[petsc-users] Newton LS - better results on single processor
Thu Nov 9 07:44:44 CST 2017
On Thu, Nov 9, 2017 at 12:14 AM, zakaryah . <zakaryah at gmail.com> wrote:
> Well the saga of my problem continues.  As I described previously in an
> epic thread, I'm using the SNES to solve problems involving an elastic
> material on a rectangular grid, subjected to external forces.  In any case,
> I'm occasionally getting poor convergence using Newton's method with line
> search.  In troubleshooting by visualizing the residual, I saw that in data
> sets which had good convergence, the residual was nevertheless
> significantly larger along the boundary between different processors.
> Likewise, in data sets with poor convergence, the residual became very
> large on the boundary between different processors.  The residual is not
> significantly larger on the physical boundary, i.e. the global boundary.
> When I run on a single process, convergence seems to be good on all data
> sets.
> Any clues to fix this?
It sounds like something is wrong with communication across domains:
 - If this is FEM, it sounds like you are not adding contributions from the
other domain to shared vertices/edges/faces
 - If this is FDM/FVM, maybe the ghosts are not updated
What DM are you using? Are you using the Local assembly functions
(FormFunctionLocal), or just FormFunction()?
     Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171109/ec673979/attachment.html>
