[petsc-users] DMPlex distribution with FVM adjacency
Thu May 25 15:00:19 CDT 2017
On Thu, May 25, 2017 at 2:22 PM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> > On 25 May 2017, at 20:03, Matthew Knepley <knepley at gmail.com> wrote:
> > Hmm, I thought I made adjacency per field. I have to look. That way, no
> problem with the Stokes example. DG is still weird.
> You might, we don't right now.  We just make the topological adjacency
> that is "large enough", and then make fields on that.
> > That seems baroque. So this is just another adjacency pattern. You
> should be able to easily define it, or if you are a patient person,
> > wait for me to do it. Its here
> > https://bitbucket.org/petsc/petsc/src/01c3230e040078628f5e559992965c
> 1c4b6f473d/src/dm/impls/plex/plexdistribute.c?at=master&
> fileviewer=file-view-default#plexdistribute.c-239
> > I am more than willing to make this overridable by the user through
> function composition or another mechanism.
> Hmm, that naive thing of just modifying the XXX_Support_Internal to
> compute with DMPlexGetTransitiveClosure rather than DMPlexGetCone didn't do
> what I expected, but I don't understand the way this bootstrapping is done
> very well.
It should do the right thing. Notice that you have to be careful about the
arrays that you use since I reuse them for efficiency here.
What is going wrong?
   Matt
> Cheers,
> Lawrence
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170525/e778481e/attachment.html>
