[petsc-users] Problems with PetscObjectViewFromOptions in Fortran
Sat May 20 15:09:55 CDT 2017
> On May 18, 2017, at 5:11 AM, Fabian.Jakub <Fabian.Jakub at physik.uni-muenchen.de> wrote:
> Dear Petsc Team,
> I have a problem with object viewing through PetscObjectViewFromOptions
> The C Version works fine, e.g.
> static char help[] = "Testing multiple PetscObjectViewFromOptions";
> #include <petsc.h>
> int main(int argc,char **argv) {
>  DM dmA, dmB;
>  PetscInitialize(&argc,&argv,(char*)0,help);
>  PetscErrorCode ierr;
>  ierr = DMPlexCreate(PETSC_COMM_WORLD, &dmA); CHKERRQ(ierr);
>  ierr = PetscObjectSetName((PetscObject) dmA, "DMPlex_A"); CHKERRQ(ierr);
>  ierr = DMPlexCreate(PETSC_COMM_WORLD, &dmB); CHKERRQ(ierr);
>  ierr = PetscObjectSetName((PetscObject) dmB, "DMPlex_B"); CHKERRQ(ierr);
>  PetscObjectViewFromOptions((PetscObject) dmA, NULL, "-dmA");
>  PetscObjectViewFromOptions((PetscObject) dmB, NULL, "-dmB");
>  ierr = DMDestroy(&dmA); CHKERRQ(ierr);
>  ierr = DMDestroy(&dmB); CHKERRQ(ierr);
>  PetscFinalize();
> and running it with -help, correctly produces the options and views as:
> -dmA
> -dmB
> but the equivalent in Fortran, e.g.:
> program main
> #include "petsc/finclude/petsc.h"
>      use petsc
>      implicit none
>      PetscErrorCode :: ierr
>      DM :: dmA, dmB
>      call PetscInitialize(PETSC_NULL_CHARACTER, ierr); CHKERRQ(ierr)
>      call DMPlexCreate(PETSC_COMM_WORLD, dmA, ierr);CHKERRQ(ierr)
>      call PetscObjectSetName(dmA, 'DMPlex_A', ierr);CHKERRQ(ierr)
>      call DMPlexCreate(PETSC_COMM_WORLD, dmB, ierr);CHKERRQ(ierr)
>      call PetscObjectSetName(dmB, 'DMPlex_B', ierr);CHKERRQ(ierr)
>      call PetscObjectViewFromOptions(dmA, PETSC_NULL_CHARACTER, "-dmA",
>      call PetscObjectViewFromOptions(dmB, PETSC_NULL_CHARACTER, "-dmB",
  The second argument is a PETScObject, not a character string.  This is what is causing the error. You should replace the PETSC_NULL_CHARACTER with PETSC_NULL_OBJECT in PETSc 3.7.x or earlier or with PETSC_NULL_VEC with the master branch development version of PETSc.
   I have added more error checking to the branch barry/errorcheck-fortran-petscobjectviewfromoptions that will detect this error in the future.
   Thanks for reporting the problem,
   Barry
>      call DMDestroy(dmA, ierr);CHKERRQ(ierr)
>      call DMDestroy(dmB, ierr);CHKERRQ(ierr)
>      call PetscFinalize(ierr)
> end program
> produces the options to be:
> -dmA-dmB
> -dmB
> While this works as expected when running with:
>    ./example -dmA-dmB -dmB
> This is not intuitive.
> Is the hickup on my side or is it somewhere in the Fortran stubs?
> Please, let me know if you need more details on the build or if you
> cannot reproduce this.
> Many thanks,
> Fabian
> Petsc Development GIT revision: v3.7.6-3910-gd04c6f6  GIT Date:
> 2017-05-15 17:09:20 -0500
> ./configure                           \
>  --with-cc=$(which mpicc)            \
>  --with-fc=$(which mpif90)           \
>  --with-cxx=$(which mpicxx)          \
>  --with-fortran                      \
>  --with-fortran-interfaces           \
>  --with-shared-libraries=1           \
>  --download-hdf5                     \
>  --download-triangle                 \
>  --download-ctetgen                  \
>  --with-cmake=$(which cmake)         \
>  --with-debugging=1                  \
>  COPTFLAGS='-O2 ' \
>  FOPTFLAGS='-O2 ' \
>  && make all test
> GNU Fortran (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
> (Open MPI) 1.10.2
> Complete output of -help -info (Fortran Version):
> [0] petscinitialize_internal(): (Fortran):PETSc successfully started:
> procs 1
> [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> met-ws-740m19.(none)
> [0] petscinitialize_internal(): Running on machine: met-ws-740m19
> ------Additional PETSc component options--------
> -log_exclude: <vec,mat,pc.ksp,snes>
> -info_exclude: <null,vec,mat,pc,ksp,snes,ts>
> [0] PetscCommDuplicate(): Duplicating a communicator 47693199447680
> 11260976 max tags = 2147483647
> [0] PetscCommDuplicate(): Using internal PETSc communicator
> 47693199447680 11260976
>  -dmA-dmB ascii[:[filename][:[format][:append]]]: Prints object to
> stdout or ASCII file (PetscOptionsGetViewer)
>    -dmA-dmB binary[:[filename][:[format][:append]]]: Saves object to a
> binary file (PetscOptionsGetViewer)
>    -dmA-dmB draw[:drawtype[:filename]] Draws object (PetscOptionsGetViewer)
>    -dmA-dmB socket[:port]: Pushes object to a Unix socket
>    -dmA-dmB saws[:communicatorname]: Publishes object to SAWs
> DM Object: DMPlex_A 1 MPI processes
>  type: plex
> [0] PetscCommDuplicate(): Duplicating a communicator 47693199449728
> 13799472 max tags = 2147483647
> 47693199449728 13799472
> DMPlex_A in 0 dimensions:
>  0-cells: 0
>  -dmB ascii[:[filename][:[format][:append]]]: Prints object to stdout
> DM Object: DMPlex_B 1 MPI processes
>  type: plex
> DMPlex_B in 0 dimensions:
>  0-cells: 0
> [0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator
> embedded in a user MPI_Comm 13799472
> [0] Petsc_DelComm_Outer(): User MPI_Comm 47693199449728 is being freed
> after removing reference from inner PETSc comm to this outer comm
> [0] PetscCommDestroy(): Deleting PETSc MPI_Comm 13799472
> [0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 13799472
> [0] PetscFinalize(): PetscFinalize() called
> [0] PetscFOpen(): Opening file Log.0
> [0] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm
> 11260976
> embedded in a user MPI_Comm 11260976
> [0] Petsc_DelComm_Outer(): User MPI_Comm 47693199447680 is being freed
> [0] PetscCommDestroy(): Deleting PETSc MPI_Comm 11260976
> [0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm 11260976
