[petsc-users] How to determine a reasonable relative tolerance to iteratively solve a linear system of equations?
Fangbo Wang fangbowa at buffalo.edu
Tue Mar 14 20:46:58 CDT 2017
it is a solid mechanics problem.
On Tue, Mar 14, 2017 at 6:42 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 14, 2017, at 5:32 PM, Fangbo Wang <fangbowa at buffalo.edu> wrote:
> > Hi,
> > I know this is not a problem specific to PETSc, but I have this doubt
> for a long time and want to ask the experts here.
> > Suppose I have a very large linear system of equations with 1.5 million
> unkowns. It is common to use relative tolerance as a stopping criteria.
> > For a small linear system, I usually use 1e-6, or 1e-8, or 1e-10, etc.
> But for a very large linear system, do I need to use a relative tolerance
> much smaller than the previous I use? (Theoretically I think the relative
> tolerance has nothing related to system size).
> > However, something very weird happens. I used 1e-7 as my relative
> tolerance for my linear system  with 1.5 million unknows using conjugate
> gradient method with jacobi preconditioner, the solver can not converge to
> 1e-7 with 10,000 iterations. I can use a larger tolerance but the solution
> is not good.
>    This is not particularly weird. Jacobi preconditioning can perform very
> poorly depending on the structure of your matrix.
>    So first you need a better preconditioner. Where does the matrix come
> from? This helps determine what preconditioner to use. For example, is it a
> pressure solve, a structural mechanics problem, a Stokes-like problem, a
> fully implicit cdf problem.
>    Barry
> > Any one have some  advices? Thank you very much!
> > Best regards,
> > Fangbo Wang
> > Fangbo Wang, PhD student
> > Stochastic Geomechanics Research Group
> > Department of Civil, Structural and Environmental Engineering
> > University at Buffalo
> > Email: fangbowa at buffalo.edu
Email: *fangbowa at buffalo.edu <fangbowa at buffalo.edu>*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170314/ab4a30f1/attachment.html>
