[petsc-users] strange convergence
Hoang Giang Bui hgbk2008 at gmail.com
Wed May 3 16:19:01 CDT 2017
Hi Lukasz, thanks for sharing very interesting slide.
Both of you are right, the mortar method starts from continuum argument
then reduce to discrete space by discretizing the Lagrange multiplier.
However, the way to choose the interpolation space has some implication on
the properties of the mortar matrices. For example, the dual mortar space
can help to reduce the multiplier by static condensation but it creates
some numerical oscillation. In my opinion I think it's not stable despite a
very sound theoretical foundation is developed. Both standard and dual
mortar approach impose some drawbacks for high order contact because of
negative shape function can create some spurious negative nodal gap. How do
you cope with that case in your code?
However, this question may be a bit off-topic. Come back to the main
question, for mesh "gluing" using mortar method, the Schur matrix is S=[0
-D^T M^T] A^-1 [0 D M]^T, has the form of A_10 (A_00)^-1 A01 since A_11=0.
The magnitude of S (~E^-1) is too small compare to A_00 (which is ~E for
elasticity). I think in some case it's also rank deficient if three
Lagrange multiplier is used per node (S is very ill-conditioned although
A_00 is well). I'm skeptical here do you really solve the system of mortar
with schur complement?
Giang
On Wed, May 3, 2017 at 2:55 PM, Lukasz Kaczmarczyk <
Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> On 3 May 2017, at 13:22, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 3, 2017 at 2:29 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote
>> Dear Jed
>> If I understood you correctly you suggest to avoid penalty by using the
>> Lagrange multiplier for the mortar constraint? In this case it leads to the
>> use of discrete Lagrange multiplier space.
> Sorry for being ignorant here, but why is the space "discrete"? It looks
> like you should have a continuum formulation
> of the mortar as well. Maybe I do not understand something fundamental.
> From this (https://en.wikipedia.org/wiki/Mortar_methods)
> short description, it seems that mortars begin from a continuum
> formulation, but are then reduced to the discrete level. This is no
> problem if done consistently, as for instance in the FETI method where
> efficient preconditioners exist.
> Hello,
> I copied the wrong link to mortar method, how we implemented it, see
> presentation http://doi.org/10.5281/zenodo.556996
> You right that we always start from continuum formulation, on this we
> apply some discretisation, at the end Lagrange multiplier is expressed by a
> finite vector of discrete unknowns. It is better to formulate problem first
> for the continuum; you have better control on what you are doing and
> stability of the solution.
> Of course, you can add some constraints at the discreet level, after you
> discretised problem, but implicitly you have some continuous space for
> Lagrange multipliers, which is associated with shape functions which you
> use to discretise problem.
> In our problem which we have,  we try to avoid rebuilding of the system of
> equations each time contact area is changing. We going to construct DM
> sub-problem for each body in contact, each sub-problem going to be solved
> using MG (adjacency for those matrices is fixed in time).  All will go to
> put in nested matrix with the separate block for Lagrange multipliers
> (adjacency will change in each time step).  For solving  Lagrange
> multipliers we going to use FIELDSPLIT using Schur complement. I need to
> look more detail to FETI method, at are still at development stage for
> contact problem and direct solver works, for now, small problems at that
> point.
> In our code, we using higher order elements with hierarchical base,  for
> this we using specialise MG solver, as you can see here, it works pretty
> well for moderate size problems, <100M
> http://mofem.eng.gla.ac.uk/mofem/html/_p_c_m_g_set_up_via_ap
> prox_orders_8cpp.html
> Regards,
> Lukasz
>  Thanks,
>     Matt
>> Do you or anyone already have experience using discrete Lagrange
>> multiplier space with Petsc?
>> There is also similar question on stackexchange
>> https://scicomp.stackexchange.com/questions/25113/preconditi
>> oners-and-discrete-lagrange-multipliers
>> Giang
>> On Sat, Apr 29, 2017 at 3:34 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>>> > Hi Barry
>>> > The first block is from a standard solid mechanics discretization
>>> based on
>>> > balance of momentum equation. There is some material involved but in
>>> > principal it's well-posed elasticity equation with positive definite
>>> > tangent operator. The "gluing business" uses the mortar method to keep
>>> the
>>> > continuity of displacement. Instead of using Lagrange multiplier to
>>> treat
>>> > the constraint I used penalty method to penalize the energy. The
>>> > discretization form of mortar is quite simple
>>> > \int_{\Gamma_1} { rho * (\delta u_1 - \delta u_2) * (u_1 - u_2) dA }
>>> > rho is penalty parameter. In the simulation I initially set it low
>>> (~E) to
>>> > preserve the conditioning of the system.
