[petsc-users] Slepc: Computing first 4 smallest eigenvalues and eigenvectors of a large graph Laplacian
Bodhisatta Pramanik bodhi91 at iastate.edu
Sun Mar 26 14:44:36 CDT 2017
*The flop rate for the MatMult and MatSolve are much lower than I would
expect. Try using the AIJ matrix instead of SBAIJ.*
SeqAIJ:
      MatMult = 213 Mflop/s
      MatSolve = 204 Mflop/s
AIJ:
      MatMult = 211 Mflop/s
      MatSolve = 198 Mflop/s
SBAIJ:
     MatMult = 179 Mflop/s
     MatSolve = 167 Mflop/s
Shouldn't the SBAIJ provide the best performance since it only works with
the upper triangular part of the whole large sparse symmetric matrix?
Bodhi
> > On Mar 26, 2017, at 6:25 AM, Bodhisatta Pramanik <bodhi91 at iastate.edu>
> wrote:
> > *First set a new PETSC_ARCH say arch-opt and ./configure with the
> additional argument --with-debugging=0 then recompile PETSc with the new
> PETSC_ARCH and recompile your code then send the new -log_view output.*
> >    I have attached the new log summary with this file. The computation
> time is a lot faster now. It takes around 23 seconds to compute the first 3
> eigenvectors of a 200K sized matrix.
> > Thanks,
> > Bodhi
> > On Sun, Mar 26, 2017 at 3:14 AM, Bodhisatta Pramanik <
> bodhi91 at iastate.edu> wrote:
> > *The error is in EPSComputeError(), not in EPSSolve(). Did you modify
> the state of the EPS object between EPSSolve() and EPSComputeError()?*
> > I am not modifying the eps object. I have copied a part of the code
> where I am computing the eigenvectors.
> >         EPSCreate(PETSC_COMM_WORLD,&eps);
> >         EPSSetOperators(eps,m.Lpl,NULL);
> >         EPSSetProblemType(eps,EPS_HEP);
> >         EPSSetFromOptions(eps);
> >         EPSSolve(eps);  //Solving for the eigenvalues
> >         EPSGetIterationNumber(eps,&its);
> >         PetscPrintf(PETSC_COMM_WORLD,"Number of iterations of the
> method: %D\n",its);
> >         EPSGetType(eps,&type);
> >         PetscPrintf(PETSC_COMM_WORLD,"Solution Method: %s\n\n",type);
> >         EPSGetTolerances(eps,&get_tol,&maxit);
> >         PetscPrintf(PETSC_COMM_WORLD,"Stopping condition: tol=%.4g,
> maxit=%D\n",(double)get_tol,maxit);
> >         EPSGetConverged(eps,&nconv);
> >         PetscPrintf(PETSC_COMM_WORLD, "Number of converged eigenpairs:
> %D\n\n",nconv);
> >         if(nconv>0)
> >                         "       k       ||Ax-kx||/||kx||\n"
> >                         "-------------- ----------------\n");
> >                 for(i=0;i<nconv;i++)
> >                         EPSGetEigenpair(eps,i,&kr,&ki,xr,xi);
> >                         EPSComputeError(eps,i,EPS_
> ERROR_RELATIVE,&error);
> >                         re = PetscRealPart(kr);
> >                         im = PetscImaginaryPart(kr);
> >                         re = kr;
> >                         im = ki;
> >                         if(im!=0.0) {
> >                                 PetscPrintf(PETSC_COMM_WORLD," %9f%+9fi
> %12g\n",(double)re,(double)im,(double)error);
> >                         else {
> >                                 PetscPrintf(PETSC_COMM_WORLD,"     %12f
>   %12g\n",(double)re,(double)error);
> >                 PetscPrintf(PETSC_COMM_WORLD,"\n");
> >         EPSDestroy(&eps);
> >         VecDestroy(&xr);
> >         VecDestroy(&xi);
> > This is what I pass through my command line:
> > ./RunPart -eps_type jd -eps_nev 3 -st_ksp_type cg -st_ksp_rtol 0.001
> -eps_tol 0.001 -st_pc_type bjacobi -eps_smallest_real
> > *In graph partitioning, I would strongly recommend deflating the
> eigenvector corresponding to the zero eigenvalue, as is done in ex11.c:*
> >         I have tried doing this but for some reason the eigenvalues fail
> to converge.
> > On Sun, Mar 26, 2017 at 2:41 AM, Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > El 26 mar 2017, a las 6:08, Bodhisatta Pramanik <bodhi91 at iastate.edu>
> escribió:
> > > Send all the output in the error message:
> > > [0]PETSC ERROR: --------------------- Error Message
> > > [0]PETSC ERROR: Object is in wrong state
> > > [0]PETSC ERROR: Must call EPSSolve() first: Parameter #1
> > > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
> documentation/faq.html for trouble shooting.
> > > [0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
> > > [0]PETSC ERROR: ./RunPart on a arch-linux2-c-debug named
> research-5.ece.iastate.edu by bodhi91 Sat Mar 25 22:33:56 2017
> > > [0]PETSC ERROR: Configure options --with-cc=gcc --with-css=g++
> -with-fc=gfortran --download-fblaslapack --download-mpich
> > > [0]PETSC ERROR: #10468 EPSComputeError() line 643 in
> /tmp/Bodhi/slepc-3.7.3/src/eps/interface/epssolve.c
> > >          0.000000     2.0795e-317
> > The error is in EPSComputeError(), not in EPSSolve(). Did you modify the
> > http://slepc.upv.es/documentation/current/src/eps/
> examples/tutorials/ex11.c.html
> > Jose
> > Bodhisatta Pramanik,
> > Graduate Student,
> > Department of Electrical and Computer Engineering,
> > 301 Durham,
> > Iowa State University,
> > Ames,Iowa 50011,
> > 515-735-6300
> > Graduate Student,
> > 301 Durham,
> > Ames,Iowa 50011,
> > 515-735-6300
> > <New Log Summary>
*Bodhisatta Pramanik,*
*Graduate Student,*
*Department of Electrical and Computer Engineering,*
*301 Durham,*
*Iowa State University,*
*Ames,Iowa 50011,*
*515-735-6300*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170326/4c7c4f99/attachment.html>
