[petsc-users] a question about PetscSectionCreate
leejearl leejearl at 126.com
Sun May 28 01:31:48 CDT 2017
Hi, PETSc developer:
     I need to create a PetscSection with a struct. The struct is
defined as follow,
    typedef struct
       PetscReal x;
       PetscInt id;
    } testStruct;
    When I run the program, I got a wrong output as follow,
    Vec Object: 1 MPI processes
   type: seq
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
2.
4.94066e-324
But when I defined the struct as
    typedef struct
       PetscReal x;
       PetscReal id;
    } testStruct;
The output is ok. It seems that  there is some wrong with the memories
when I define the "id" as a PetscInt type.
I can not find out the reasons, and any one can help me with it? The
source file "test.c" is attached.
leejearl
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170528/fd8f4dba/attachment.c>
