[petsc-users] PetscFECreateDefault in Fortran
Justin Pogacnik j.pogacnik at auckland.ac.nz
Tue May 30 22:19:34 CDT 2017
Hello,
I'm developing a finite element code in fortran 90. I recently updated my PETSc and am now getting the following error during compile/linking on an existing application:
Undefined symbols for architecture x86_64:
  "_petscfecreatedefault_", referenced from:
      _MAIN__ in fe_test.o
ld: symbol(s) not found for architecture x86_64
collect2: error: ld returned 1 exit status
make: *** [dist/fe_test] Error 1
I'm running Mac OS X Yosemite (10.10.5). I've created a "minimum working example" (attached) that re-creates the problem. It's basically just dm/impls/plex/examples/tutorials/ex3f90, but tries to create a PetscFE object. Everything goes fine and the DM looks like what is expected if PetscFECreateDefault is commented out. Any idea what am I missing?
Many thanks!
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170531/a46cbf53/attachment.html>
Desc: fe_test.F90
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170531/a46cbf53/attachment.obj>
