[petsc-users] monitoring the convergence of fieldsplit 0 and 1
Klaij, Christiaan C.Klaij at marin.nl
Wed Jan 18 02:40:20 CST 2017
Barry,
I've managed to replicate the problem with 3.7.4
snes/examples/tutorials/ex70.c. Basically I've added
KSPGetTotalIterations to main (file is attached):
$ diff -u ex70.c.bak ex70.c
--- ex70.c.bak2017-01-18 09:25:46.286174830 +0100
+++ ex70.c2017-01-18 09:03:40.904483434 +0100
@@ -669,6 +669,10 @@
   KSP            ksp;
   PetscErrorCode ierr;
+  KSP            *subksp;
+  PC             pc;
+  PetscInt       numsplit = 1, nusediter_vv, nusediter_pp;
   ierr     = PetscInitialize(&argc, &argv, NULL, help);CHKERRQ(ierr);
   s.nx     = 4;
   s.ny     = 6;
@@ -690,6 +694,13 @@
   ierr = StokesSetupPC(&s, ksp);CHKERRQ(ierr);
   ierr = KSPSolve(ksp, s.b, s.x);CHKERRQ(ierr);
+  ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
+  ierr = PCFieldSplitGetSubKSP(pc,&numsplit,&subksp); CHKERRQ(ierr);
+  ierr = KSPGetTotalIterations(subksp[0],&nusediter_vv); CHKERRQ(ierr);
+  ierr = KSPGetTotalIterations(subksp[1],&nusediter_pp); CHKERRQ(ierr);
+  ierr = PetscPrintf(PETSC_COMM_WORLD," total u solves = %i\n", nusediter_vv); CHKERRQ(ierr);
+  ierr = PetscPrintf(PETSC_COMM_WORLD," total p solves = %i\n", nusediter_pp); CHKERRQ(ierr);
   /* don't trust, verify! */
   ierr = StokesCalcResidual(&s);CHKERRQ(ierr);
   ierr = StokesCalcError(&s);CHKERRQ(ierr);
Now run as follows:
$ mpirun -n 2 ./ex70 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi -fieldsplit_1_pc_type jacobi -fieldsplit_1_inner_ksp_type preonly -fieldsplit_1_inner_pc_type jacobi -fieldsplit_1_upper_ksp_type preonly -fieldsplit_1_upper_pc_type jacobi -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_converged_reason
  Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 5
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 14
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 16
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 17
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 18
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 20
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 21
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 23
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
 total u solves = 225
 total p solves = 225
 residual u = 9.67257e-06
 residual p = 5.42082e-07
 residual [u,p] = 9.68775e-06
 discretization error u = 0.0106464
 discretization error p = 1.85907
 discretization error [u,p] = 1.8591
So here again the total of 225 is correct for p, but for u it
should be 60. Hope this helps you find the problem.
Chris
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Few-places-left-for-Offshore-and-Ship-hydrodynamics-courses.htm
Sent: Tuesday, January 17, 2017 8:45 AM
To: Barry Smith
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] monitoring the convergence of fieldsplit 0 and 1
Well, that's it, all the rest was hard coded. Here's the relevant part of the code:
   CALL PCSetType(pc_system,PCFIELDSPLIT,ierr); CHKERRQ(ierr)
  CALL PCFieldSplitSetType(pc_system,PC_COMPOSITE_SCHUR,ierr); CHKERRQ(ierr)
  CALL PCFieldSplitSetIS(pc_system,"0",isgs(1),ierr); CHKERRQ(ierr)
  CALL PCFieldSplitSetIS(pc_system,"1",isgs(2),ierr); CHKERRQ(ierr)
  CALL PCFieldSplitSetSchurFactType(pc_system,PC_FIELDSPLIT_SCHUR_FACT_FULL,ierr);CHKERRQ(ierr)
  CALL PCFieldSplitSetSchurPre(pc_system,PC_FIELDSPLIT_SCHUR_PRE_SELFP,PETSC_NULL_OBJECT,ierr);CHKERRQ(ierr)
  CALL KSPSetTolerances(ksp_system,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,maxiter,ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_rtol","0.01",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_ksp_rtol","0.01",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_pc_side","right",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_ksp_pc_side","right",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_type","gmres",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_upper_ksp_type","preonly",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_upper_pc_type","jacobi",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_inner_ksp_type","preonly",ierr); CHKERRQ(ierr)
  CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_inner_pc_type","jacobi",ierr); CHKERRQ(ierr)
Sent: Monday, January 16, 2017 9:28 PM
To: Klaij, Christiaan
   Please send all the command line options you use.