>>> There are two things that can go wrong here with AMG:
>>> * The penalty term can mess up the strength of connection heuristics
>>>   such that you get poor choice of C-points (classical AMG like
>>>   BoomerAMG) or poor choice of aggregates (smoothed aggregation).
>>> * The penalty term can prevent Jacobi smoothing from being effective; in
>>>   this case, it can lead to poor coarse basis functions (higher energy
>>>   than they should be) and poor smoothing in an MG cycle.  You can fix
>>>   the poor smoothing in the MG cycle by using a stronger smoother, like
>>>   ASM with some overlap.
>>> I'm generally not a fan of penalty methods due to the irritating
>>> tradeoffs and often poor solver performance.
>>> > In the figure below, the colorful blocks are u_1 and the base is u_2.
>>> Both
>>> > u_1 and u_2 use isoparametric quadratic approximation.
>>> > <https://drive.google.com/file/d/0Bw8Hmu0-YGQXc2hKQ1BhQ1I4OE
>>> U/view?usp=drive_web>
>>> > Giang
>>> > On Fri, Apr 28, 2017 at 6:21 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> >>   Ok, so boomerAMG algebraic multigrid is not good for the first
>>> block.
>>> >> You mentioned the first block has two things glued together? AMG is
>>> >> fantastic for certain problems but doesn't work for everything.
>>> >>    Tell us more about the first block, what PDE it comes from, what
>>> >> discretization, and what the "gluing business" is and maybe we'll have
>>> >> suggestions for how to precondition it.
>>> >>    Barry
>>> >> > On Apr 28, 2017, at 3:56 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
>>> wrote:
>>> >> > It's in fact quite good
>>> >> >     Residual norms for fieldsplit_u_ solve.
>>> >> >     0 KSP Residual norm 4.014715925568e+00
>>> >> >     1 KSP Residual norm 2.160497019264e-10
>>> >> >     Residual norms for fieldsplit_wp_ solve.
>>> >> >     0 KSP Residual norm 0.000000000000e+00
>>> >> >   0 KSP preconditioned resid norm 4.014715925568e+00 true resid norm
>>> >> 9.006493082896e+06 ||r(i)||/||b|| 1.000000000000e+00
>>> >> >     0 KSP Residual norm 9.999999999416e-01
>>> >> >     1 KSP Residual norm 7.118380416383e-11
>>> >> >   1 KSP preconditioned resid norm 1.701150951035e-10 true resid norm
>>> >> 5.494262251846e-04 ||r(i)||/||b|| 6.100334726599e-11
>>> >> > Linear solve converged due to CONVERGED_ATOL iterations 1
>>> >> > Giang
>>> >> > On Thu, Apr 27, 2017 at 5:25 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> >> >   Run again using LU on both blocks to see what happens.
