[petsc-users] DMPlex distribution with FVM adjacency
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Thu May 25 13:38:51 CDT 2017
> On 25 May 2017, at 19:23, Matthew Knepley <knepley at gmail.com> wrote:
> Ok, let me clarify.
> Given shared facets, I'd like closure(support(facet)) this is a subset of the fem adjacency. "Add in the cell and its closure from the remote rank". This doesn't include remote cells I can only see through vertices. Without sending data evaluated at facet quad points, I think this is the adjacency I need to compute facet integrals: all the dofs in closure(support(facet)).
> This seems incoherent to me. For FV, dofs reside in the cells, so you should only need the cell for adjacency. If you
> need dofs defined at vertices, then you should also need cells which are only attached by vertices. How could this
> scheme be consistent without this?
OK, so what I think is this:
I need to compute integrals over cells and facets.
So I do:
GlobalToLocal(INSERT_VALUES)
ComputeIntegralsOnOwnedEntities
LocalToGlobal(ADD_VALUES)
That way, an integration is performed on every entity exactly once, and LocalToGlobal ensures that I get a consistent assembled Vec.
OK, so if I only compute cell integrals, then the zero overlap distribution with all the points in the closure of the cell (including some remote points) is sufficient.
If I compute facet integrals, I need both cells (and their closure) in the support of the facet.  Again, each facet is only integrated by one process, and the LocalToGlobal adds in contributions to remote dofs.  This is the same as cell integrals, just I need a bit more data, no?
The other option is to notice that what I actually need when I compute a facet integral is the test function and/or any coefficients evaluated at quadrature points on the facet.  So if I don't want the extra overlapped halo, then what I need to do is for the remote process to evaluate any coefficients at the quad points, then send the evaluated data to the facet owner.  Now the facet owner can compute the integral, and again LocalToGlobal adds in contributions to remote dofs.
Lawrence
