[petsc-users] Visualization of uninterpolated DMPlex with hdf5 is broken
Sander Arens Sander.Arens at ugent.be
Wed Jan 11 07:23:04 CST 2017
Visualization of uninterpolated DMPlex with hdf5 currently does not work. I
think the culprit is this line.
<https://bitbucket.org/petsc/petsc/src/aa0ba431d766d8676b0f511486aa700b6a8925ca/src/dm/impls/plex/plexhdf5.c?at=master&fileviewer=file-view-default#plexhdf5.c-303>Is
this to avoid duplicating output for the topology? If so, I think this is
wrong, because the dataset /topology/cells does not have the correct block
size and correct values (it outputs point numbers and not vertex numbers)
for visualization.
Sander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170111/0f8a7a2c/attachment.html>
