[petsc-users] Values of a column in a parallel matrix
Jed Brown jed at jedbrown.org
Mon Mar 20 21:40:57 CDT 2017
"Daralagodu Dattatreya Jois, Sathwik Bharadw" <sdaralagodudatta at wpi.edu>
writes:
>  I am using AIJ matrix to solve Laplace problem in finite element
>  framework. To apply Neumann boundary conditions I need to obtain
>  values of first and last few columns and subtract it with the
>  corresponding right hand side vector. I understand that
>  MatGetColumnVector and MatGetValues are not collective. Is there any
>  other alternative petsc calls to achieve this in parallel?
Inhomogeneous Neumann conditions are normally applied by integration
over the boundary.  But if you need a linear combination of some columns
of the matrix, that's a MatMult.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170320/9ee0dc77/attachment.pgp>
