[petsc-users] Question on incomplete factorization level and fill
Danyang Su danyang.su at gmail.com
Wed May 24 14:28:51 CDT 2017
Hi Hong,
Awesome. Thanks for testing the case. I will try your options for the
code and get back to you later.
Danyang
On 17-05-24 12:21 PM, Hong wrote:
> Danyang :
> I tested your data.
> Your matrices encountered zero pivots, e.g.
> petsc/src/ksp/ksp/examples/tutorials (master)
> $ mpiexec -n 24 ./ex10 -f0 a_react_in_2.bin -rhs b_react_in_2.bin
> -ksp_monitor -ksp_error_if_not_converged
> [15]PETSC ERROR: Zero pivot in LU factorization:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
> [15]PETSC ERROR: Zero pivot row 1249 value 2.05808e-14 tolerance
> 2.22045e-14
> Adding option '-sub_pc_factor_shift_type nonzero', I got
> -ksp_monitor -ksp_error_if_not_converged -sub_pc_factor_shift_type
> nonzero -mat_view ascii::ascii_info
> Mat Object: 24 MPI processes
>   type: mpiaij
>   rows=450000, cols=450000
>   total: nonzeros=6991400, allocated nonzeros=6991400
>   total number of mallocs used during MatSetValues calls =0
>     not using I-node (on process 0) routines
>   0 KSP Residual norm 5.849777711755e+01
>   1 KSP Residual norm 6.824179430230e-01
>   2 KSP Residual norm 3.994483555787e-02
>   3 KSP Residual norm 6.085841461433e-03
>   4 KSP Residual norm 8.876162583511e-04
>   5 KSP Residual norm 9.407780665278e-05
> Number of iterations =   5
> Residual norm 0.00542891
> Hong
>     Hi Matt,
>     Yes. The matrix is 450000x450000 sparse. The hypre takes hundreds
>     of iterates, not for all but in most of the timesteps. The matrix
>     is not well conditioned, with nonzero entries range from 1.0e-29
>     to 1.0e2. I also made double check if there is anything wrong in
>     the parallel version, however, the matrix is the same with
>     sequential version except some round error which is relatively
>     very small. Usually for those not well conditioned matrix, direct
>     solver should be faster than iterative solver, right? But when I
>     use the sequential iterative solver with ILU prec developed almost
>     20 years go by others, the solver converge fast with appropriate
>     factorization level. In other words, when I use 24 processor using
>     hypre, the speed is almost the same as as the old sequential
>     iterative solver using 1 processor.
>     I use most of the default configuration for the general case with
>     pretty good speedup. And I am not sure if I miss something for
>     this problem.
>     Thanks,
>     Danyang
>     On 17-05-24 11:12 AM, Matthew Knepley wrote:
>>     On Wed, May 24, 2017 at 12:50 PM, Danyang Su
>>     <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> wrote:
>>         Hi Matthew and Barry,
>>         Thanks for the quick response.
>>         I also tried superlu and mumps, both work but it is about
>>         four times slower than ILU(dt) prec through hypre, with 24
>>         processors I have tested.
>>     You mean the total time is 4x? And you are taking hundreds of
>>     iterates? That seems hard to believe, unless you are dropping
>>     a huge number of elements.
>>         When I look into the convergence information, the method
>>         using ILU(dt) still takes 200 to 3000 linear iterations for
>>         each newton iteration. One reason is this equation is hard to
>>         solve. As for the general cases, the same method works
>>         awesome and get very good speedup.
>>     I do not understand what you mean here.
>>         I also doubt if I use hypre correctly for this case. Is there
>>         anyway to check this problem, or is it possible to increase
>>         the factorization level through hypre?
>>     I don't know.
>>       Matt
>>         Thanks,
>>         Danyang
>>         On 17-05-24 04:59 AM, Matthew Knepley wrote:
>>>         On Wed, May 24, 2017 at 2:21 AM, Danyang Su
>>>             Dear All,
>>>             I use PCFactorSetLevels for ILU and PCFactorSetFill for
>>>             other preconditioning in my code to help solve the
>>>             problems that the default option is hard to solve.
>>>             However, I found the latter one, PCFactorSetFill does
>>>             not take effect for my problem. The matrices and rhs as
>>>             well as the solutions are attached from the link below.
>>>             I obtain the solution using hypre preconditioner and it
>>>             takes 7 and 38 iterations for matrix 1 and matrix 2.
>>>             However, if I use other preconditioner, the solver just
>>>             failed at the first matrix. I have tested this matrix
>>>             using the native sequential solver (not PETSc) with ILU
>>>             preconditioning. If I set the incomplete factorization
>>>             level to 0, this sequential solver will take more than
>>>             100 iterations. If I increase the factorization level to
>>>             1 or more, it just takes several iterations. This remind
>>>             me that the PC factor for this matrices should be
>>>             increased. However, when I tried it in PETSc, it just
>>>             does not work.
>>>             Matrix and rhs can be obtained from the link below.
>>>             https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R
>>>             <https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R>
>>>             Would anyone help to check if you can make this work by
>>>             increasing the PC factor level or fill?
>>>         We have ILU(k) supported in serial. However ILU(dt) which
>>>         takes a tolerance only works through Hypre
>>>         http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>>         <http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html>
>>>         I recommend you try SuperLU or MUMPS, which can both be
>>>         downloaded automatically by configure, and
>>>         do a full sparse LU.
>>>           Thanks,
>>>             Matt
>>>             Thanks and regards,
>>>             Danyang
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>>         http://www.caam.rice.edu/~mk51/
>>>         <http://www.caam.rice.edu/%7Emk51/>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
>>     http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170524/f7a2d84e/attachment.html>
