[petsc-users] PetscFECreateDefault in Fortran
Justin Pogacnik j.pogacnik at auckland.ac.nz
Wed May 31 22:00:09 CDT 2017
Thanks Matt! That works perfectly now. I have another question regarding accessing the quadrature information.
When I use PetscFEGetQuadrature(), then PetscQuadratureView(), I see what I expect regarding point locations, weights.
However, when I try to use PetscQuadratureGetData() the pointers seem to point to random memory locations.
The exact line from my test problem is: call PetscQuadratureGetData(quad,q_nc,q_dim,q_num,pq_points,pq_weights,ierr);
where the pq_* are the pointers giving strange output. The q_nc, q_dim, and q_num are all giving what I would expect to see.
Happy to send along the file if that helps.
Thanks again,
Justin
Sent: Thursday, June 1, 2017 1:34 AM
To: Justin Pogacnik
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PetscFECreateDefault in Fortran
On Wed, May 31, 2017 at 7:53 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, May 30, 2017 at 10:19 PM, Justin Pogacnik <j.pogacnik at auckland.ac.nz<mailto:j.pogacnik at auckland.ac.nz>> wrote:
Hello,
I'm developing a finite element code in fortran 90. I recently updated my PETSc and am now getting the following error during compile/linking on an existing application:
Undefined symbols for architecture x86_64:
  "_petscfecreatedefault_", referenced from:
      _MAIN__ in fe_test.o
ld: symbol(s) not found for architecture x86_64
collect2: error: ld returned 1 exit status
make: *** [dist/fe_test] Error 1
I'm running Mac OS X Yosemite (10.10.5). I've created a "minimum working example" (attached) that re-creates the problem. It's basically just dm/impls/plex/examples/tutorials/ex3f90, but tries to create a PetscFE object. Everything goes fine and the DM looks like what is expected if PetscFECreateDefault is commented out. Any idea what am I missing?
Yes, I had not made a Fortran binding for this function. I will do it now.
I have merged it to the 'next' branch, and it will be in 'master' soon.
     Matt
     Matt
Many thanks!
Justin
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170601/171891d2/attachment.html>