>>> >> > > On Apr 27, 2017, at 2:14 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
>>> >> wrote:
>>> >> > > I have changed the way to tie the nonconforming mesh. It seems the
>>> >> matrix now is better
>>> >> > > with -pc_type lu  the output is
>>> >> > >   0 KSP preconditioned resid norm 3.308678584240e-01 true resid
>>> norm
>>> >> > >   1 KSP preconditioned resid norm 2.004313395301e-12 true resid
>>> norm
>>> >> 2.549872332830e-05 ||r(i)||/||b|| 2.831148938173e-12
>>> >> > > with -pc_type fieldsplit  -fieldsplit_u_pc_type hypre
>>> >> -fieldsplit_wp_pc_type lu    the convergence is slow
>>> >> > >   0 KSP preconditioned resid norm 1.116302362553e-01 true resid
>>> norm
>>> >> 9.006493083520e+06 ||r(i)||/||b|| 1.000000000000e+00
>>> >> > >   1 KSP preconditioned resid norm 2.582134825666e-02 true resid
>>> norm
>>> >> 9.268347719866e+06 ||r(i)||/||b|| 1.029073984060e+00
>>> >> > > 824 KSP preconditioned resid norm 1.018542387738e-09 true resid
>>> norm
>>> >> 2.906608839310e+02 ||r(i)||/||b|| 3.227237074804e-05
>>> >> > > 825 KSP preconditioned resid norm 9.743727947637e-10 true resid
>>> norm
>>> >> 2.820369993061e+02 ||r(i)||/||b|| 3.131485215062e-05
>>> >> > > Linear solve converged due to CONVERGED_ATOL iterations 825
>>> >> > > checking with additional  -fieldsplit_u_ksp_type richardson
>>> >> -fieldsplit_u_ksp_monitor -fieldsplit_u_ksp_max_it 1
>>> >> -fieldsplit_wp_ksp_type richardson -fieldsplit_wp_ksp_monitor
>>> >> -fieldsplit_wp_ksp_max_it 1  gives
>>> norm
>>> >> > >     0 KSP Residual norm 5.803507549280e-01
>>> >> > >     1 KSP Residual norm 2.069538175950e-01
>>> norm
>>> >> > >     0 KSP Residual norm 7.831796195225e-01
>>> >> > >     1 KSP Residual norm 1.734608520110e-01
>>> >> > > 823 KSP preconditioned resid norm 1.065070135605e-09 true resid
>>> norm
>>> >> 3.081881356833e+02 ||r(i)||/||b|| 3.421843916665e-05
>>> >> > >     0 KSP Residual norm 6.113806394327e-01
>>> >> > >     1 KSP Residual norm 1.535465290944e-01
>>> >> > > 824 KSP preconditioned resid norm 1.018542387746e-09 true resid
>>> norm
>>> >> 2.906608839353e+02 ||r(i)||/||b|| 3.227237074851e-05
>>> >> > >     0 KSP Residual norm 6.123437055586e-01
>>> >> > >     1 KSP Residual norm 1.524661826133e-01
>>> >> > > 825 KSP preconditioned resid norm 9.743727947718e-10 true resid
>>> norm
>>> >> 2.820369990571e+02 ||r(i)||/||b|| 3.131485212298e-05
>>> >> > > The residual for wp block is zero since in this first step the
>>> rhs is
>>> >> zero. As can see in the output, the multigrid does not perform well to
>>> >> reduce the residual in the sub-solve. Is my observation right? what
>>> can be
>>> >> done to improve this?
>>> >> > > Giang
>>> >> > > On Tue, Apr 25, 2017 at 12:17 AM, Barry Smith <bsmith at mcs.anl.gov
>>> >> wrote:
>>> >> > >    This can happen in the matrix is singular or nearly singular
>>> or if
>>> >> the factorization generates small pivots, which can occur for even
>>> >> nonsingular problems if the matrix is poorly scaled or just plain
>>> nasty.
