[petsc-users] Using PCFIELDSPLIT with -pc_fieldsplit_type schur
David Knezevic david.knezevic at akselos.com
Wed Jan 11 16:29:02 CST 2017
Thanks very much for the input. I tried with "selfp" and it's about the
same (log below), so I gather that I'll have to look into a user-defined
approximation to S.
David
  0 KSP Residual norm 5.405528187695e+04
  1 KSP Residual norm 2.187814910803e+02
  2 KSP Residual norm 1.019051577515e-01
  3 KSP Residual norm 4.370464012859e-04
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=1000
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled
approximation to S, which uses (lumped, if requested) A00's diagonal's
inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_RB_split_)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_RB_split_)       1 MPI processes
        type: cholesky
          Cholesky: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 0., needed 0.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=324, cols=324
                package used to perform factorization: mumps
                total: nonzeros=3042, allocated nonzeros=3042
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   2
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):
0
                    ICNTL(13) (efficiency control):
0
                    ICNTL(14) (percentage of estimated workspace increase):
20
                    ICNTL(18) (input mat struct):
0
                    ICNTL(19) (Shur complement info):
0
                    ICNTL(20) (rhs sparse pattern):
0
                    ICNTL(21) (solution struct):
 0
                    ICNTL(22) (in-core/out-of-core facility):
0
                    ICNTL(23) (max size of memory can be allocated
locally):0
                    ICNTL(24) (detection of null pivot rows):
0
                    ICNTL(25) (computation of a null space basis):
 0
                    ICNTL(26) (Schur options for rhs or solution):
 0
                    ICNTL(27) (experimental parameter):
-24
                    ICNTL(28) (use parallel or sequential ordering):
 1
                    ICNTL(29) (parallel ordering):
 0
                    ICNTL(30) (user-specified set of entries in inv(A)):
 0
                    ICNTL(31) (factors is discarded in the solve phase):
 0
                    ICNTL(33) (compute determinant):
 0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absolute pivoting threshold):      0.
                    CNTL(4) (value of static pivoting):         -1.
                    CNTL(5) (fixation for null pivots):         0.
                    RINFO(1) (local estimated flops for the elimination
after analysis):
                      [0] 29394.
                    RINFO(2) (local estimated flops for the assembly after
factorization):
                      [0]  1092.
                    RINFO(3) (local estimated flops for the elimination
after factorization):
                      [0]  29394.
                    INFO(15) (estimated size of (in MB) MUMPS internal data
for running numerical factorization):
                    [0] 1
                    INFO(16) (size of (in MB) MUMPS internal data used
during numerical factorization):
                      [0] 1
                    INFO(23) (num of pivots eliminated on this processor
                      [0] 324
                    RINFOG(1) (global estimated flops for the elimination
after analysis): 29394.
                    RINFOG(2) (global estimated flops for the assembly
after factorization): 1092.
                    RINFOG(3) (global estimated flops for the elimination
after factorization): 29394.
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
(0.,0.)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all
processors after analysis): 3888
                    INFOG(4) (estimated integer workspace for factors on
all processors after analysis): 2067
                    INFOG(5) (estimated maximum front size in the complete
tree): 12
                    INFOG(6) (number of nodes in the complete tree): 53
                    INFOG(7) (ordering option effectively use after
analysis): 2
                    INFOG(8) (structural symmetry in percent of the
permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the
matrix factors after factorization): 3888
                    INFOG(10) (total integer space store the matrix factors
after factorization): 2067
                    INFOG(11) (order of largest frontal matrix after
factorization): 12
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after
factorization): 0
                    INFOG(14) (number of memory compress after
factorization): 0
                    INFOG(15) (number of steps of iterative refinement
after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal
data for factorization after analysis: value on the most memory consuming
processor): 1
                    INFOG(17) (estimated size of all MUMPS internal data
for factorization after analysis: sum over all processors): 1
                    INFOG(18) (size of all MUMPS internal data allocated
during factorization: value on the most memory consuming processor): 1
                    INFOG(19) (size of all MUMPS internal data allocated
during factorization: sum over all processors): 1
                    INFOG(20) (estimated number of entries in the factors):
3042
                    INFOG(21) (size in MB of memory effectively used during
factorization - value on the most memory consuming processor): 1
                    INFOG(22) (size in MB of memory effectively used during
factorization - sum over all processors): 1
                    INFOG(23) (after analysis: value of ICNTL(6)
effectively used): 5
                    INFOG(24) (after analysis: value of ICNTL(12)
effectively used): 1
                    INFOG(25) (after factorization: number of pivots
modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots
encountered): 0
                    INFOG(29) (after factorization: effective number of
entries in the factors (sum over all processors)): 3042
                    INFOG(30, 31) (after solution: size in Mbytes of memory
used during solution phase): 0, 0
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): -2
                    INFOG(34) (exponent of the determinant if determinant
is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_RB_split_)         1 MPI processes
          type: seqaij
          rows=324, cols=324
          total: nonzeros=5760, allocated nonzeros=5760
            using I-node routines: found 108 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_FE_split_)       1 MPI processes
        type: cg
      PC Object:      (fieldsplit_FE_split_)       1 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 1
          Local solve is same for all blocks, in the following KSP and PC
objects:
          KSP Object:          (fieldsplit_FE_split_sub_)           1 MPI
processes
            type: preonly
          PC Object:          (fieldsplit_FE_split_sub_)           1 MPI
processes
            type: ilu
              ILU: out-of-place factorization
              0 levels of fill
              factor fill ratio given 1., needed 1.