> On Jan 16, 2017, at 1:47 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Barry,
> Sure, here's the output with:
> -sys_ksp_view -sys_ksp_converged_reason -sys_fieldsplit_0_ksp_converged_reason -sys_fieldsplit_1_ksp_converged_reason
> (In my previous email, I rearranged 0 & 1 for easy summing.)
> Chris
>  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
>  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
>  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 2
>  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 6
>  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
>  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 3
>  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 8
> Linear sys_ solve converged due to CONVERGED_RTOL iterations 6
> KSP Object:(sys_) 1 MPI processes
>  type: fgmres
>    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>    GMRES: happy breakdown tolerance 1e-30
>  maximum iterations=300, initial guess is zero
>  tolerances:  relative=0.01, absolute=1e-50, divergence=10000.
>  right preconditioning
>  using UNPRECONDITIONED norm type for convergence test
> PC Object:(sys_) 1 MPI processes
>  type: fieldsplit
>    FieldSplit with Schur preconditioner, factorization FULL
>    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
>    Split info:
>    Split number 0 Defined by IS
>    Split number 1 Defined by IS
>    KSP solver for A00 block
>      KSP Object:      (sys_fieldsplit_0_)       1 MPI processes
>        type: gmres
>        maximum iterations=10000, initial guess is zero
>      PC Object:      (sys_fieldsplit_0_)       1 MPI processes
>        type: ilu
>          ILU: out-of-place factorization
>          0 levels of fill
>          tolerance for zero pivot 2.22045e-14
>          matrix ordering: natural
>          factor fill ratio given 1., needed 1.
>            Factored matrix follows:
>              Mat Object:               1 MPI processes
>                type: seqaij
>                rows=9600, cols=9600
>                package used to perform factorization: petsc
>                total: nonzeros=47280, allocated nonzeros=47280
>                total number of mallocs used during MatSetValues calls =0
>                  not using I-node routines
>        linear system matrix = precond matrix:
>        Mat Object:        (sys_fieldsplit_0_)         1 MPI processes
>          type: seqaij
>    KSP solver for upper A00 in upper triangular factor
>      KSP Object:      (sys_fieldsplit_1_upper_)       1 MPI processes
>        type: preonly
>        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>        left preconditioning
>        using NONE norm type for convergence test
>      PC Object:      (sys_fieldsplit_1_upper_)       1 MPI processes
>        type: jacobi
>          type: seqaij
>    KSP solver for S = A11 - A10 inv(A00) A01
>      KSP Object:      (sys_fieldsplit_1_)       1 MPI processes
>        type: gmres
>      PC Object:      (sys_fieldsplit_1_)       1 MPI processes
>        type: ilu
>          0 levels of fill
>                type: seqaij
>                rows=3200, cols=3200
>                total: nonzeros=40404, allocated nonzeros=40404
>        linear system matrix followed by preconditioner matrix:
>        Mat Object:        (sys_fieldsplit_1_)         1 MPI processes
>          type: schurcomplement
>            Schur complement A11 - A10 inv(A00) A01
>            A11
>                type: seqaij
>            A10
>                type: seqaij
>                rows=3200, cols=9600
>            KSP of A00
>              KSP Object:              (sys_fieldsplit_1_inner_)               1 MPI processes
>                type: preonly
>              PC Object:              (sys_fieldsplit_1_inner_)               1 MPI processes
>                type: jacobi
>                  type: seqaij
>            A01
>                type: seqaij
>                rows=9600, cols=3200
>          type: seqaij
>    type: nest
>    rows=12800, cols=12800
>      Matrix object:
>        type=nest, rows=2, cols=2
>        MatNest structure:
>        (0,0) : prefix="mom_", type=seqaij, rows=9600, cols=9600
>        (0,1) : prefix="grad_", type=seqaij, rows=9600, cols=3200
>        (1,0) : prefix="div_", type=seqaij, rows=3200, cols=9600
>        (1,1) : prefix="stab_", type=seqaij, rows=3200, cols=3200
>    type: nest
>      Matrix object:
>        MatNest structure:
>        (0,0) : prefix="sys_fieldsplit_0_", type=seqaij, rows=9600, cols=9600
>        (0,1) : type=seqaij, rows=9600, cols=3200
>        (1,0) : type=seqaij, rows=3200, cols=9600
>        (1,1) : prefix="sys_fieldsplit_1_", type=seqaij, rows=3200, cols=3200
> nusediter_vv          37
> nusediter_pp          37
> MARIN news: http://www.marin.nl/web/News/News-items/The-Ocean-Cleanup-testing-continues.htm
> From: Barry Smith <bsmith at mcs.anl.gov>
> Sent: Friday, January 13, 2017 7:51 PM
>   Yes, I would have expected this to work. Could you send the output from -ksp_view in this case?
