[petsc-users] Installation question
Pham Pham pvsang002 at gmail.com
Mon May 22 11:25:09 CDT 2017
Hi Matt,
For the machine I have, Is it a good idea if I mix MPI and OpenMP: MPI for
cores with Rank%12==0 and OpenMP for the others ?
Thank you,
PVS.
On Thu, May 11, 2017 at 8:27 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 11, 2017 at 7:08 AM, Pham Pham <pvsang002 at gmail.com> wrote:
>> Hi Matt,
>> Thank you for the reply.
>> I am using University HPC which has multiple nodes, and should be good
>> for parallel computing. The bad performance might be due to the way I
>> install and run PETSc...
>> Looking at the output when running streams, I can see that the Processor
>> names were the same.
>> Does that mean only one processor involved in computing, did it cause the
>> bad performance?
> Yes. From the data, it appears that the kind of processor you have has 12
> cores, but only enough memory bandwidth to support 1.5 cores.
> Try running the STREAMS with only 1 process per node. This is a setting in
> your submission script, but it is different for every cluster. Thus
> I would ask the local sysdamin for this machine to help you do that. You
> should see almost perfect scaling with that configuration. You might
> also try 2 processes per node to compare.
>   Thanks,
>      Matt
>> Thank you very much.
>> Ph.
>> Below is testing output:
>> [mpepvs at atlas5-c01 petsc-3.7.5]$ make PETSC_DIR=/home/svu/mpepvs/petsc/petsc-3.7.5
>> PETSC_ARCH=arch-linux-cxx-opt streams
>> cd src/benchmarks/streams; /usr/bin/gmake  --no-print-directory
>> /app1/centos6.3/Intel/xe_2015/impi/5.0.3.048/intel64/bin/mpicxx -o
>> MPIVersion.o c -wd1572 -g -O3   -fPIC    -I/home/svu/mpepvs/petsc/petsc-3.7.5/include
>> -I/hom
>> e/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/include
>> -I/app1/centos6.3/Intel/xe_2015/impi/5.0.3.048/intel64/include
>> `pwd`/MPIVersion.c
>> The version of PETSc you are using is out-of-date, we recommend updating
>> to the new release
>>  Available Version: 3.7.6   Installed Version: 3.7.5
>> http://www.mcs.anl.gov/petsc/download/index.html
>> Running streams with 'mpiexec.hydra ' using 'NPMAX=12'
>> Number of MPI processes 1 Processor names  atlas5-c01
>> Triad:        11026.7604   Rate (MB/s)
>> Number of MPI processes 2 Processor names  atlas5-c01 atlas5-c01
>> Triad:        14669.6730   Rate (MB/s)
>> Number of MPI processes 3 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01
>> Triad:        12848.2644   Rate (MB/s)
>> Number of MPI processes 4 Processor names  atlas5-c01 atlas5-c01
>> Triad:        15033.7687   Rate (MB/s)
>> Number of MPI processes 5 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01 atlas5-c01 atlas5-c01
>> Triad:        13299.3830   Rate (MB/s)
>> Number of MPI processes 6 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
>> Triad:        14382.2116   Rate (MB/s)
>> Number of MPI processes 7 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
>> Triad:        13194.2573   Rate (MB/s)
>> Number of MPI processes 8 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
>> Triad:        14199.7255   Rate (MB/s)
>> Number of MPI processes 9 Processor names  atlas5-c01 atlas5-c01
>> atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01 atlas5-c01
>> Triad:        13045.8946   Rate (MB/s)
>> Number of MPI processes 10 Processor names  atlas5-c01 atlas5-c01
>> Triad:        13058.3283   Rate (MB/s)
>> Number of MPI processes 11 Processor names  atlas5-c01 atlas5-c01
>> Triad:        13037.3334   Rate (MB/s)
>> Number of MPI processes 12 Processor names  atlas5-c01 atlas5-c01
>> Triad:        12526.6096   Rate (MB/s)
>> np  speedup
>> 1 1.0
>> 2 1.33
>> 3 1.17
>> 4 1.36
>> 5 1.21
>> 6 1.3
>> 7 1.2
>> 8 1.29
>> 9 1.18
>> 10 1.18
>> 11 1.18
>> 12 1.14
>> Estimation of possible speedup of MPI programs based on Streams benchmark.
>> It appears you have 1 node(s)
>> See graph in the file src/benchmarks/streams/scaling.png
>> On Fri, May 5, 2017 at 11:26 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, May 5, 2017 at 10:18 AM, Pham Pham <pvsang002 at gmail.com> wrote:
>>>> Hi Satish,
>>>> It runs now, and shows a bad speed up:
>>>> Please help to improve this.
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>> The short answer is: You cannot improve this without buying a different
>>> machine. This is
>>> a fundamental algorithmic limitation that cannot be helped by threads,
>>> or vectorization, or
>>> anything else.
>>>    Matt
>>>> Thank you.