>>> >> > > > On Apr 24, 2017, at 5:10 PM, Hoang Giang Bui <
>>> >> wrote:
>>> >> > > > It took a while, here I send you the output
>>> >> > > >   0 KSP preconditioned resid norm 3.129073545457e+05 true resid
>>> norm
>>> >> 9.015150492169e+06 ||r(i)||/||b|| 1.000000000000e+00
>>> >> > > >   1 KSP preconditioned resid norm 7.442444222843e-01 true resid
>>> norm
>>> >> 1.003356247696e+02 ||r(i)||/||b|| 1.112966720375e-05
>>> >> > > >   2 KSP preconditioned resid norm 3.267453132529e-07 true resid
>>> norm
>>> >> 3.216722968300e+01 ||r(i)||/||b|| 3.568130084011e-06
>>> >> > > >   3 KSP preconditioned resid norm 1.155046883816e-11 true resid
>>> norm
>>> >> 3.234460376820e+01 ||r(i)||/||b|| 3.587805194854e-06
>>> >> > > > Linear solve converged due to CONVERGED_ATOL iterations 3
>>> >> > > > KSP Object: 4 MPI processes
>>> >> > > >   type: gmres
>>> >> > > >     GMRES: restart=1000, using Modified Gram-Schmidt
>>> >> Orthogonalization
>>> >> > > >     GMRES: happy breakdown tolerance 1e-30
>>> >> > > >   maximum iterations=1000, initial guess is zero
>>> >> > > >   tolerances:  relative=1e-20, absolute=1e-09, divergence=10000
>>> >> > > >   left preconditioning
>>> >> > > >   using PRECONDITIONED norm type for convergence test
>>> >> > > > PC Object: 4 MPI processes
>>> >> > > >   type: lu
>>> >> > > >     LU: out-of-place factorization
>>> >> > > >     tolerance for zero pivot 2.22045e-14
>>> >> > > >     matrix ordering: natural
>>> >> > > >     factor fill ratio given 0, needed 0
>>> >> > > >       Factored matrix follows:
>>> >> > > >         Mat Object:         4 MPI processes
>>> >> > > >           type: mpiaij
>>> >> > > >           rows=973051, cols=973051
>>> >> > > >           package used to perform factorization: pastix
>>> >> > > >   Error :                        3.24786e-14
>>> >> > > >           total: nonzeros=0, allocated nonzeros=0
>>> >> > > >           total number of mallocs used during MatSetValues
>>> calls =0
>>> >> > > >             PaStiX run parameters:
>>> >> > > >               Matrix type :                      Unsymmetric
>>> >> > > >               Level of printing (0,1,2):         0
>>> >> > > >               Number of refinements iterations : 3
>>> >> > > >   Error :                        3.24786e-14
>>> >> > > >   linear system matrix = precond matrix:
>>> >> > > >     type: mpiaij
>>> >> > > >   Error :                        3.24786e-14
>>> >> > > >     total: nonzeros=9.90037e+07, allocated nonzeros=9.90037e+07
>>> >> > > >     total number of mallocs used during MatSetValues calls =0
>>> >> > > >       using I-node (on process 0) routines: found 78749 nodes,
>>> limit
>>> >> used is 5
>>> >> > > >   Error :                        3.24786e-14
>>> >> > > > It doesn't do as you said. Something is not right here. I will
>>> look
>>> >> in depth.
>>> >> > > > Giang
>>> >> > > > On Mon, Apr 24, 2017 at 8:21 PM, Barry Smith <
>>> >> wrote:
>>> >> > > > > On Apr 24, 2017, at 12:47 PM, Hoang Giang Bui <
>>> >> wrote:
>>> >> > > > > Good catch. I get this for the very first step, maybe at that
>>> time
>>> >> the rhs_w is zero.
>>> >> > > >     With the multiplicative composition the right hand side of
>>> the
>>> >> second solve is the initial right hand side of the second solve minus
>>> >> A_10*x where x is the solution to the first sub solve and A_10 is the
>>> lower
>>> >> left block of the outer matrix. So unless both the initial right hand
>>> side
>>> >> has a zero for the second block and A_10 is identically zero the
>>> right hand
>>> >> side for the second sub solve should not be zero. Is A_10 == 0?
>>> >> > > > > In the later step, it shows 2 step convergence
>>> >> > > > >     0 KSP Residual norm 3.165886479830e+04
>>> >> > > > >     1 KSP Residual norm 2.905922877684e-01
>>> >> > > > >     0 KSP Residual norm 2.397669419027e-01
>>> >> > > > >     1 KSP Residual norm 0.000000000000e+00
>>> >> > > > >   0 KSP preconditioned resid norm 3.165886479920e+04 true
>>> resid
>>> >> norm 7.963616922323e+05 ||r(i)||/||b|| 1.000000000000e+00
>>> >> > > > >     0 KSP Residual norm 9.999891813771e-01
>>> >> > > > >     1 KSP Residual norm 1.512000395579e-05
>>> >> > > > >     0 KSP Residual norm 8.192702188243e-06
>>> >> > > > >   1 KSP preconditioned resid norm 5.252183822848e-02 true
>>> resid
>>> >> norm 7.135927677844e+04 ||r(i)||/||b|| 8.960661653427e-02
>>> >> > > >     The outer residual norms are still wonky, the preconditioned
>>> >> residual norm goes from 3.165886479920e+04 to 5.252183822848e-02
>>> which is a
>>> >> huge drop but the 7.963616922323e+05  drops very much less
>>> >> 7.135927677844e+04. This is not normal.
