[petsc-users] About GMRES Solver in PETSc
Chih-Hao Chen chih-hao.chen2 at mail.mcgill.ca
Wed Jan 18 14:32:30 CST 2017
Hello,
Thanks for the quick reply.
So if I specify matrix A and RHS vector b in parallel forms,
ie. having them distributed across several cores,
when I using the functions like MatMult, VecAYPX and etc.,
all the operations would be executed in parallel too?
Thanks very much.
Best,
Chih-Hao
Sent: 18 January 2017 15:24:41
To: Chih-Hao Chen
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] About GMRES Solver in PETSc
Yes.
Hong
On Wed, Jan 18, 2017 at 2:22 PM, Chih-Hao Chen <chih-hao.chen2 at mail.mcgill.ca<mailto:chih-hao.chen2 at mail.mcgill.ca>> wrote:
Hello,
Sorry for this bother.
I"ve checked  GMRES solver in your libary supports parallel computing in your website:
http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html.<http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html>
Summary of Sparse Linear Solvers Available from PETSc<http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html>
www.mcs.anl.gov<http://www.mcs.anl.gov>
Summary of Sparse Linear Solvers Available from PETSc Requests and contributions welcome
As we all know the key algorithm inside GMRES solver is Gram-Schmidt process,
so I guess if users specify their matrix A and right-hand-side vector b in a linear equation (Ax=b),
the Gram-Schmidt process will be executed in parallel,
including matrix-vector multiplications and orthogonalization between the basis vectors.
Am I correct?
Thanks very much.
Best,
Chih-Hao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170118/f8d1c060/attachment.html>
