[petsc-users] Installation question
Pham Pham pvsang002 at gmail.com
Mon May 22 18:00:09 CDT 2017
Hi Barry,
My code using DMDA, the mesh is partitioned in x-direction only. Can I have
MPI+OpenMP works in the following way:
I want to create a new communicator which includes  processes with
Rank%12==0, PETSc objects will be created with this new sub-set of
processes. In each node (which has 12 cores), the first core (Rank%12==0)
does MPI communicating job (with Rank%12==0 process of other nodes), then
commanded other 11 processes do computation works using openMP?
Thank you.
On Tue, May 23, 2017 at 1:58 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On May 22, 2017, at 11:25 AM, Pham Pham <pvsang002 at gmail.com> wrote:
> > Hi Matt,
> > For the machine I have, Is it a good idea if I mix MPI and OpenMP: MPI
> for cores with Rank%12==0 and OpenMP for the others ?
>    MPI+OpenMP doesn't work this way. Each "rank" is an MPI process, you
> cannot say some ranks are MPI and some are OpenMP. If you want to use one
> MPI process per node and have each MPI process have 12 OpenMP threads you
> need to find out for YOUR systems MPI how you tell it to put one MPI
> process per node;
>    Barry
> > Thank you,
> > PVS.
> > On Thu, May 11, 2017 at 8:27 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, May 11, 2017 at 7:08 AM, Pham Pham <pvsang002 at gmail.com> wrote:
> > Hi Matt,
> > Thank you for the reply.
> > I am using University HPC which has multiple nodes, and should be good
> for parallel computing. The bad performance might be due to the way I
> install and run PETSc...
> > Looking at the output when running streams, I can see that the Processor
> names were the same.
> > Does that mean only one processor involved in computing, did it cause
> the bad performance?
> > Yes. From the data, it appears that the kind of processor you have has
> 12 cores, but only enough memory bandwidth to support 1.5 cores.
> > Try running the STREAMS with only 1 process per node. This is a setting
> in your submission script, but it is different for every cluster. Thus
> > I would ask the local sysdamin for this machine to help you do that. You
> should see almost perfect scaling with that configuration. You might
> > also try 2 processes per node to compare.
> >   Thanks,
> >      Matt
> > Thank you very much.
> > Ph.
> > Below is testing output:
> > [mpepvs at atlas5-c01 petsc-3.7.5]$ make PETSC_DIR=/home/svu/mpepvs/petsc/petsc-3.7.5
> PETSC_ARCH=arch-linux-cxx-opt streams
> > cd src/benchmarks/streams; /usr/bin/gmake  --no-print-directory
> > /app1/centos6.3/Intel/xe_2015/impi/5.0.3.048/intel64/bin/mpicxx -o
> MPIVersion.o c -wd1572 -g -O3   -fPIC    -I/home/svu/mpepvs/petsc/petsc-3.7.5/include
> -I/hom
>                                        e/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/include
> -I/app1/centos6.3/Intel/xe_2015/impi/5.0.3.048/intel64/include
> `pwd`/MPIVersion.c
> > The version of PETSc you are using is out-of-date, we recommend updating
> to the new release
> >  Available Version: 3.7.6   Installed Version: 3.7.5
> > http://www.mcs.anl.gov/petsc/download/index.html
> > Running streams with 'mpiexec.hydra ' using 'NPMAX=12'
> > Number of MPI processes 1 Processor names  atlas5-c01
> > Triad:        11026.7604   Rate (MB/s)
> > Number of MPI processes 2 Processor names  atlas5-c01 atlas5-c01
> > Triad:        14669.6730   Rate (MB/s)
> > Number of MPI processes 3 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01
> > Triad:        12848.2644   Rate (MB/s)
> > Number of MPI processes 4 Processor names  atlas5-c01 atlas5-c01
> > Triad:        15033.7687   Rate (MB/s)
> > Number of MPI processes 5 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01 atlas5-c01 atlas5-c01
> > Triad:        13299.3830   Rate (MB/s)
> > Number of MPI processes 6 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
