[petsc-users] Slepc JD and GD converge to wrong eigenpair
Toon Weyens toon.weyens at gmail.com
Thu Mar 30 02:27:18 CDT 2017
Hi, thanks for the answer.
I use MUMPS as a PC. The
options -ksp_converged_reason, -ksp_monitor_true_residual and -ksp_view
 are not used.
The difference between the log_view outputs of running a simple solution
with 1, 2, 3 or 4 MPI procs is attached (debug version).
I can see that with 2 procs it takes about 22 seconds, versus 7 seconds for
1 proc. For 3 and 4 the situation is worse: 29 and 37 seconds.
Looks like the difference is mainly in the BVmult and especially in the
BVorthogonalize routines:
BVmult takes 1, 6.5, 10 or even a whopping 17 seconds for the different
number of proceses
BVorthogonalize takes 1, 4, 6, 10.
Calculating the preconditioner does not take more time for different number
of proceses, and applying it only slightly increases. So it cannot be
mumps' fault...
Does this makes sense? Is there any way to improve this?
Thanks!
On Wed, Mar 29, 2017 at 3:20 PM Matthew Knepley <knepley at gmail.com> wrote:
On Wed, Mar 29, 2017 at 6:58 AM, Toon Weyens <toon.weyens at gmail.com> wrote:
Dear Jose,
Thanks for the answer. I am looking for the smallest real, indeed.
I have, just now, accidentally figured out that I can get correct
convergence by increasing NCV to higher values, so that's covered! I
thought I had checked this before, but apparently not. It's converging well
now, and rather fast (still about 8 times faster than Krylov-Schur).
The issue now is that it scales rather badly: If I use 2 or more MPI
processes, the time required to solve it goes up drastically. A small test
case, on my Ubuntu 16.04 laptop, takes 10 seconds (blazing fast) for 1 MPI
process, 25 for 2, 33 for 3, 59 for 4, etc... It is a machine with 8 cores,
so i don't really understand why this is.
For any scalability question, we need to see the output of
  -log_view -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
and other EPS options which I forget unfortunately. What seems likely here
is that you
are using a PC which is not scalable, so iteration would be going up.
     Matt
Are there other methods that can actually maintain the time required to
solve for multiple MPI process? Or, preferable, decrease it (why else would
I use multiple processes if not for memory restrictions)?
I will never have to do something bigger than a generalized non-Hermitian
ev problem of, let's say, 5000 blocks of 200x200 complex values per block,
and a band size of about 11 blocks wide (so a few GB per matrix max).
Thanks so much!
On Wed, Mar 29, 2017 at 9:54 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 29 mar 2017, a las 9:08, Toon Weyens <toon.weyens at gmail.com> escribió:
> I started looking for alternatives from the standard Krylov-Schur method
to solve the generalized eigenvalue problem Ax = kBx in my code. These
matrices have a block-band structure (typically 5, 7 or 9 blocks wide, with
block sizes of the order 20) of size typically 1000 blocks. This eigenvalue
problem results from the minimization of the energy of a perturbed
plasma-vacuum system in order to investigate its stability. So far, I've
not taken advantage of the Hermiticity of the problem.
> For "easier" problems, especially the Generalized Davidson method
converges like lightning, sometimes up to 100 times faster than
Krylov-Schur.
> However, for slightly more complicated problems, GD converges to the
wrong eigenpair: There is certainly an eigenpair with an eigenvalue lower
than 0 (i.e. unstable), but the solver never gets below some small,
positive value, to which it wrongly converges.
I would need to know the settings you are using. Are you doing
smallest_real? Maybe you can try target_magnitude with harmonic extraction.
> Is it possible to improve this behavior? I tried changing the
preconditioner, but it did not work.
> Might it be possible to use Krylov-Schur until reaching some precision,
and then switching to JD to quickly converge?
Yes, you can do this, using EPSSetInitialSpace() in the second solve. But,
depending on the settings, this may not buy you much.
Jose
> Thanks!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170330/c8c73b91/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170330/c8c73b91/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170330/c8c73b91/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170330/c8c73b91/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170330/c8c73b91/attachment-0007.obj>
