[petsc-users] block ILU(K) is slower than the point-wise version?
Kong, Fande fande.kong at inl.gov
Mon Mar 6 17:44:00 CST 2017
Thanks, Barry,
Log info:
AIJ:
MatSolve             850 1.0 8.6543e+00 4.2 3.04e+09 1.8 0.0e+00 0.0e+00
0.0e+00  0 41  0  0  0   0 41  0  0  0 49594
MatLUFactorNum        25 1.0 1.7622e+00 2.0 2.04e+09 2.1 0.0e+00 0.0e+00
0.0e+00  0 26  0  0  0   0 26  0  0  0 153394
MatILUFactorSym       13 1.0 2.8002e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BAIJ:
MatSolve             826 1.0 1.3016e+01 1.7 1.42e+10 1.8 0.0e+00 0.0e+00
0.0e+00  1 29  0  0  0   1 29  0  0  0 154617
MatLUFactorNum        25 1.0 1.5503e+01 2.0 3.55e+10 2.1 0.0e+00 0.0e+00
0.0e+00  1 67  0  0  0   1 67  0  0  0 303190
MatILUFactorSym       13 1.0 5.7561e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
It looks like both MatSolve and MatLUFactorNum are slower.
I will try your suggestions.
Fande
On Mon, Mar 6, 2017 at 4:14 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Note also that if the 11 by 11 blocks are actually sparse (and you don't
> store all the zeros in the blocks in the AIJ format) then then AIJ
> non-block factorization involves less floating point operations and less
> memory access so can be faster than the BAIJ format, depending on "how
> sparse" the blocks are. If you actually "fill in" the 11 by 11 blocks with
> AIJ (with zeros maybe in certain locations) then the above is not true.
> > On Mar 6, 2017, at 5:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   This is because for block size 11 it is using calls to LAPACK/BLAS for
> the block operations instead of custom routines for that block size.
> >   Here is what you need to do. For a good sized case run both with
> -log_view and check the time spent in
> > MatLUFactorNumeric, MatLUFactorSymbolic and in MatSolve for AIJ and
> BAIJ. If they have a different number of function calls then divide by the
> function call count to determine the time per function call.
> >   This will tell you which routine needs to be optimized first either
> MatLUFactorNumeric or MatSolve. My guess is MatSolve.
> >   So edit src/mat/impls/baij/seq/baijsolvnat.c and copy the function
> MatSolve_SeqBAIJ_15_NaturalOrdering_ver1() to a new function
> MatSolve_SeqBAIJ_11_NaturalOrdering_ver1. Edit the new function for the
> block size of 11.
> >   Now edit MatLUFactorNumeric_SeqBAIJ_N() so that if block size is 11 it
> uses the new routine something like.
> > if (both_identity) {
> >   if (b->bs == 11)
> >    C->ops->solve = MatSolve_SeqBAIJ_11_NaturalOrdering_ver1;
> >   } else {
> >    C->ops->solve = MatSolve_SeqBAIJ_N_NaturalOrdering;
> >   Rerun and look at the new -log_view. Send all three -log_view to use
> at this point.  If this optimization helps and now
> > MatLUFactorNumeric is the time sink you can do the process to
> MatLUFactorNumeric_SeqBAIJ_15_NaturalOrdering() to make an 11 size block
> custom version.
> >  Barry
> >> On Mar 6, 2017, at 4:32 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> >> On Mon, Mar 6, 2017 at 3:27 PM, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> >> On Mon, Mar 6, 2017 at 1:48 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> >>> Hi All,
> >>> I am solving a nonlinear system whose Jacobian matrix has a block
> structure.
> >>> More precisely, there is a mesh, and for each vertex there are 11
> variables
> >>> associated with it. I am using BAIJ.
> >>> I thought block ILU(k) should be more efficient than the point-wise
> ILU(k).
> >>> After some numerical experiments, I found that the block ILU(K) is much
> >>> slower than the point-wise version.
> >> Do you mean that it takes more iterations to converge, or that the
> >> time per iteration is greater, or both?
> >> The number of iterations is very similar, but the timer per iteration
> is greater.
> >>> Any thoughts?
> >>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170306/26452561/attachment.html>