> > Triad:        14382.2116   Rate (MB/s)
> > Number of MPI processes 7 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
> > Triad:        13194.2573   Rate (MB/s)
> > Number of MPI processes 8 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
> > Triad:        14199.7255   Rate (MB/s)
> > Number of MPI processes 9 Processor names  atlas5-c01 atlas5-c01
> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
> > Triad:        13045.8946   Rate (MB/s)
> > Number of MPI processes 10 Processor names  atlas5-c01 atlas5-c01
> > Triad:        13058.3283   Rate (MB/s)
> > Number of MPI processes 11 Processor names  atlas5-c01 atlas5-c01
> > Triad:        13037.3334   Rate (MB/s)
> > Number of MPI processes 12 Processor names  atlas5-c01 atlas5-c01
> > Triad:        12526.6096   Rate (MB/s)
> > np  speedup
> > 1 1.0
> > 2 1.33
> > 3 1.17
> > 4 1.36
> > 5 1.21
> > 6 1.3
> > 7 1.2
> > 8 1.29
> > 9 1.18
> > 10 1.18
> > 11 1.18
> > 12 1.14
> > Estimation of possible speedup of MPI programs based on Streams
> benchmark.
> > It appears you have 1 node(s)
> > See graph in the file src/benchmarks/streams/scaling.png
> > On Fri, May 5, 2017 at 11:26 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Fri, May 5, 2017 at 10:18 AM, Pham Pham <pvsang002 at gmail.com> wrote:
> > Hi Satish,
> > It runs now, and shows a bad speed up:
> > Please help to improve this.
> > http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
> > The short answer is: You cannot improve this without buying a different
> machine. This is
> > a fundamental algorithmic limitation that cannot be helped by threads,
> or vectorization, or
> > anything else.
> >    Matt
> > Thank you.
> > <scaling.png>
> > On Fri, May 5, 2017 at 10:02 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > With Intel MPI - its best to use mpiexec.hydra [and not mpiexec]
> > So you can do:
> PETSC_ARCH=arch-linux-cxx-opt MPIEXEC=mpiexec.hydra test
> > [you can also specify --with-mpiexec=mpiexec.hydra at configure time]
> > Satish
> > On Fri, 5 May 2017, Pham Pham wrote:
> > > *Hi,*
> > > *I can configure now, but fail when testing:*
> > > [mpepvs at atlas7-c10 petsc-3.7.5]$ make
> > > test   Running test examples to verify correct installation
> > > Using PETSC_DIR=/home/svu/mpepvs/petsc/petsc-3.7.5 and
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
> MPI
> > > process
> > > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > > mpiexec_atlas7-c10: cannot connect to local mpd
> (/tmp/mpd2.console_mpepvs);
> > > possible causes:
> > >   1. no mpd is running on this host
> > >   2. an mpd is running but was started without a "console" (-n option)
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
> MPI
> > > processes
> > > possible causes:
> > > Possible error running Fortran example src/snes/examples/tutorials/
> ex5f
> > > with 1 MPI process
> > > possible causes:
> > > Completed test examples
> > > Now to evaluate the computer systems you plan use - do:
> > > *Please help on this.*
> > > *Many thanks!*
> > > On Thu, Apr 20, 2017 at 2:02 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > Sorry - should have mentioned:
> > > > do 'rm -rf arch-linux-cxx-opt' and rerun configure again.
> > > > The mpich install from previous build [that is currently in
> > > > arch-linux-cxx-opt/]
> > > > is conflicting with --with-mpi-dir=/app1/centos6.3/gnu/mvapich2-1.9/
> > > > Satish
> > > > On Wed, 19 Apr 2017, Pham Pham wrote:
> > > > > I reconfigured PETSs with installed MPI, however, I got serous
> error:
> > > > > **************************ERROR*************************
> > > > >   Error during compile, check arch-linux-cxx-opt/lib/petsc/
> conf/make.log
> > > > >   Send it and arch-linux-cxx-opt/lib/petsc/conf/configure.log to
> > > > > petsc-maint at mcs.anl.gov
> > > > > Please explain what is happening?