>> On Jan 13, 2017, at 3:46 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>> Barry,
>> It's been a while but I'm finally using this function in
>> 3.7.4. Is it supposed to work with fieldsplit? Here's why.
>> I'm solving a Navier-Stokes system with fieldsplit (pc has one
>> velocity solve and one pressure solve) and trying to retrieve the
>> totals like this:
>> CALL KSPSolve(ksp_system,rr_system,xx_system,ierr); CHKERRQ(ierr)
>> CALL PCFieldSplitGetSubKSP(pc_system,numsplit,subksp,ierr); CHKERRQ(ierr)
>> CALL KSPGetTotalIterations(subksp(1),nusediter_vv,ierr); CHKERRQ(ierr)
>> CALL KSPGetTotalIterations(subksp(2),nusediter_pp,ierr); CHKERRQ(ierr)
>> print *, 'nusediter_vv', nusediter_vv
>> print *, 'nusediter_pp', nusediter_pp
>> Running the code shows this surprise:
>> nusediter_vv          37
>> nusediter_pp          37
>> So the value of nusediter_pp is indeed 37, but for nusediter_vv
>> it should be 66. Any idea what went wrong?
>> Chris
>> MARIN news: http://www.marin.nl/web/News/News-items/MARIN-wishes-you-a-challenging-inspiring-2017.htm
>> Sent: Saturday, April 11, 2015 12:27 AM
>> Chris,
>> I have added KSPGetTotalIterations() to the branch barry/add-ksp-total-iterations/master and next. After tests it will go into master
>> Barry
>>> On Apr 10, 2015, at 8:07 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>>> Barry,
>>> Sure, I can call PCFieldSplitGetSubKSP() to get the fieldsplit_0
>>> ksp and then KSPGetIterationNumber, but what does this number
>>> mean?
>>> It appears to be the number of iterations of the last time that
>>> the subsystem was solved, right? If so, this corresponds to the
>>> last iteration of the coupled system, how about all the previous
>>> iterations?
>>> Chris
>>> Sent: Friday, April 10, 2015 2:48 PM
>>> Chris,
>>>   It appears you should call PCFieldSplitGetSubKSP() and then get the information you want out of the individual KSPs. If this doesn't work please let us know.
>>> Barry
>>>> On Apr 10, 2015, at 6:48 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>>>> A question when using PCFieldSplit: for each linear iteration of
>>>> the system, how many iterations for fielsplit 0 and 1?
>>>> One way to find out is to run with -ksp_monitor,
>>>> -fieldsplit_0_ksp_monitor and -fieldsplit_0_ksp_monitor. This
>>>> gives the complete convergence history.
>>>> Another way, suggested by Matt, is to use -ksp_monitor,
>>>> -fieldsplit_0_ksp_converged_reason and
>>>> -fieldsplit_1_ksp_converged_reason. This gives only the totals
>>>> for fieldsplit 0 and 1 (but without saying for which one).
>>>> Both ways require to somehow process the output, which is a bit
>>>> inconvenient. Could KSPGetResidualHistory perhaps return (some)
>>>> information on the subsystems' convergence for processing inside
>>>> the code?
>>>> Chris
>>>> CFD Researcher
>>>> E mailto:C.Klaij at marin.nl
>>>> T +31 317 49 33 44
>>>> MARIN
>>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>>> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
Type: text/x-csrc
Desc: ex70.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170118/74afe930/attachment-0001.c>