>>> >> > > >    What if you just use -pc_type lu for the entire system (no
>>> >> fieldsplit), does the true residual drop to almost zero in the first
>>> >> iteration (as it should?). Send the output.
>>> >> > > > >     0 KSP Residual norm 6.946213936597e-01
>>> >> > > > >     1 KSP Residual norm 1.195514007343e-05
>>> >> > > > >     0 KSP Residual norm 1.025694497535e+00
>>> >> > > > >   2 KSP preconditioned resid norm 8.785709535405e-03 true
>>> resid
>>> >> norm 1.419341799277e+04 ||r(i)||/||b|| 1.782282866091e-02
>>> >> > > > >     0 KSP Residual norm 7.255149996405e-01
>>> >> > > > >     1 KSP Residual norm 6.583512434218e-06
>>> >> > > > >     0 KSP Residual norm 1.015229700337e+00
>>> >> > > > >   3 KSP preconditioned resid norm 7.110407712709e-04 true
>>> resid
>>> >> norm 5.284940654154e+02 ||r(i)||/||b|| 6.636357205153e-04
>>> >> > > > >     0 KSP Residual norm 3.512243341400e-01
>>> >> > > > >     1 KSP Residual norm 2.032490351200e-06
>>> >> > > > >     0 KSP Residual norm 1.282327290982e+00
>>> >> > > > >   4 KSP preconditioned resid norm 3.482036620521e-05 true
>>> resid
>>> >> norm 4.291231924307e+01 ||r(i)||/||b|| 5.388546393133e-05
>>> >> > > > >     0 KSP Residual norm 3.423609338053e-01
>>> >> > > > >     1 KSP Residual norm 4.213703301972e-07
>>> >> > > > >     0 KSP Residual norm 1.157384757538e+00
>>> >> > > > >   5 KSP preconditioned resid norm 1.203470314534e-06 true
>>> resid
>>> >> norm 4.544956156267e+00 ||r(i)||/||b|| 5.707150658550e-06
>>> >> > > > >     0 KSP Residual norm 3.838596289995e-01
>>> >> > > > >     1 KSP Residual norm 9.927864176103e-08
>>> >> > > > >     0 KSP Residual norm 1.066298905618e+00
>>> >> > > > >   6 KSP preconditioned resid norm 3.331619244266e-08 true
>>> resid
>>> >> norm 2.821511729024e+00 ||r(i)||/||b|| 3.543002829675e-06
>>> >> > > > >     0 KSP Residual norm 4.624964188094e-01
>>> >> > > > >     1 KSP Residual norm 6.418229775372e-08
>>> >> > > > >     0 KSP Residual norm 9.800784311614e-01
>>> >> > > > >   7 KSP preconditioned resid norm 8.788046233297e-10 true
>>> resid
>>> >> norm 2.849209671705e+00 ||r(i)||/||b|| 3.577783436215e-06
>>> >> > > > > Linear solve converged due to CONVERGED_ATOL iterations 7
>>> >> > > > > The outer operator is an explicit matrix.
>>> >> > > > > Giang
>>> >> > > > > On Mon, Apr 24, 2017 at 7:32 PM, Barry Smith <
>>> >> wrote:
>>> >> > > > > > On Apr 24, 2017, at 3:16 AM, Hoang Giang Bui <
>>> >> wrote:
>>> >> > > > > > Thanks Barry, trying with -fieldsplit_u_type lu gives better
>>> >> convergence. I still used 4 procs though, probably with 1 proc it
>>> should
>>> >> also be the same.
>>> >> > > > > > The u block used a Nitsche-type operator to connect two
>>> >> non-matching domains. I don't think it will leave some rigid body
>>> motion
>>> >> leads to not sufficient constraints. Maybe you have other idea?
>>> >> > > > > >     0 KSP Residual norm 3.129067184300e+05
>>> >> > > > > >     1 KSP Residual norm 5.906261468196e-01
>>> >> > > > >     ^^^^ something is wrong here. The sub solve should not be
>>> >> starting with a 0 residual (this means the right hand side for this
>>> sub
>>> >> solve is zero which it should not be).
