[petsc-users] Building petsc4py / mpi4py
Mon Jan 23 09:22:56 CST 2017
Looks like --download-petsc4py [and --download-mpi4py] uses python
from PATH - and not the one used by configure.
'mpi4py-1.3.1-py3.6.egg-info' suggests that default 'python' in PATH is python-3.6. So try:
python RBF_Load.py
Should we use the same python for configure and all external python packages?
[petsc configure is limited to python2 - but petsc4py works with python3]
How about other externalpackages that use python? [scientificpython.py etc..
Satish
On Mon, 23 Jan 2017, Florian Lindner wrote:
> Hello,
> I try to build petsc from the maint branch together with petsc4py and mpi4py
> python2 configure --download-petsc4py=yes --download-mpi4py=yes --with-mpi4py=yes --with-petsc4py=yes --with-debugging=1
> make
> works without errors, so does make test.
> % echo $PYTHONPATH
> /home/florian/software/petsc/arch-linux2-c-debug/lib
> % ls $PYTHONPATH
> libpetsc.so  libpetsc.so.3.7  libpetsc.so.3.7.5  mpi4py  mpi4py-1.3.1-py3.6.egg-info  petsc  petsc4py
> petsc4py-3.7.0-py3.6.egg-info  pkgconfig
> but:
> % python2 RBF_Load.py
> Traceback (most recent call last):
>   File "RBF_Load.py", line 10, in <module>
>     petsc4py.init(sys.argv)
>   File "/home/florian/software/petsc/arch-linux2-c-debug/lib/petsc4py/__init__.py", line 42, in init
>     PETSc = petsc4py.lib.ImportPETSc(arch)
>   File "/home/florian/software/petsc/arch-linux2-c-debug/lib/petsc4py/lib/__init__.py", line 29, in ImportPETSc
>     return Import('petsc4py', 'PETSc', path, arch)
>   File "/home/florian/software/petsc/arch-linux2-c-debug/lib/petsc4py/lib/__init__.py", line 63, in Import
>     fo, fn, stuff = imp.find_module(name, pathlist)
> ImportError: No module named PETSc
> Anyone having an idea what could be the problem here?
> I have also attached the configure.log
> Best,
> Florian
