[petsc-users] Configure nested PCFIELDSPLIT with general index sets
Wed Mar 22 06:33:23 CDT 2017
On Wed, Mar 22, 2017 at 10:03 AM, Natacha BEREUX <natacha.bereux at gmail.com>
wrote:
> Hello,
> if my understanding is correct, the approach proposed by Matt and Lawrence
> is the following :
> - create a DMShell (DMShellCreate)
> - define my own CreateFieldDecomposition to return the index sets I need
> (for displacement, pressure and temperature degrees of freedom) :
> myCreateFieldDecomposition(... )
> - set it in the DMShell ( DMShellSetCreateFieldDecomposition)
> - then sets  the DM in KSP context  (KSPSetDM)
> I  have some more questions
> - I did not succeed in setting my own CreateFieldDecomposition in the
> DMShell : link  fails with " unknown reference to «
> dmshellsetcreatefielddecomposition_ ». Could it be a Fortran problem (I
> am using Fortran)?  Is this routine available in PETSc  Fortran interface ?
Yes, exactly. The Fortran interface for passing function pointers is
complex, and no one has added this function yet.
> - CreateFieldDecomposition is supposed to return an array of dms (to
> define the fields). I am not able to return such datas.  Do I return a
> PETSC_NULL_OBJECT instead ?
Yes.
> - do I have to provide something else to define the DMShell ?
I think you will have to return local and global vectors, but this just
means creating a vector of the correct size and distribution.
     Matt
> Thanks a lot for your help
> Natacha
> On Tue, Mar 21, 2017 at 2:44 PM, Natacha BEREUX <natacha.bereux at gmail.com>
> wrote:
>> Thanks for your quick answers. To be honest, I am not familiar at all
>> with DMShells and DMPlexes. But since it is what I need, I am going to try
>> it.
>> Thanks again  for your advices,
>> Natacha
>> On Tue, Mar 21, 2017 at 2:27 PM, Lawrence Mitchell <
>> lawrence.mitchell at imperial.ac.uk> wrote:
>>> > On 21 Mar 2017, at 13:24, Matthew Knepley <knepley at gmail.com> wrote:
>>> > I think the remedy is as easy as specifying a DMShell that has a
>>> PetscSection (DMSetDefaultSection) with your ordering, and
>>> > I think this is how Firedrake (http://www.firedrakeproject.org/) does
>>> it.
>>> We actually don't use a section, but we do provide
>>> DMCreateFieldDecomposition_Shell.
>>> If you have a section that describes all the fields, then I think if the
>>> DMShell knows about it, you effectively get the same behaviour as DMPlex
>>> (which does the decomposition in the same manner?).
>>> > However, I usually use a DMPlex which knows about my
>>> > mesh, so I am not sure if this strategy has any holes.
>>> I haven't noticed anything yet.
>>> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170322/c5a18ea8/attachment-0001.html>