>>> >> > > > > > FieldSplit with MULTIPLICATIVE composition: total splits = 2
>>> >> > > > >    How are you providing the outer operator? As an explicit
>>> matrix
>>> >> or with some shell matrix?
>>> >> > > > > >   0 KSP preconditioned resid norm 3.129067184300e+05 true
>>> resid
>>> >> norm 9.015150492169e+06 ||r(i)||/||b|| 1.000000000000e+00
>>> >> > > > > >     0 KSP Residual norm 9.999955993437e-01
>>> >> > > > > >     1 KSP Residual norm 4.019774691831e-06
>>> >> > > > > >   1 KSP preconditioned resid norm 5.003913641475e-01 true
>>> resid
>>> >> norm 4.692996324114e+01 ||r(i)||/||b|| 5.205677185522e-06
>>> >> > > > > >     0 KSP Residual norm 1.000012180204e+00
>>> >> > > > > >     1 KSP Residual norm 1.017367950422e-05
>>> >> > > > > >   2 KSP preconditioned resid norm 2.330910333756e-07 true
>>> resid
>>> >> norm 3.474855463983e+01 ||r(i)||/||b|| 3.854461960453e-06
>>> >> > > > > >     0 KSP Residual norm 1.000004200085e+00
>>> >> > > > > >     1 KSP Residual norm 6.231613102458e-06
>>> >> > > > > >   3 KSP preconditioned resid norm 8.671259838389e-11 true
>>> resid
>>> >> norm 3.545103468011e+01 ||r(i)||/||b|| 3.932384125024e-06
>>> >> > > > > >   type: gmres
>>> >> Orthogonalization
>>> divergence=10000
>>> >> > > > > >   type: fieldsplit
>>> splits = 2
>>> >> > > > > >     Solver info for each split is in the following KSP
>>> objects:
>>> >> > > > > >     Split number 0 Defined by IS
>>> >> > > > > >     KSP Object:    (fieldsplit_u_)     4 MPI processes
>>> >> > > > > >       type: richardson
>>> >> > > > > >         Richardson: damping factor=1
>>> >> > > > > >       maximum iterations=1, initial guess is zero
>>> >> > > > > >       tolerances:  relative=1e-05, absolute=1e-50,
>>> >> divergence=10000
>>> >> > > > > >     PC Object:    (fieldsplit_u_)     4 MPI processes
>>> >> > > > > >       type: lu
>>> >> > > > > >               type: mpiaij
>>> >> > > > > >               rows=938910, cols=938910
>>> >> > > > > >       Error :                        3.36878e-14
>>> calls
>>> >> =0
>>> >> > > > > >                   Matrix type :
>>> Unsymmetric
>>> >> > > > > >   Error :                        3.36878e-14
>>> >> > > > > >       Mat Object:      (fieldsplit_u_)       4 MPI processes
>>> >> > > > > >         type: mpiaij
>>> >> > > > > >         rows=938910, cols=938910, bs=3
>>> >> > > > > >   Error :                        3.36878e-14
>>> >> > > > > >   Error :                        3.36878e-14
>>> >> > > > > >         total: nonzeros=8.60906e+07, allocated
>>> calls =0
>>> >> nodes, limit used is 5
>>> >> > > > > >     Split number 1 Defined by IS
>>> >> > > > > >     KSP Object:    (fieldsplit_wp_)     4 MPI processes
>>> >> > > > > >       type: richardson
>>> >> divergence=10000
>>> >> > > > > >     PC Object:    (fieldsplit_wp_)     4 MPI processes
>>> >> > > > > >       type: lu
>>> >> > > > > >               type: mpiaij
>>> >> > > > > >               rows=34141, cols=34141
>>> >> > > > > >                 Error :                        -nan
>>> >> > > > > >   Error :                        -nan
>>> >> > > > > >   Error :                        -nan
>>> MatSetValues
>>> >> calls =0
>>> >> > > > > >                   Matrix type :
>>> Symmetric
>>> >> > > > > >                   Number of refinements iterations : 0
>>> >> > > > > >   Error :                        -nan