> > > > > On Wed, Apr 19, 2017 at 11:43 PM, Satish Balay <balay at mcs.anl.gov>
> > > > wrote:
> > > > > > Presumably your cluster already has a recommended MPI to use
> [which is
> > > > > > already installed. So you should use that - instead of
> > > > > > --download-mpich=1
> > > > > > Satish
> > > > > > > Hi,
> > > > > > > I just installed petsc-3.7.5 into my university cluster. When
> > > > evaluating
> > > > > > > the computer system, PETSc reports "It appears you have 1
> node(s)", I
> > > > > > donot
> > > > > > > understand this, since the system is a multinodes system.
> Could you
> > > > > > please
> > > > > > > explain this to me?
> > > > > > > S.
> > > > > > > Output:
> > > > > > > streams
> > > > > > > streams
> > > > > > > /home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpicxx
> -o
> > > > > > > MPIVersion.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
> > > > > > > -Wno-unknown-pragmas -fvisibility=hidden -g -O
> > > > > > > -I/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-
> opt/include
> > > > > > > `pwd`/MPIVersion.c
> > > > > > > '/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpiexec
> > > > > > using
> > > > > > > 'NPMAX=12'
> > > > > > > Number of MPI processes 1 Processor names  atlas7-c10
> > > > > > > Triad:         9137.5025   Rate (MB/s)
> > > > > > > Number of MPI processes 2 Processor names  atlas7-c10
> atlas7-c10
> > > > > > > Triad:         9707.2815   Rate (MB/s)
> > > > > > > Number of MPI processes 3 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > Triad:        13559.5275   Rate (MB/s)
> > > > > > > Number of MPI processes 4 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > atlas7-c10
> > > > > > > Triad:        14193.0597   Rate (MB/s)
> > > > > > > Number of MPI processes 5 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > atlas7-c10 atlas7-c10
> > > > > > > Triad:        14492.9234   Rate (MB/s)
> > > > > > > Number of MPI processes 6 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > atlas7-c10 atlas7-c10 atlas7-c10
> > > > > > > Triad:        15476.5912   Rate (MB/s)
> > > > > > > Number of MPI processes 7 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
> > > > > > > Triad:        15148.7388   Rate (MB/s)
> > > > > > > Number of MPI processes 8 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> > > > > > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
> > > > > > > Triad:        15799.1290   Rate (MB/s)
> > > > > > > Number of MPI processes 9 Processor names  atlas7-c10
> atlas7-c10
> > > > > > atlas7-c10
> atlas7-c10
> > > > > > > Triad:        15671.3104   Rate (MB/s)
> > > > > > > Number of MPI processes 10 Processor names  atlas7-c10
> atlas7-c10
> atlas7-c10
> > > > > > > Triad:        15601.4754   Rate (MB/s)
> > > > > > > Number of MPI processes 11 Processor names  atlas7-c10
> atlas7-c10
> atlas7-c10
> > > > > > > Triad:        15434.5790   Rate (MB/s)
> > > > > > > Number of MPI processes 12 Processor names  atlas7-c10
> atlas7-c10
> atlas7-c10
> > > > > > > Triad:        15134.1263   Rate (MB/s)
> > > > > > > np  speedup
> > > > > > > 1 1.0
> > > > > > > 2 1.06
> > > > > > > 3 1.48
> > > > > > > 4 1.55
> > > > > > > 5 1.59
> > > > > > > 6 1.69
> > > > > > > 7 1.66
> > > > > > > 8 1.73
> > > > > > > 9 1.72
> > > > > > > 10 1.71
> > > > > > > 11 1.69
> > > > > > > 12 1.66
> > > > > > benchmark.
> > > > > > > Unable to plot speedup to a file
> > > > > > > Unable to open matplotlib to plot speedup
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170523/c8050512/attachment-0001.html>
