[petsc-users] PetscTableCreateHashSize
Jed Brown jed at jedbrown.org
Mon Jan 9 19:24:50 CST 2017
Satish Balay <balay at mcs.anl.gov> writes:
>> Why is it not sufficient to be coprime?
> Well whatever was implemented previsously with PETSC_HASH_FACT [a
> prime number] didn't work well. [there were a couple of reports on it].
That was linear probing, right?
> Checking double hashing [Intro to algorithms, Coremen et all.]:
> For a hashtable size 'm' - and using hash functions h1(k), h2(k) - it
> says: h2(k) must be relatively prime to 'm'. [for all possilbe 'k'
> values? its not clear. Also any constraints on h1(k)?]
relatively prime = coprime
> And it suggested the following as one way to imlement:
> choose a prime 'm'
> h1(k) = k mod m
> h2(k) = 1 +  (k mod m')
> This was simple enough for me - so I updated ctable to use it. I've
> added entries up to INT_MAX.
Thanks.
> If its still lacking (I could potentially add more entries - perhaps
> for 64bitincides? or) - feel free to change the algorithm for arbirary
> sizes...
I would use khash (hash.h) because it is a portable and well-optimized
hash implementation.  The version in PETSc uses primes and double
hashing, though upstream now uses quadratic probing (better cache
locality).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170109/7fe52bbf/attachment.pgp>