>>> >> > > > > >       Mat Object:      (fieldsplit_wp_)       4 MPI
>>> processes
>>> >> > > > > >         type: mpiaij
>>> >> > > > > >         total: nonzeros=485655, allocated nonzeros=485655
>>> calls =0
>>> >> > > > > >           not using I-node (on process 0) routines
>>> >> > > > > >     type: mpiaij
>>> =0
>>> nodes,
>>> >> limit used is 5
>>> >> > > > > > Giang
>>> >> > > > > > On Sun, Apr 23, 2017 at 10:19 PM, Barry Smith <
>>> >> bsmith at mcs.anl.gov> wrote:
>>> >> > > > > > > On Apr 23, 2017, at 2:42 PM, Hoang Giang Bui <
>>> >> hgbk2008 at gmail.com> wrote:
>>> >> > > > > > > Dear Matt/Barry
>>> >> > > > > > > With your options, it results in
>>> >> > > > > > >   0 KSP preconditioned resid norm 1.106709687386e+31 true
>>> >> resid norm 9.015150491938e+06 ||r(i)||/||b|| 1.000000000000e+00
>>> >> > > > > > >     0 KSP Residual norm 2.407308987203e+36
>>> >> > > > > > >     1 KSP Residual norm 5.797185652683e+72
>>> >> > > > > > It looks like Matt is right, hypre is seemly producing
>>> useless
>>> >> garbage.
>>> >> > > > > > First how do things run on one process. If you have similar
>>> >> problems then debug on one process (debugging any kind of problem is
>>> always
>>> >> far easy on one process).
>>> >> > > > > > First run with -fieldsplit_u_type lu (instead of using
>>> hypre) to
>>> >> see if that works or also produces something bad.
>>> >> > > > > > What is the operator and the boundary conditions for u? It
>>> could
>>> >> be singular.
>>> >> > > > > > > 999 KSP preconditioned resid norm 2.920157329174e+12 true
>>> >> resid norm 9.015683504616e+06 ||r(i)||/||b|| 1.000059124102e+00
>>> >> > > > > > >     0 KSP Residual norm 1.533726746719e+36
>>> >> > > > > > >     1 KSP Residual norm 3.692757392261e+72
>>> >> > > > > > > Do you suggest that the pastix solver for the "wp" block
>>> >> encounters small pivot? In addition, seem like the "u" block is also
>>> >> singular.
>>> >> > > > > > > Giang
>>> >> > > > > > > On Sun, Apr 23, 2017 at 7:39 PM, Barry Smith <
>>> >> > > > > > >    Huge preconditioned norms but normal unpreconditioned
>>> norms
>>> >> almost always come from a very small pivot in an LU or ILU
>>> factorization.
>>> >> > > > > > >    The first thing to do is monitor the two sub solves.
>>> Run
>>> >> with the additional options -fieldsplit_u_ksp_type richardson
>>> >> > > > > > > > On Apr 23, 2017, at 12:22 PM, Hoang Giang Bui <
>>> >> > > > > > > > Hello
>>> >> > > > > > > > I encountered a strange convergence behavior that I have
>>> >> trouble to understand
>>> >> > > > > > > > KSPSetFromOptions completed
>>> true
>>> >> > > > > > > >   1 KSP preconditioned resid norm 2.933141742664e+29
>>> true
>>> >> resid norm 9.015152282123e+06 ||r(i)||/||b|| 1.000000198575e+00
>>> >> > > > > > > >   2 KSP preconditioned resid norm 9.686409637174e+16
>>> true
>>> >> resid norm 9.015354521944e+06 ||r(i)||/||b|| 1.000022631902e+00
>>> >> > > > > > > >   3 KSP preconditioned resid norm 4.219243615809e+15
>>> true
>>> >> resid norm 9.017157702420e+06 ||r(i)||/||b|| 1.000222648583e+00
>>> >> > > > > > > > 999 KSP preconditioned resid norm 3.043754298076e+12
>>> true
>>> >> resid norm 9.015425041089e+06 ||r(i)||/||b|| 1.000030454195e+00
>>> >> > > > > > > > 1000 KSP preconditioned resid norm 3.043000287819e+12
>>> true
>>> >> resid norm 9.015424313455e+06 ||r(i)||/||b|| 1.000030373483e+00