>>>> On Fri, May 5, 2017 at 10:02 PM, Satish Balay <balay at mcs.anl.gov>
>>>> wrote:
>>>>> With Intel MPI - its best to use mpiexec.hydra [and not mpiexec]
>>>>> So you can do:
>>>>> PETSC_ARCH=arch-linux-cxx-opt MPIEXEC=mpiexec.hydra test
>>>>> [you can also specify --with-mpiexec=mpiexec.hydra at configure time]
>>>>> Satish
>>>>> On Fri, 5 May 2017, Pham Pham wrote:
>>>>> > *Hi,*
>>>>> > *I can configure now, but fail when testing:*
>>>>> > [mpepvs at atlas7-c10 petsc-3.7.5]$ make
>>>>> > test   Running test examples to verify correct installation
>>>>> > Using PETSC_DIR=/home/svu/mpepvs/petsc/petsc-3.7.5 and
>>>>> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with
>>>>> 1 MPI
>>>>> > process
>>>>> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> > mpiexec_atlas7-c10: cannot connect to local mpd
>>>>> (/tmp/mpd2.console_mpepvs);
>>>>> > possible causes:
>>>>> >   1. no mpd is running on this host
>>>>> >   2. an mpd is running but was started without a "console" (-n
>>>>> option)
>>>>> 2 MPI
>>>>> > processes
>>>>> > possible causes:
>>>>> option)
>>>>> > Possible error running Fortran example src/snes/examples/tutorials/ex
>>>>> 5f
>>>>> > with 1 MPI process
>>>>> > possible causes:
>>>>> option)
>>>>> > Completed test examples
>>>>> > Now to evaluate the computer systems you plan use - do:
>>>>> > *Please help on this.*
>>>>> > *Many thanks!*
>>>>> > On Thu, Apr 20, 2017 at 2:02 AM, Satish Balay <balay at mcs.anl.gov>
>>>>> wrote:
>>>>> > > Sorry - should have mentioned:
>>>>> > > do 'rm -rf arch-linux-cxx-opt' and rerun configure again.
>>>>> > > The mpich install from previous build [that is currently in
>>>>> > > arch-linux-cxx-opt/]
>>>>> > > is conflicting with --with-mpi-dir=/app1/centos6.3
>>>>> /gnu/mvapich2-1.9/
>>>>> > > Satish
>>>>> > > On Wed, 19 Apr 2017, Pham Pham wrote:
>>>>> > > > I reconfigured PETSs with installed MPI, however, I got serous
>>>>> error:
>>>>> > > > **************************ERROR*****************************
>>>>> > > >   Error during compile, check arch-linux-cxx-opt/lib/petsc/c
>>>>> onf/make.log
>>>>> > > >   Send it and arch-linux-cxx-opt/lib/petsc/conf/configure.log to
>>>>> > > > petsc-maint at mcs.anl.gov
>>>>> > > > Please explain what is happening?
>>>>> > > > On Wed, Apr 19, 2017 at 11:43 PM, Satish Balay <
>>>>> > > wrote:
>>>>> > > > > Presumably your cluster already has a recommended MPI to use
>>>>> [which is
>>>>> > > > > already installed. So you should use that - instead of
>>>>> > > > > --download-mpich=1
>>>>> > > > > Satish
>>>>> > > > > > Hi,
>>>>> > > > > > I just installed petsc-3.7.5 into my university cluster. When
>>>>> > > evaluating
>>>>> > > > > > the computer system, PETSc reports "It appears you have 1
>>>>> node(s)", I
>>>>> > > > > donot
>>>>> > > > > > understand this, since the system is a multinodes system.
>>>>> Could you
>>>>> > > > > please
>>>>> > > > > > explain this to me?
>>>>> > > > > > S.
>>>>> > > > > > Output:
>>>>> > > > > > streams
>>>>> > > > > > streams
>>>>> > > > > > /home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpicxx
>>>>> -o
>>>>> > > > > > MPIVersion.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>> > > > > > -Wno-unknown-pragmas -fvisibility=hidden -g -O
>>>>> > > > > > -I/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/incl
>>>>> ude
>>>>> > > > > > `pwd`/MPIVersion.c
>>>>> > > > > > '/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpiexec
>>>>> > > > > using
>>>>> > > > > > 'NPMAX=12'
>>>>> > > > > > Number of MPI processes 1 Processor names  atlas7-c10
>>>>> > > > > > Triad:         9137.5025   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 2 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > > Triad:         9707.2815   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 3 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > Triad:        13559.5275   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 4 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > atlas7-c10
>>>>> > > > > > Triad:        14193.0597   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 5 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > atlas7-c10 atlas7-c10
>>>>> > > > > > Triad:        14492.9234   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 6 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > atlas7-c10 atlas7-c10 atlas7-c10
>>>>> > > > > > Triad:        15476.5912   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 7 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
>>>>> > > > > > Triad:        15148.7388   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 8 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> > > > > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
>>>>> > > > > > Triad:        15799.1290   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 9 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > > Triad:        15671.3104   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 10 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > > Triad:        15601.4754   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 11 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > > Triad:        15434.5790   Rate (MB/s)
>>>>> > > > > > Number of MPI processes 12 Processor names  atlas7-c10
>>>>> atlas7-c10
>>>>> atlas7-c10
>>>>> > > > > > Triad:        15134.1263   Rate (MB/s)
>>>>> > > > > > np  speedup
>>>>> > > > > > 1 1.0
>>>>> > > > > > 2 1.06
>>>>> > > > > > 3 1.48
>>>>> > > > > > 4 1.55
>>>>> > > > > > 5 1.59
>>>>> > > > > > 6 1.69
>>>>> > > > > > 7 1.66
>>>>> > > > > > 8 1.73
>>>>> > > > > > 9 1.72
>>>>> > > > > > 10 1.71
>>>>> > > > > > 11 1.69
>>>>> > > > > > 12 1.66
>>>>> Streams
>>>>> > > > > benchmark.
>>>>> > > > > > Unable to plot speedup to a file
>>>>> > > > > > Unable to open matplotlib to plot speedup
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170523/b753448c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170523/b753448c/attachment-0001.png>
