[petsc-users] Accessing submatrices without additional memory usage
Michał Dereziński michal.derezinski at gmail.com
Wed May 24 12:37:11 CDT 2017
Great! Then I have a follow-up question:
My goal is to be able to load the full matrix X from disk, while at the same time in parallel, performing computations on the submatrices that have already been loaded. Essentially, I want to think of X as a block matrix (where the blocks are horizontal, spanning the full width of the matrix), where I’m loading one block at a time, and all the blocks that have already been loaded are combined using MatCreateNest, so that I can make computations on that portion of the matrix.
In this scenario, every process needs to be simultaneously loading the next block of X, and perform computations on the previously loaded portion. My strategy is for each MPI process to spawn a thread for data loading (so that the memory between the process and the thread is shared), while the process does computations. My concern is that the data loading thread may be using up computational resources of the processor, even though it is mainly doing IO. Will this be an issue? What is the best way to minimize the cpu time of this parallel data loading scheme?
Michal.
> Wiadomość napisana przez Matthew Knepley <knepley at gmail.com> w dniu 24.05.2017, o godz. 04:55:
> On Wed, May 24, 2017 at 1:09 AM, Michal Derezinski <mderezin at ucsc.edu <mailto:mderezin at ucsc.edu>> wrote:
> Hi,
> I want to be able to perform matrix operations on several contiguous submatrices of a full matrix, without allocating the memory redundantly for the submatrices (in addition to the memory that is already allocated for the full matrix).
> I tried using MatGetSubMatrix, but this function appears to allocate the additional memory.
> The other way I found to do this is to create the smallest submatrices I need first, then use MatCreateNest to combine them into bigger ones (including the full matrix).
> The documentation of MatCreateNest seems to indicate that it does not allocate additional memory for storing the new matrix.
> Is this the right approach, or is there a better one?
> Yes, that is the right approach.
>   Thanks,
>     Matt
> Thanks,
> Michal Derezinski.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170524/b4e1ffbd/attachment.html>
