[petsc-users] Fortran: undefined reference to petscsfdistributesection
    Matthew Knepley
    knepley at gmail.com
    Mon Dec  3 14:03:40 CST 2018
On Mon, Dec 3, 2018 at 2:27 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> Thanks.
> BTW: DmPlexGetVertexNumbering now can work using the latest develop
> version. But the index is not in natural ordering when DMSetUseNatural is
> called. That's why I want to use PetscSFDistributeSection to check if I
> miss anything in the code.
> Can you explain that a little more? Maybe you can just push forward what
you want using the migrationSF.
     Matt
> Regards,
> Danyang
> On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
> I need to write a custom Fortran stub for this one. I will get it done as
> soon as possible.
>   Thanks,
>     Matt
> On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi All,
>> I got a simple compilation error when use PetscSFDistributeSection in
>> Fortran. It looks like the required head files are included and the
>> parameters are correctly defined. However, when compile the code, I got
>> error undefined reference to `petscsfdistributesection_'. The code is
>> shown below. Did I miss anything here?
>> #include <petsc/finclude/petscsys.h>
>> #include <petsc/finclude/petscvec.h>
>> #include <petsc/finclude/petscdm.h>
>> #include <petsc/finclude/petscdmplex.h>
>>        use petscsys
>>        use petscvec
>>        use petscdm
>>        use petscdmplex
>>        implicit none
>>        PetscSection ::  section, section_seq
>>        PetscSF :: migrationsf_inv, sf_natural
>>        Vec :: vec_global, vec_natural
>>        PetscErrorCode :: ierr
>>        call PetscSFDistributeSection(migrationsf_inv,section,           &
>> PETSC_NULL_INTEGER,section_seq,ierr)
>>        CHKERRQ(ierr)
>>            CHKERRQ(ierr)
>> Thanks,
>> Danyang
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/c7a7c8c9/attachment.html>
