[petsc-users] Incorrect Eigenvalues when Setting KSP and PC types
Hong hzhang at mcs.anl.gov
Thu Sep 21 17:39:27 CDT 2017
Greg:
> OK, the difference is whether LU or Cholesky factorization is used. But I
> would hope that neither one should give incorrect eigenvalues, and when I
> run with the latter it does!
Are your matrices symmetric/Hermitian?
Hong
> On Thu, Sep 21, 2017 at 2:05 PM Hong <hzhang at mcs.anl.gov> wrote:
>> Gregory :
>> Use '-eps_view' for both runs to check the algorithms being used.
>> Hong
>> Hi all,
>>> I'm using shift-invert with EPS to solve for eigenvalues. I find that if
>>> I do only
>>>   ierr = EPSGetST(eps,&st);CHKERRQ(ierr);
>>>   ierr = STSetType(st,STSINVERT);CHKERRQ(ierr);
>>> in my code I get correct eigenvalues. But if I do
>>>   ierr = STGetKSP(st,&ksp);CHKERRQ(ierr);
>>>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>>   ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
>>>   ierr = PCSetType(pc,PCCHOLESKY);CHKERRQ(ierr);
>>> the eigenvalues found by EPS are completely wrong! Somehow I thought I
>>> was supposed to do the latter, from the examples etc, but I guess that was
>>> not correct? I attach the full piece of test code and a test matrix.
>>> Best,
>>> Greg
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170921/d23bd488/attachment.html>
