[petsc-users] petsc4py and MPI.COMM_SELF.Spawn
Rodrigo Felicio Rodrigo.Felicio at iongeo.com
Wed Mar 1 11:40:36 CST 2017
Thanks, Barry and Matt, for your prompt responses. I really appreciated them.
Sorry I forgot to mention that I am using petsc 3.6.1, petsc4py 3.6.0 and mpi4py 2.0.0. (and also tested with mpi4py 1.2.2)
from running env I get:
PYTHONPATH=/home/XXXXX/Enthought/Canopy_64bit/User/lib/python2.7/site-packages:/home/XXXXX/dev/myPy:/home/XXXXX/ipnotebooks
and also
PETSC_DIR=/home/XXXXX/mylocal/petsc-3.6.1
PETSC_ARCH=arch-linux2-c
I_MPI_ROOT=/apps/tools/centos54-x86_64-intel14//impi/4.1.3.04
Funny thing is that  only inside a python session I see the directory where both petsc4py and mpi4py are installed in the python path, i.e.,
only after
import sys
sys.path
I see  '/home/XXXX/.local/lib/python2.7/site-packages'
Anyway, after running
time mpirun -n 1 python ./dyn_mem_ex.py
I get the error msg  (once I killed the process running dyn_mem_ex.py. Mind you I edited out the the IP of the machine with XXX.XX.XX.XX)
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 15
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Fatal error in PMPI_Init_thread: Invalid port, error stack:
MPIR_Init_thread(674).....:
MPID_Init(320)............: spawned process group was unable to connect back to the parent on port <tag#0$description#v1n29$port#51319$ifname#XXX.XX.XX.XX$>
MPID_Comm_connect(206)....:
MPIDI_Comm_connect(579)...: Named port tag#0$description#v1n29$port#51319$ifname#XXX.XX.XX.XX$ does not exist
MPIDI_Comm_connect(415)...:
dequeue_and_set_error(628): Communication error with rank 0
MPIR_Init_thread(674)..:
MPID_Init(320).........: spawned process group was unable to connect back to the parent on port <tag#0$description#v1n29$port#51319$ifname#XXX.XX.XX.XX$>
MPID_Comm_connect(206).:
MPIDI_Comm_connect(432): Named port tag#0$description#v1n29$port#51319$ifname#XXX.XX.XX.XX$ does not exist
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
real    0m9.987s
user    0m36.714s
sys     0m11.541s
if I comment out the lines that import PETSc and initialize petsc4py on the code for the cpi.py (codes attached below)
import pestc4py
#petsc4py.init(sys.argv)
#from petsc4py import PETSc
from mpi4py import MPI
Then it runs without problems and the output is
proc 2 of 4
proc 3 of 4 proc 1 of 4
proc 0 of 4
proc 0 of 4, Adim=[10]
proc 1 of 4, Adim=[10]
proc 2 of 4, Adim=[10]
proc 3 of 4, Adim=[10]
Adata = [ 0.  1.  2.  3.  4.  5.  6.  7.  8.  9.]Adata = [ 0.  1.  2.  3.  4.  5.  6.  7.  8.  9.]
3.14160098692
2.65258238441e-06
real    0m0.535s
user    0m0.431s
sys     0m0.633s
the codes that I used in this example,  have just minor modifications compared to old examples from petsc4py. For reference, I am also attaching them
# dyn_mem_ex.py
import numpy
import sys
import petsc4py
mypath = '/home/XXX/study/mpi4py/'
comm = MPI.COMM_SELF.Spawn(sys.executable,
                           args=[mypath + 'cpi.py'],
                           maxprocs=4)
N = numpy.array(100, 'i')
Adata = numpy.array(numpy.arange(10), dtype='f')
Adim = numpy.array(Adata.shape[0], dtype='i')
comm.Bcast([N, MPI.INT], root=MPI.ROOT)
comm.Bcast([Adim, MPI.INT], root=MPI.ROOT)
comm.Bcast([Adata, MPI.FLOAT], root=MPI.ROOT)
PI = numpy.array(0.0, 'd')
comm.Reduce(None, [PI, MPI.DOUBLE],
            op=MPI.SUM, root=MPI.ROOT)
print(PI)
print(PI/numpy.pi - 1.0)
comm.Disconnect()
# cpi.py
import numpy
import sys, petsc4py
parent = MPI.Comm.Get_parent()
size = parent.Get_size()
rank = parent.Get_rank()
print("proc {} of {} ".format(rank, size))
N = numpy.array(0, dtype='i')
Adim = numpy.zeros(1, dtype='i')
parent.Bcast([N, MPI.INT], root=0)
parent.Bcast([Adim, MPI.INT], root=0)
Adata = numpy.zeros(Adim[0], dtype='f')
parent.Bcast([Adata, MPI.FLOAT],root=0)
print("proc {} of {}, Adim={}".format(rank, size, Adim))
print("Adata = {}".format(Adata))
h = 1.0 / N; s = 0.0
for i in range(rank, N, size):
    x = h * (i + 0.5)
    #print(rank,size,Adim.shape)
    s += 4.0 / (1.0 + x**2)
PI = numpy.array(s * h, dtype='d')
parent.Reduce([PI, MPI.DOUBLE], None,
            op=MPI.SUM, root=0)
parent.Disconnect()
kind regards,
Rodrigo
This email and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you are not the original recipient or the person responsible for delivering the email to the intended recipient, be advised that you have received this email in error, and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. If you received this email in error, please immediately notify the sender and delete the original.
