[petsc-users] Suggestion for large scale Poisson's solver
Thu May 4 13:00:13 CDT 2017
> On May 4, 2017, at 12:52 PM, Hom Nath Gharti <hng.email at gmail.com> wrote:
> Thanks, Barry. Is there a way to take advantage of the fact that the
> matrix remains same during time steps?
   Yes since you are not changing the matrix it will construct the preconditioner once and just use it forever.
> On Thu, May 4, 2017 at 1:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On May 4, 2017, at 12:10 PM, Hom Nath Gharti <hng.email at gmail.com> wrote:
>>> Dear all,
>>> I am trying to solve a Poisson's equation on the Earth models with the
>>> following information
>>> - Degrees of freedom ~300,000,000
>>> - I use MPIAIJ matrix
>>> - Coefficient matrix is symmetric and doesn't change with time steps
>>> - Need to compute for a large number of time steps
>>> Which solver/preconditioner is the most efficient for this problem? I
>>> would be grateful for your suggestion.
>>   Geometric multigrid is always best if you can use it. If not I would use hypre BoomerAMG, it should have very good convergence.
>>> Thanks,
>>> Hom Nath
