[petsc-users] Understanding log summary
Zhang, Hong hongzhang at anl.gov
Fri May 19 13:53:47 CDT 2017
On May 19, 2017, at 9:25 AM, Zou, Ling <ling.zou at inl.gov<mailto:ling.zou at inl.gov>> wrote:
Hi All,
In terms of code performance, sometimes people would ask for info about total non-linear iteration numbers, total linear iteration numbers, etc. I suppose all these could be found in the log summary. For the attached log summary, can I say?
  total non-linear iteration number = 573
  total linear iteration number = 2321
Usually SNESSolve corresponds to the number of nonlinear iterations in the summary. It seems that you are solving some linear systems with GMRES. And there are 573 linear solves with 2321 GMRES iterations in total.
Hong (Mr.)
Thank you.
Ling
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot               607 1.0 1.8729e-04 1.0 1.95e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1040
VecMDot             2321 1.0 1.1075e-03 1.0 2.87e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   0  5  0  0  0  2590
VecNorm             5422 1.0 1.2229e-03 1.0 1.74e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  1423
VecScale            5822 1.0 1.2764e-03 1.0 9.37e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   734
VecCopy            14334 1.0 1.8302e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              1231 1.0 3.0700e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            14961 1.0 3.3679e-03 1.0 4.82e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  9  0  0  0   0  9  0  0  0  1430
VecWAXPY           20842 1.0 5.5537e-03 1.0 4.00e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0   721
VecMAXPY            2894 1.0 1.4292e-03 1.0 3.62e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0  2536
VecSetRandom          34 1.0 1.0322e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecReduceArith      1146 1.0 2.9907e-04 1.0 3.68e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1230
VecReduceComm        573 1.0 9.2384e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize        2894 1.0 1.9604e-03 1.0 1.39e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0   712
SNESJacobianEval     573 1.0 2.2410e+00 1.0 5.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00 62 11  0  0  0  62 11  0  0  0     2
MatMult MF          2928 1.0 5.7922e-01 1.0 2.83e+06 1.0 0.0e+00 0.0e+00 0.0e+00 16  5  0  0  0  16  5  0  0  0     5
MatMult             2928 1.0 5.7963e-01 1.0 2.83e+06 1.0 0.0e+00 0.0e+00 0.0e+00 16  5  0  0  0  16  5  0  0  0     5
MatSolve            2894 1.0 7.3171e-03 1.0 1.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 33  0  0  0   0 33  0  0  0  2405
MatLUFactorNum       573 1.0 1.4733e-02 1.0 1.71e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 32  0  0  0   0 32  0  0  0  1158
MatILUFactorSym        1 1.0 2.4543e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin    1147 1.0 7.9204e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd      1147 1.0 2.5825e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 6.3280e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.5754e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries       573 1.0 5.7120e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatFDColorCreate       1 1.0 2.0541e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatFDColorSetUp        1 1.0 1.6103e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatFDColorApply      573 1.0 2.2386e+00 1.0 5.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00 62 11  0  0  0  62 11  0  0  0     2
MatFDColorFunc     11460 1.0 2.2264e+00 1.0 1.85e+06 1.0 0.0e+00 0.0e+00 0.0e+00 62  3  0  0  0  62  3  0  0  0     1
MatColoringApply       1 1.0 3.9990e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog      2321 1.0 2.9685e-03 1.0 5.75e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0  1935
KSPSetUp             573 1.0 2.3291e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve             573 1.0 5.0164e-01 1.0 4.50e+07 1.0 0.0e+00 0.0e+00 0.0e+00 14 85  0  0  0  14 85  0  0  0    90
PCSetUp              573 1.0 1.5172e-02 1.0 1.71e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 32  0  0  0   0 32  0  0  0  1124
PCApply             2894 1.0 7.8614e-03 1.0 1.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 33  0  0  0   0 33  0  0  0  2239
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170519/42f31d45/attachment-0001.html>
