[petsc-users] CMake and PETSc
Jed Brown jed at jedbrown.org
Mon Mar 27 22:02:47 CDT 2017
Hom Nath Gharti <hng.email at gmail.com> writes:
> Thanks, Jed! I will try. I see that FindPETSc.cmake has following lines:
> set(PETSC_VALID_COMPONENTS
> C
> CXX)
> Should we add FC or similar?
You could, but then you'd have to also add test code for that language
binding.  (All this does is a test for whether the library works when
called from that language.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170327/c66bef0a/attachment.pgp>