                    type: seqaij
                    rows=28476, cols=28476
                    package used to perform factorization: petsc
                    total: nonzeros=1037052, allocated nonzeros=1037052
=0
                      using I-node routines: found 9489 nodes, limit used
is 5
              type: seqaij
                using I-node routines: found 9489 nodes, limit used is 5
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_FE_split_)         1 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
1 MPI processes
                type: seqaij
                total: nonzeros=1017054, allocated nonzeros=1017054
                  using I-node routines: found 9492 nodes, limit used is 5
            A10
                type: seqaij
                rows=28476, cols=324
                total: nonzeros=936, allocated nonzeros=936
                  using I-node routines: found 5717 nodes, limit used is 5
            KSP of A00
1 MPI processes
                type: preonly
divergence=10000.
1 MPI processes
                type: cholesky
                        type: seqaij
                        rows=324, cols=324
calls =0
        0
        0
increase): 20
        0
        0
        0
         0
        0
locally):0
        0
         0
         0
        -24
ordering):        1
         0
inv(A)):    0
phase):    0
         0
 0.01
1.49012e-08
elimination after analysis):
                              [0] 29394.
assembly after factorization):
                              [0]  1092.
elimination after factorization):
                              [0]  29394.
internal data for running numerical factorization):
                            [0] 1
used during numerical factorization):
                              [0] 1
processor after factorization):
                              [0] 324
elimination after analysis): 29394.
assembly after factorization): 1092.
elimination after factorization): 29394.
(determinant): (0.,0.)*(2^0)
on all processors after analysis): 3888
factors on all processors after analysis): 2067
complete tree): 12
tree): 53
analysis): 2
the matrix factors after factorization): 3888
factors after factorization): 2067
after factorization): 12
factorization): 0
factorization): 0
refinement after solution): 0
internal data for factorization after analysis: value on the most memory
data for factorization after analysis: sum over all processors): 1
allocated during factorization: value on the most memory consuming
processor): 1
allocated during factorization: sum over all processors): 1
factors): 3042
used during factorization - value on the most memory consuming processor):
1
used during factorization - sum over all processors): 1
pivots modified by static pivoting): 0
pivots encountered): 0
number of entries in the factors (sum over all processors)): 3042
of memory used during solution phase): 0, 0
done): 1
determinant is requested): 0
      1 MPI processes
                  type: seqaij
                  rows=324, cols=324
            A01
                type: seqaij
                rows=324, cols=28476
                  using I-node routines: found 67 nodes, limit used is 5
          type: seqaij
  Mat Object:  ()   1 MPI processes
    type: seqaij
    rows=28800, cols=28800
    total: nonzeros=1024686, allocated nonzeros=1024794
      using I-node routines: found 9600 nodes, limit used is 5
---------------------------------------------- PETSc Performance Summary:
/home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a
arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11
17:22:10 2017
Using Petsc Release Version 3.7.3, unknown
                         Max       Max/Min        Avg      Total
Time (sec):           9.638e+01      1.00000   9.638e+01
Objects:              2.030e+02      1.00000   2.030e+02
Flops:                1.732e+11      1.00000   1.732e+11  1.732e+11
Flops/sec:            1.797e+09      1.00000   1.797e+09  1.797e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N
--> 2N flops
                            and VecAXPY() for complex vectors of length N
--> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
 -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total
 0:      Main Stage: 9.6379e+01 100.0%  1.7318e+11 100.0%  0.000e+00   0.0%
 0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this
phase
      %M - percent messages in this phase     %L - percent message lengths
in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
all processors)
Event                Count      Time (sec)     Flops
