[petsc-users] Correlation between da_refine and pg_mg_levels
Jed Brown jed at jedbrown.org
Fri Mar 31 10:00:25 CDT 2017
Justin Chang <jychang48 at gmail.com> writes:
> Yeah based on my experiments it seems setting pc_mg_levels to $DAREFINE + 1
> has decent performance.
> 1) is there ever a case where you'd want $MGLEVELS <= $DAREFINE? In some of
> the PETSc tutorial slides (e.g., http://www.mcs.anl.gov/
> petsc/documentation/tutorials/TutorialCEMRACS2016.pdf on slide 203/227)
> they say to use $MGLEVELS = 4 and $DAREFINE = 5, but when I ran this, it
> was almost twice as slow as if $MGLEVELS >= $DAREFINE
Smaller coarse grids are generally more scalable -- when the problem
data is distributed, multigrid is a good solution algorithm.  But if
multigrid stops being effective because it is not preserving sufficient
coarse grid accuracy (e.g., for transport-dominated problems in
complicated domains) then you might want to stop early and use a more
robust method (like direct solves).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170331/7834fe77/attachment.pgp>
