[petsc-users] DMPlex export to hdf5/vtk for triangle/prism mesh
Fabian.Jakub Fabian.Jakub at physik.uni-muenchen.de
Fri May 26 12:27:25 CDT 2017
Dear Petsc Team,
I am playing around with DMPlex, using it to generate the Mesh for the
ICON weather model(http://doi.org/10.1002/2015MS000431), which employs a
triangle mesh horizontally and columns, vertically.
This results in a grid, looking like prisms, where top and bottom faces
are triangles and side faces are rectangles.
I was delighted to see that I could export the triangle DMPlex (2d Mesh)
to hdf5 and use petsc_gen_xdmf.py to then visualize the mesh in
visit/paraview.
This is especially nice when exporting petscsections/vectors directly to
VTK.
I then tried the same approach for the prism grid in 3D.
I attached the code for one single cell, as well as the output in hdf5.
However, trying to convert the hdf5 output, it fails with:
make prism.xmf
$PETSC_DIR/bin/petsc_gen_xdmf.py prism.h5
Traceback (most recent call last):
  File
"/software/meteo/xenial/x86_64/petsc/master/debug_gcc/..//bin/petsc_gen_xdmf.py",
line 241, in <module>
    generateXdmf(f)
  File
line 235, in generateXdmf
    Xdmf(xdmfFilename).write(hdfFilename, topoPath, numCells,
numCorners, cellDim, geomPath, numVertices, spaceDim, time, vfields,
cfields)
  File
line 193, in write
    self.writeSpaceGridHeader(fp, numCells, numCorners, cellDim, spaceDim)
  File
line 75, in writeSpaceGridHeader
    ''' % (self.cellMap[cellDim][numCorners], numCells, "XYZ" if
spaceDim > 2 else "XY"))
KeyError: 6
Also, if I try to export a vector directly to vtk, visit and paraview
fail to open it.
My question is:
Is this a general limitation of these output formats, that I can not mix
faces with 3 and 4 vertices or is it a limitation of the
petsc_gen_xdmf.py or the VTK Viewer.
I'd also welcome any thoughts on the prism mesh in general.
Is it that uncommon to use and do you foresee other complications with it?
I fear I cannot change the discretization of the host model but maybe it
makes sense to use a different grid for my radiative transfer code?
Many thanks,
Fabian
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
prism.xmf:: prism.h5
		${PETSC_DIR}/bin/petsc_gen_xdmf.py prism.h5
prism.h5:: plex_prism
		./plex_prism -show_plex ::ascii_info_detail
		./plex_prism -show_plex hdf5:prism.h5
plex_prism:: plex_prism.F90
		${PETSC_FCOMPILE} -c plex_prism.F90
		${FLINKER} plex_prism.o -o plex_prism ${PETSC_LIB}
clean::
		rm -rf *.o prism.h5 prism.xmf plex_prism
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170526/92c3cbf5/attachment-0001.bin>
Type: application/x-hdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170526/92c3cbf5/attachment-0001.hdf>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170526/92c3cbf5/attachment-0001.pgp>