      --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot                42 1.0 2.2411e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   380
VecTDot            77761 1.0 1.4294e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
0.0e+00  1  3  0  0  0   1  3  0  0  0  3098
VecNorm            38894 1.0 9.1002e-01 1.0 2.22e+09 1.0 0.0e+00 0.0e+00
0.0e+00  1  1  0  0  0   1  1  0  0  0  2434
VecScale           38882 1.0 3.7314e-01 1.0 1.11e+09 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   0  1  0  0  0  2967
VecCopy            38908 1.0 2.1655e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             77887 1.0 3.2034e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY            77777 1.0 1.8382e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
0.0e+00  2  3  0  0  0   2  3  0  0  0  2409
VecAYPX            38875 1.0 1.2884e+00 1.0 2.21e+09 1.0 0.0e+00 0.0e+00
0.0e+00  1  1  0  0  0   1  1  0  0  0  1718
VecAssemblyBegin      68 1.0 1.9407e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecAssemblyEnd        68 1.0 2.6941e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin       48 1.0 4.6349e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatMult            38891 1.0 4.3045e+01 1.0 8.03e+10 1.0 0.0e+00 0.0e+00
0.0e+00 45 46  0  0  0  45 46  0  0  0  1866
MatMultAdd         38889 1.0 3.5360e+01 1.0 7.91e+10 1.0 0.0e+00 0.0e+00
0.0e+00 37 46  0  0  0  37 46  0  0  0  2236
MatSolve           77769 1.0 4.8780e+01 1.0 7.95e+10 1.0 0.0e+00 0.0e+00
0.0e+00 51 46  0  0  0  51 46  0  0  0  1631
MatLUFactorNum         1 1.0 1.9575e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1274
MatCholFctrSym         1 1.0 9.4891e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatCholFctrNum         1 1.0 3.7885e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatILUFactorSym        1 1.0 4.1780e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatConvert             1 1.0 3.0041e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatScale               2 1.0 2.7180e-05 1.0 2.53e+04 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   930
MatAssemblyBegin      32 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyEnd        32 1.0 1.2032e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetRow         114978 1.0 5.9254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetRowIJ            2 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetSubMatrice       6 1.0 1.5707e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         2 1.0 3.2425e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries         6 1.0 3.0580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatView                7 1.0 3.5119e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatAXPY                1 1.0 1.9384e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatMatMult             1 1.0 2.7120e-03 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   117
MatMatMultSym          1 1.0 1.8010e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatMatMultNum          1 1.0 6.1703e-04 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   513
KSPSetUp               4 1.0 9.8944e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               1 1.0 9.3380e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
0.0e+00 97100  0  0  0  97100  0  0  0  1855
PCSetUp                4 1.0 6.6326e-02 1.0 2.53e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   381
PCSetUpOnBlocks        5 1.0 2.4082e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1036
PCApply                5 1.0 9.3376e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
KSPSolve_FS_0          5 1.0 7.0214e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve_FS_Schu       5 1.0 9.3372e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
KSPSolve_FS_Low        5 1.0 2.1377e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    92             92      9698040     0.
      Vector Scatter    24             24        15936     0.
           Index Set    51             51       537876     0.
   IS L to G Mapping     3              3       240408     0.
              Matrix    16             16     77377776     0.
       Krylov Solver     6              6         7888     0.
      Preconditioner     6              6         6288     0.
              Viewer     1              0            0     0.
    Distributed Mesh     1              1         4624     0.
Star Forest Bipartite Graph     2              2         1616     0.
     Discrete System     1              1          872     0.
Average time to get PetscTime(): 0.