>>> >> > > > > > > > Linear solve did not converge due to DIVERGED_ITS
>>> iterations
>>> >> 1000
>>> >> > > > > > > >   type: gmres
>>> >> Orthogonalization
>>> >> divergence=10000
>>> >> > > > > > > >   type: fieldsplit
>>> splits
>>> >> = 2
>>> >> objects:
>>> >> > > > > > > >       type: preonly
>>> >> > > > > > > >       maximum iterations=10000, initial guess is zero
>>> >> divergence=10000
>>> >> > > > > > > >       using NONE norm type for convergence test
>>> >> > > > > > > >       type: hypre
>>> >> > > > > > > >         HYPRE BoomerAMG preconditioning
>>> >> > > > > > > >         HYPRE BoomerAMG: Cycle type V
>>> >> > > > > > > >         HYPRE BoomerAMG: Maximum number of levels 25
>>> >> > > > > > > >         HYPRE BoomerAMG: Maximum number of iterations
>>> PER
>>> >> hypre call 1
>>> >> > > > > > > >         HYPRE BoomerAMG: Convergence tolerance PER hypre
>>> >> call 0
>>> >> > > > > > > >         HYPRE BoomerAMG: Threshold for strong coupling
>>> 0.6
>>> >> > > > > > > >         HYPRE BoomerAMG: Interpolation truncation
>>> factor 0
>>> >> > > > > > > >         HYPRE BoomerAMG: Interpolation: max elements
>>> per row
>>> >> 0
>>> >> > > > > > > >         HYPRE BoomerAMG: Number of levels of aggressive
>>> >> coarsening 0
>>> >> > > > > > > >         HYPRE BoomerAMG: Number of paths for aggressive
>>> >> coarsening 1
>>> >> > > > > > > >         HYPRE BoomerAMG: Maximum row sums 0.9
>>> >> > > > > > > >         HYPRE BoomerAMG: Sweeps down         1
>>> >> > > > > > > >         HYPRE BoomerAMG: Sweeps up           1
>>> >> > > > > > > >         HYPRE BoomerAMG: Sweeps on coarse    1
>>> >> > > > > > > >         HYPRE BoomerAMG: Relax down
>>> >> symmetric-SOR/Jacobi
>>> >> > > > > > > >         HYPRE BoomerAMG: Relax up
>>> >> > > > > > > >         HYPRE BoomerAMG: Relax on coarse
>>> >>  Gaussian-elimination
>>> >> > > > > > > >         HYPRE BoomerAMG: Relax weight  (all)      1
>>> >> > > > > > > >         HYPRE BoomerAMG: Outer relax weight (all) 1
>>> >> > > > > > > >         HYPRE BoomerAMG: Using CF-relaxation
>>> >> > > > > > > >         HYPRE BoomerAMG: Measure type        local
>>> >> > > > > > > >         HYPRE BoomerAMG: Coarsen type        PMIS
>>> >> > > > > > > >         HYPRE BoomerAMG: Interpolation type  classical
>>> processes
>>> >> > > > > > > >         type: mpiaij
>>> >> calls =0
>>> 78749
>>> >> > > > > > > >       type: preonly
>>> >> divergence=10000
>>> >> > > > > > > >       type: lu
>>> >> > > > > > > >               type: mpiaij
>>> pastix
>>> >> > > > > > > >             Error :                        -nan
>>> >> > > > > > > >   Error :                        -nan
>>> >> > > > > > > >             Error :                        -nan
>>> calls =0
>>> >> > > > > > > >                   Matrix type :
>>> >> Symmetric
>>> >> > > > > > > >   Error :                        -nan
>>> processes
>>> >> > > > > > > >         type: mpiaij
>>> nonzeros=485655
>>> >> calls =0
>>> >> > > > > > > >     type: mpiaij
>>> calls =0
>>> >> > > > > > > > The pattern of convergence gives a hint that this
>>> system is
>>> >> somehow bad/singular. But I don't know why the preconditioned error
>>> goes up
>>> >> too high. Anyone has an idea?
>>> >> > > > > > > > Best regards
>>> >> > > > > > > > Giang Bui
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170503/c9a34020/attachment-0001.html>
