[petsc-users] SNES error
Mark Adams mfadams at lbl.gov
Tue May 2 10:10:18 CDT 2017
/Users/markadams/Codes/petsc/arch-macosx-gnu-O/bin/mpiexec -n 1 ./vml
-v_coord_cylinder -x_dm_refine 2 -v_dm_refine 2 -snes_rtol 1.e-6 -snes_stol
1.e-6 -ts_type cn -snes_fd -pc_type lu -ksp_type preonly
-x_petscspace_order 1 -x_petscspace_poly_tensor -v_petscspace_order 1
-v_petscspace_poly_tensor -ts_dt .1 -ts_max_steps 10 -ts_final_time 1e10
-verbose 3 -num_species 1 -snes_monitor -masses 1,2,4 -thermal_temps
30,30,30  -domainv_lo -2,-2 -domainv_hi 2,2 -domainx_lo -12,-12 -domainx_hi
12,12 -E 0,0 -blobx_radius 2 -x_dm_view hdf5:x.h5 -x_vec_view
hdf5:x.h5::append -v_dm_view hdf5:v.h5 -v_vec_view hdf5:v.h5::append
-x_pre_dm_view hdf5:prex.h5 -x_pre_vec_view hdf5:prex.h5::append
-snes_converged_reason -snes_linesearch_monitor -ts_adapt_monitor
main call SetupXDiscretization
main call SetInitialConditionDomain
                VMLViewX DMGetOutputSequenceNumber=-1,
cmd_str=-x_pre_vec_view
  0) species 0: charge density= -2.3940791757186e+00, z-momentum=
 5.9851979392559e-01, energy=  3.2314073646197e-01, thermal-flux=
 2.4419137539877e-01
          0) Normalized: charge density= -2.3940791757186e+00, z momentum=
 5.9851979392559e-01, energy=  3.2314073646197e-01, thermal flux=
 2.4419137539877e-01, local: 64 X cells, 81 X vertices
                VMLViewX DMGetOutputSequenceNumber=0, cmd_str=(null)
        VMLViewV DMGetOutputSequenceNumber=-1
    0 SNES Function norm 4.097052680599e+00
    1 SNES Function norm 1.213148652908e-09
  Nonlinear solve did not converge due to DIVERGED_FUNCTION_COUNT
iterations 1
      TSAdapt none step   0 stage rejected t=0          + 1.000e-01,
nonlinear solve failures 1 greater than current TS allowed
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR:
[0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase
-ts_max_snes_failures or make negative to attempt recovery
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-3659-g699918129c
 GIT Date: 2017-04-26 08:18:35 -0400
[0]PETSC ERROR: ./vml on a arch-macosx-gnu-O named MarksMac-5.local by
markadams Tue May  2 11:04:02 2017
[0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
COPTFLAGS="-O3 -g -mavx2" CXXOPTFLAGS="-O3 -g -mavx2" FOPTFLAGS="-O3 -g
-mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
--download-hypre=1 --download-ml=1 --download-triangle=1
--download-ctetgen=1 --download-p4est=1 --with-x=0 --download-superlu_dist
--download-superlu --download-ctetgen --with-debugging=0 --download-hdf5=1
PETSC_ARCH=arch-macosx-gnu-O --download-chaco --with-viewfromoptions=1
On Mon, May 1, 2017 at 10:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   and
>   -ts_adapt_monitor
> > On May 1, 2017, at 7:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > Run with -snes_converged_reason.
> >    Matt
> > On Mon, May 1, 2017 at 7:14 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I get this SNES failure and I don't understand what the problem is. The
> rtol is 1.e-6 and the first iteration reduces the residual by 9 orders of
> magnitude. Yet, TS is not satisfied. What is going on here?
> > mpiexec -n 1 ./vml -v_coord_cylinder -x_dm_refine 2 -v_dm_refine 2
> -snes_rtol 1.e-6 -snes_stol 1.e-6 -ts_type cn -snes_fd -pc_type lu
> -ksp_type preonly -x_petscspace_order 1 -x_petscspace_poly_tensor
> -v_petscspace_order 1 -v_petscspace_poly_tensor -ts_dt .1 -ts_max_steps 10
> -ts_final_time 1e10 -verbose 3 -num_species 1 -snes_monitor -masses 1,2,4
> -thermal_temps 30,30,30  -domainv_lo -2,-2 -domainv_hi 2,2 -domainx_lo
> -12,-12 -domainx_hi 12,12 -E 0,0 -blobx_radius 2 -x_dm_view hdf5:x.h5
> -x_vec_view hdf5:x.h5::append -v_dm_view hdf5:v.h5 -v_vec_view
> hdf5:v.h5::append -x_pre_dm_view hdf5:prex.h5 -x_pre_vec_view
> > [0]PETSC ERROR:
> increase -ts_max_snes_failures or make negative to attempt recovery
> for trouble shooting.
> markadams Mon May  1 19:21:32 2017
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170502/1c86239c/attachment-0001.html>