#PETSc Option Table entries:
-ksp_monitor
-ksp_view
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-shared-libraries=1 --with-debugging=0
--download-suitesparse --download-blacs --download-ptscotch=yes
--with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl
--CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps
--download-metis
--prefix=/home/dknez/software/libmesh_install/opt_real/petsc
--download-hypre --download-ml
Libraries compiled on Wed Sep 21 17:38:52 2016 on david-Lenovo
Machine characteristics:
Linux-4.4.0-38-generic-x86_64-with-Ubuntu-16.04-xenial
Using PETSc directory: /home/dknez/software/petsc-src
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -fvisibility=hidden -g -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0
-Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
Using include paths:
-I/home/dknez/software/petsc-src/arch-linux2-c-opt/include
-I/home/dknez/software/petsc-src/include
-I/home/dknez/software/libmesh_install/opt_real/petsc/include
-I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent
-I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include
-I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
-Wl,-rpath,/home/dknez/software/petsc-src/arch-linux2-c-opt/lib
-L/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -lpetsc
-Wl,-rpath,/home/dknez/software/libmesh_install/opt_real/petsc/lib
-L/home/dknez/software/libmesh_install/opt_real/petsc/lib -lcmumps -ldmumps
-lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE
-Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5
-L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -lscalapack -lml -lmpi_cxx
-lstdc++ -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd
-lsuitesparseconfig
-Wl,-rpath,/opt/intel/system_studio_2015.2.050/mkl/lib/intel64
-L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -lmkl_intel_lp64
-lmkl_sequential -lmkl_core -lpthread -lm -lhwloc -lptesmumps -lptscotch
-lptscotcherr -lscotch -lscotcherr -lX11 -lm -lmpi_usempif08
-lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm -lgfortran -lm
-lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz
-L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/usr/lib/openmpi/lib -lmpi
-lgcc_s -lpthread -ldl
On Wed, Jan 11, 2017 at 4:49 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> It looks like the Schur solve is requiring a huge number of iterates to
> converge (based on the instances of MatMult).
> This is killing the performance.
> Are you sure that A11 is a good approximation to S? You might consider
> trying the selfp option
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/
> PCFieldSplitSetSchurPre.html#PCFieldSplitSetSchurPre
> Note that the best approx to S is likely both problem and discretisation
> dependent so if selfp is also terrible, you might want to consider coding
> up your own approx to S for your specific system.
> Thanks,
>   Dave
> On Wed, 11 Jan 2017 at 22:34, David Knezevic <david.knezevic at akselos.com>
> wrote:
> I have a definite block 2x2 system and I figured it'd be good to apply the
> PCFIELDSPLIT functionality with Schur complement, as described in Section
> 4.5 of the manual.
> The A00 block of my matrix is very small so I figured I'd specify a direct
> solver (i.e. MUMPS) for that block.
> So I did the following:
> - PCFieldSplitSetIS to specify the indices of the two splits
> - PCFieldSplitGetSubKSP to get the two KSP objects, and to set the solver
> and PC types for each (MUMPS for A00, ILU+CG for A11)
> - I set -pc_fieldsplit_schur_fact_type full
> Below I have pasted the output of "-ksp_view -ksp_monitor -log_view" for a
> test case. It seems to converge well, but I'm concerned about the speed
> (about 90 seconds, vs. about 1 second if I use a direct solver for the
> entire system). I just wanted to check if I'm setting this up in a good way?
> Many thanks,
> David
>   0 KSP Residual norm 5.405774214400e+04
>   1 KSP Residual norm 1.849649014371e+02
>   2 KSP Residual norm 7.462775074989e-02
>   3 KSP Residual norm 2.680497175260e-04
>   type: cg
>   type: fieldsplit
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>         type: preonly
>         type: cholesky
>                 type: seqaij
>                 rows=324, cols=324
>   0
>   0
> increase): 20
>   0
>   0
>   0
>  0
>   0
> locally):0
>   0
>  0
>  0
>   -24
>  1
>  0
>  0
>  0
>  0
> 1.49012e-08
> after analysis):
>                       [0] 29394.
> factorization):
>                       [0]  1092.
>                       [0]  29394.
>                     [0] 1
>                       [0] 1
>                       [0] 324
> (0.,0.)*(2^0)
> tree): 12
> analysis): 2
> factorization): 12
> factorization): 0
> factorization): 0
> after solution): 0
> factors): 3042
> during factorization - value on the most memory consuming processor): 1
> encountered): 0
> is requested): 0
>           type: seqaij
>           rows=324, cols=324
>         type: cg
>         type: bjacobi
> objects:
> processes
>             type: preonly
> processes
>             type: ilu
>               0 levels of fill
>                     type: seqaij
> =0
> is 5
> MPI processes
>               type: seqaij
>             A11
>   1 MPI processes
>                 type: seqaij
>             A10
>                 type: seqaij
>             KSP of A00
>   1 MPI processes
>                 type: preonly
> divergence=10000.
