[petsc-users] Question on incomplete factorization level and fill
Hong hzhang at mcs.anl.gov
Wed May 24 20:32:40 CDT 2017
Remove your option '-vecload_block_size 10'.
Hong
On Wed, May 24, 2017 at 3:06 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Dear Hong,
> I just tested with different number of processors for the same matrix. It
> sometimes got "ERROR: Arguments are incompatible" for different number of
> processors. It works fine using 4, 8, or 24 processors, but failed with
> "ERROR: Arguments are incompatible" using 16 or 48 processors. The error
> information is attached. I tested this on my local computer with 6 cores 12
> threads. Any suggestion on this?
> Thanks,
> Danyang
> On 17-05-24 12:28 PM, Danyang Su wrote:
> Hi Hong,
> Awesome. Thanks for testing the case. I will try your options for the code
> and get back to you later.
> Regards,
> Danyang
> On 17-05-24 12:21 PM, Hong wrote:
> Danyang :
> I tested your data.
> Your matrices encountered zero pivots, e.g.
> petsc/src/ksp/ksp/examples/tutorials (master)
> $ mpiexec -n 24 ./ex10 -f0 a_react_in_2.bin -rhs b_react_in_2.bin
> -ksp_monitor -ksp_error_if_not_converged
> [15]PETSC ERROR: Zero pivot in LU factorization:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
> [15]PETSC ERROR: Zero pivot row 1249 value 2.05808e-14 tolerance
> 2.22045e-14
> Adding option '-sub_pc_factor_shift_type nonzero', I got
> -ksp_monitor -ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero
> -mat_view ascii::ascii_info
> Mat Object: 24 MPI processes
>   type: mpiaij
>   rows=450000, cols=450000
>   total: nonzeros=6991400, allocated nonzeros=6991400
>   total number of mallocs used during MatSetValues calls =0
>     not using I-node (on process 0) routines
>   0 KSP Residual norm 5.849777711755e+01
>   1 KSP Residual norm 6.824179430230e-01
>   2 KSP Residual norm 3.994483555787e-02
>   3 KSP Residual norm 6.085841461433e-03
>   4 KSP Residual norm 8.876162583511e-04
>   5 KSP Residual norm 9.407780665278e-05
> Number of iterations =   5
> Residual norm 0.00542891
> Hong
>> Hi Matt,
>> Yes. The matrix is 450000x450000 sparse. The hypre takes hundreds of
>> iterates, not for all but in most of the timesteps. The matrix is not well
>> conditioned, with nonzero entries range from 1.0e-29 to 1.0e2. I also made
>> double check if there is anything wrong in the parallel version, however,
>> the matrix is the same with sequential version except some round error
>> which is relatively very small. Usually for those not well conditioned
>> matrix, direct solver should be faster than iterative solver, right? But
>> when I use the sequential iterative solver with ILU prec developed almost
>> 20 years go by others, the solver converge fast with appropriate
>> factorization level. In other words, when I use 24 processor using hypre,
>> the speed is almost the same as as the old sequential iterative solver
>> using 1 processor.
>> I use most of the default configuration for the general case with pretty
>> good speedup. And I am not sure if I miss something for this problem.
>> Thanks,
>> Danyang
>> On 17-05-24 11:12 AM, Matthew Knepley wrote:
>> On Wed, May 24, 2017 at 12:50 PM, Danyang Su <danyang.su at gmail.com>
>> wrote:
>>> Hi Matthew and Barry,
>>> Thanks for the quick response.
>>> I also tried superlu and mumps, both work but it is about four times
>>> slower than ILU(dt) prec through hypre, with 24 processors I have tested.
>> You mean the total time is 4x? And you are taking hundreds of iterates?
>> That seems hard to believe, unless you are dropping
>> a huge number of elements.
>>> When I look into the convergence information, the method using ILU(dt)
>>> still takes 200 to 3000 linear iterations for each newton iteration. One
>>> reason is this equation is hard to solve. As for the general cases, the
>>> same method works awesome and get very good speedup.
>> I do not understand what you mean here.
>>> I also doubt if I use hypre correctly for this case. Is there anyway to
>>> check this problem, or is it possible to increase the factorization level
>>> through hypre?
>> I don't know.
>>   Matt
>>> Thanks,
>>> Danyang
>>> On 17-05-24 04:59 AM, Matthew Knepley wrote:
>>> On Wed, May 24, 2017 at 2:21 AM, Danyang Su <danyang.su at gmail.com>
>>> wrote:
>>>> Dear All,
>>>> I use PCFactorSetLevels for ILU and PCFactorSetFill for other
>>>> preconditioning in my code to help solve the problems that the default
>>>> option is hard to solve. However, I found the latter one, PCFactorSetFill
>>>> does not take effect for my problem. The matrices and rhs as well as the
>>>> solutions are attached from the link below. I obtain the solution using
>>>> hypre preconditioner and it takes 7 and 38 iterations for matrix 1 and
>>>> matrix 2. However, if I use other preconditioner, the solver just failed at
>>>> the first matrix. I have tested this matrix using the native sequential
>>>> solver (not PETSc) with ILU preconditioning. If I set the incomplete
>>>> factorization level to 0, this sequential solver will take more than 100
>>>> iterations. If I increase the factorization level to 1 or more, it just
>>>> takes several iterations. This remind me that the PC factor for this
>>>> matrices should be increased. However, when I tried it in PETSc, it just
>>>> does not work.
>>>> Matrix and rhs can be obtained from the link below.
>>>> https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R
>>>> Would anyone help to check if you can make this work by increasing the
>>>> PC factor level or fill?
>>> We have ILU(k) supported in serial. However ILU(dt) which takes a
>>> tolerance only works through Hypre
>>>   http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>> I recommend you try SuperLU or MUMPS, which can both be downloaded
>>> automatically by configure, and
>>> do a full sparse LU.
>>>   Thanks,
>>>     Matt
>>>> Thanks and regards,
>>>> Danyang
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> http://www.caam.rice.edu/~mk51/
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170524/60796a5e/attachment-0001.html>
