[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Sun Jan 8 11:48:38 CST 2017
  we need to see the -log_summary with hypre on 1 and 2 processes (with debugging tuned off) also we need to see the output from
   make stream NPMAX=4
run in the PETSc directory.
> On Jan 7, 2017, at 7:38 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Ok great, i tried those command line args and this is the result:
> when i use -pc_type gamg:
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: Petsc has generated inconsistent data
> [1]PETSC ERROR: Have un-symmetric graph (apparently). Use '-pc_gamg_sym_graph true' to symetrize the graph or '-pc_gamg_threshold -1.0' if the matrix is structurally symmetric.
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.7.4, unknown
> [1]PETSC ERROR: ./ucmsMR on a arch-linux2-c-debug named ocean by valera Sat Jan  7 17:35:05 2017
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5 --download-netcdf --download-hypre --download-metis --download-parmetis --download-trillinos
> [1]PETSC ERROR: #1 smoothAggs() line 462 in /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: #2 PCGAMGCoarsen_AGG() line 998 in /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: #3 PCSetUp_GAMG() line 571 in /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/gamg.c
> [1]PETSC ERROR: #4 PCSetUp() line 968 in /usr/dataC/home/valera/petsc/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: #5 KSPSetUp() line 390 in /usr/dataC/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
> application called MPI_Abort(comm=0x84000002, 77) - process 1
> when i use -pc_type gamg and -pc_gamg_sym_graph true:
> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> [1]PETSC ERROR:       is given.
> [1]PETSC ERROR: [1] LAPACKgesvd line 42 /usr/dataC/home/valera/petsc/src/ksp/ksp/impls/gmres/gmreig.c
> [1]PETSC ERROR: [1] KSPComputeExtremeSingularValues_GMRES line 24 /usr/dataC/home/valera/petsc/src/ksp/ksp/impls/gmres/gmreig.c
> [1]PETSC ERROR: [1] KSPComputeExtremeSingularValues line 51 /usr/dataC/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: [1] PCGAMGOptProlongator_AGG line 1187 /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: [1] PCSetUp_GAMG line 472 /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/gamg.c
> [1]PETSC ERROR: [1] PCSetUp line 930 /usr/dataC/home/valera/petsc/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: [1] KSPSetUp line 305 /usr/dataC/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
> [0] PCGAMGOptProlongator_AGG line 1187 /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: [0] PCSetUp_GAMG line 472 /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: [0] PCSetUp line 930 /usr/dataC/home/valera/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 305 /usr/dataC/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> when i use -pc_type hypre it actually shows something different on -ksp_view :
> KSP Object: 2 MPI processes
>   type: gcr
>     GCR: restart = 30
>     GCR: restarts performed = 37
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-14, absolute=1e-50, divergence=10000.
>   right preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 2 MPI processes
>   type: hypre
>     HYPRE BoomerAMG preconditioning
>     HYPRE BoomerAMG: Cycle type V
>     HYPRE BoomerAMG: Maximum number of levels 25
>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
>     HYPRE BoomerAMG: Threshold for strong coupling 0.25
>     HYPRE BoomerAMG: Interpolation truncation factor 0.
>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>     HYPRE BoomerAMG: Maximum row sums 0.9
>     HYPRE BoomerAMG: Sweeps down         1
>     HYPRE BoomerAMG: Sweeps up           1
>     HYPRE BoomerAMG: Sweeps on coarse    1
>     HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>     HYPRE BoomerAMG: Relax weight  (all)      1.
>     HYPRE BoomerAMG: Outer relax weight (all) 1.
>     HYPRE BoomerAMG: Using CF-relaxation
>     HYPRE BoomerAMG: Not using more complex smoothers.
>     HYPRE BoomerAMG: Measure type        local
>     HYPRE BoomerAMG: Coarsen type        Falgout
>     HYPRE BoomerAMG: Interpolation type  classical
>     HYPRE BoomerAMG: Using nodal coarsening (with HYPRE_BOOMERAMGSetNodal() 1
>     HYPRE BoomerAMG: HYPRE_BoomerAMGSetInterpVecVariant() 1
>   linear system matrix = precond matrix:
>   Mat Object:   2 MPI processes
>     type: mpiaij
>     rows=200000, cols=200000
>     total: nonzeros=3373340, allocated nonzeros=3373340
>     total number of mallocs used during MatSetValues calls =0
>       not using I-node (on process 0) routines
> but still the timing is terrible.
> On Sat, Jan 7, 2017 at 5:28 PM, Jed Brown <jed at jedbrown.org> wrote:
> Manuel Valera <mvalera at mail.sdsu.edu> writes:
> > Awesome Matt and Jed,
> > The GCR is used because the matrix is not invertible and because this was
> > the algorithm that the previous library used,
> > The Preconditioned im aiming to use is multigrid, i thought i configured
> > the hypre-boomerAmg solver for this, but i agree in that it doesn't show in
> > the log anywhere, how can i be sure is being used ? i sent -ksp_view log
> > before in this thread
> Did you run with -pc_type hypre?
> > I had a problem with the matrix block sizes so i couldn't make the petsc
> > native multigrid solver to work,
> What block sizes?  If the only variable is pressure, the block size
> would be 1 (default).
> > This is a nonhidrostatic pressure solver, it is an elliptic problem so
> > multigrid is a must,
> Yes, multigrid should work well.