> 1 MPI processes
>                 type: cholesky
>                         type: seqaij
>                         rows=324, cols=324
> calls =0
>           0
>           0
> increase): 20
>           0
>           0
>           0
>          0
>           0
> locally):0
>           0
>          0
>          0
>           -24
> ordering):        1
>          0
> inv(A)):    0
> phase):    0
>          0
>  0.01
> 1.49012e-08
> -1.
>                               [0] 29394.
>                               [0]  1092.
>                               [0]  29394.
>                             [0] 1
>                               [0] 1
>                               [0] 324
> complete tree): 12
> tree): 53
> after analysis): 2
> the permuted matrix after analysis): 100
> store the matrix factors after factorization): 3888
> matrix factors after factorization): 2067
> factorization): 0
> factorization): 0
> internal data for factorization after analysis: sum over all processors): 1
> processor): 1
> factors): 3042
> 1
> done): 1
>         1 MPI processes
>                   type: seqaij
>                   rows=324, cols=324
>             A01
>                 type: seqaij
>           type: seqaij
>     type: seqaij
> 16:16:47 2017
> Time (sec):           9.179e+01      1.00000   9.179e+01
> Objects:              1.990e+02      1.00000   1.990e+02
> Flops:                1.634e+11      1.00000   1.634e+11  1.634e+11
> Flops/sec:            1.780e+09      1.00000   1.780e+09  1.780e+09
> --> 2N flops
> --> 8N flops
> ---  -- Message Lengths --  -- Reductions --
>  0:      Main Stage: 9.1787e+01 100.0%  1.6336e+11 100.0%  0.000e+00
> 0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> Phase summary info:
> PetscLogStagePop().
> phase
> in this phase
> VecDot                42 1.0 2.4080e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   354
> VecTDot            74012 1.0 1.2440e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  3  0  0  0   1  3  0  0  0  3388
> VecNorm            37020 1.0 8.3580e-01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  2523
> VecScale           37008 1.0 3.5800e-01 1.0 1.05e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0  2944
> VecCopy            37034 1.0 2.5754e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet             74137 1.0 3.0537e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY            74029 1.0 1.7233e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  3  0  0  0   2  3  0  0  0  2446
> VecAYPX            37001 1.0 1.2214e+00 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  1725
> VecAssemblyBegin      68 1.0 2.0432e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd        68 1.0 2.5988e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin       48 1.0 4.6921e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMult            37017 1.0 4.1269e+01 1.0 7.65e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 45 47  0  0  0  45 47  0  0  0  1853
> MatMultAdd         37015 1.0 3.3638e+01 1.0 7.53e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 37 46  0  0  0  37 46  0  0  0  2238
> MatSolve           74021 1.0 4.6602e+01 1.0 7.42e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 51 45  0  0  0  51 45  0  0  0  1593
> MatLUFactorNum         1 1.0 1.7209e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1420
> MatCholFctrSym         1 1.0 8.8310e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatCholFctrNum         1 1.0 3.6907e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatILUFactorSym        1 1.0 3.7372e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyBegin      29 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd        29 1.0 9.9473e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRow          58026 1.0 2.8155e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRowIJ            2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetSubMatrice       6 1.0 1.5399e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering         2 1.0 3.0112e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatZeroEntries         6 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatView                7 1.0 3.4356e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSetUp               4 1.0 9.4891e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve               1 1.0 8.8793e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> 0.0e+00 97100  0  0  0  97100  0  0  0  1840
> PCSetUp                4 1.0 3.8375e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   637
> PCSetUpOnBlocks        5 1.0 2.1250e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1150
> PCApply                5 1.0 8.8789e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> KSPSolve_FS_0          5 1.0 7.5364e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve_FS_Schu       5 1.0 8.8785e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> KSPSolve_FS_Low        5 1.0 2.1019e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>               Vector    91             91      9693912     0.
>            Index Set    51             51       537888     0.
>               Matrix    13             13     64097868     0.
>               Viewer     1              0            0     0.
> -ksp_monitor
> -ksp_view
> -log_view
> --download-metis --prefix=/home/dknez/software/libmesh_install/opt_real/petsc
> Machine characteristics: Linux-4.4.0-38-generic-x86_64-
> Using include paths: -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include
> -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/include
> Using libraries: -Wl,-rpath,/home/dknez/software/petsc-src/arch-linux2-c-opt/lib
> -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE
> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5
> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx
> -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lumfpack -lklu -lcholmod
> -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig
> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
> -Wl,-rpath,/usr/lib/openmpi/lib -lmpi -lgcc_s -lpthread -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170111/4a338276/attachment-0001.html>
