[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Sat Jan 7 21:23:02 CST 2017
On Sat, Jan 7, 2017 at 7:38 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Ok great, i tried those command line args and this is the result:
> when i use -pc_type gamg:
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Petsc has generated inconsistent data
> [1]PETSC ERROR: Have un-symmetric graph (apparently). Use
> '-pc_gamg_sym_graph true' to symetrize the graph or '-pc_gamg_threshold
> -1.0' if the matrix is structurally symmetric.
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.7.4, unknown
> [1]PETSC ERROR: ./ucmsMR on a arch-linux2-c-debug named ocean by valera
> Sat Jan  7 17:35:05 2017
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
> --download-netcdf --download-hypre --download-metis --download-parmetis
> --download-trillinos
> [1]PETSC ERROR: #1 smoothAggs() line 462 in /usr/dataC/home/valera/petsc/
> src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: #2 PCGAMGCoarsen_AGG() line 998 in
> /usr/dataC/home/valera/petsc/src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: #3 PCSetUp_GAMG() line 571 in /usr/dataC/home/valera/petsc/
> src/ksp/pc/impls/gamg/gamg.c
> [1]PETSC ERROR: #4 PCSetUp() line 968 in /usr/dataC/home/valera/petsc/
> src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: #5 KSPSetUp() line 390 in /usr/dataC/home/valera/petsc/
> src/ksp/ksp/interface/itfunc.c
> application called MPI_Abort(comm=0x84000002, 77) - process 1
> when i use -pc_type gamg and -pc_gamg_sym_graph true:
Do everything Barry said.
However, I would like to track down this error. It could be a bug in our
code. However, it appears to happen in the call
to LAPACK, so it could also be a problem with that library on your machine.
Could you run this case in the debugger
and give the stack trace?
     Matt
> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
> Exception,probably divide by zero
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [1]PETSC ERROR: ------------------------------
> [1]PETSC ERROR: ---------------------  Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> [1]PETSC ERROR:       is given.
> [1]PETSC ERROR: [1] LAPACKgesvd line 42 /usr/dataC/home/valera/petsc/
> src/ksp/ksp/impls/gmres/gmreig.c
> [1]PETSC ERROR: [1] KSPComputeExtremeSingularValues_GMRES line 24
> /usr/dataC/home/valera/petsc/src/ksp/ksp/impls/gmres/gmreig.c
> [1]PETSC ERROR: [1] KSPComputeExtremeSingularValues line 51
> /usr/dataC/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: [1] PCGAMGOptProlongator_AGG line 1187
> [1]PETSC ERROR: [1] PCSetUp_GAMG line 472 /usr/dataC/home/valera/petsc/
> [1]PETSC ERROR: [1] PCSetUp line 930 /usr/dataC/home/valera/petsc/
> [1]PETSC ERROR: [1] KSPSetUp line 305 /usr/dataC/home/valera/petsc/
> [0] PCGAMGOptProlongator_AGG line 1187 /usr/dataC/home/valera/petsc/
> [0]PETSC ERROR: [0] PCSetUp_GAMG line 472 /usr/dataC/home/valera/petsc/
> [0]PETSC ERROR: [0] PCSetUp line 930 /usr/dataC/home/valera/petsc/
> [0]PETSC ERROR: [0] KSPSetUp line 305 /usr/dataC/home/valera/petsc/
> [0]PETSC ERROR: --------------------- Error Message
> when i use -pc_type hypre it actually shows something different on
> -ksp_view :
> KSP Object: 2 MPI processes
>   type: gcr
>     GCR: restart = 30
>     GCR: restarts performed = 37
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-14, absolute=1e-50, divergence=10000.
>   right preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 2 MPI processes
>   type: hypre
>     HYPRE BoomerAMG preconditioning
>     HYPRE BoomerAMG: Cycle type V
>     HYPRE BoomerAMG: Maximum number of levels 25
>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
>     HYPRE BoomerAMG: Threshold for strong coupling 0.25
>     HYPRE BoomerAMG: Interpolation truncation factor 0.
>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>     HYPRE BoomerAMG: Maximum row sums 0.9
>     HYPRE BoomerAMG: Sweeps down         1
>     HYPRE BoomerAMG: Sweeps up           1
>     HYPRE BoomerAMG: Sweeps on coarse    1
>     HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>     HYPRE BoomerAMG: Relax weight  (all)      1.
>     HYPRE BoomerAMG: Outer relax weight (all) 1.
>     HYPRE BoomerAMG: Using CF-relaxation
>     HYPRE BoomerAMG: Not using more complex smoothers.
>     HYPRE BoomerAMG: Measure type        local
>     HYPRE BoomerAMG: Coarsen type        Falgout
>     HYPRE BoomerAMG: Interpolation type  classical
>     HYPRE BoomerAMG: Using nodal coarsening (with
> HYPRE_BOOMERAMGSetNodal() 1
>     HYPRE BoomerAMG: HYPRE_BoomerAMGSetInterpVecVariant() 1
>   linear system matrix = precond matrix:
>   Mat Object:   2 MPI processes
>     type: mpiaij
>     rows=200000, cols=200000
>     total: nonzeros=3373340, allocated nonzeros=3373340
>     total number of mallocs used during MatSetValues calls =0
>       not using I-node (on process 0) routines
> but still the timing is terrible.
> On Sat, Jan 7, 2017 at 5:28 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Manuel Valera <mvalera at mail.sdsu.edu> writes:
>> > Awesome Matt and Jed,
>> > The GCR is used because the matrix is not invertible and because this
>> was
>> > the algorithm that the previous library used,
>> > The Preconditioned im aiming to use is multigrid, i thought i configured
>> > the hypre-boomerAmg solver for this, but i agree in that it doesn't
>> show in
>> > the log anywhere, how can i be sure is being used ? i sent -ksp_view log
>> > before in this thread
>> Did you run with -pc_type hypre?
>> > I had a problem with the matrix block sizes so i couldn't make the petsc
>> > native multigrid solver to work,
>> What block sizes?  If the only variable is pressure, the block size
>> would be 1 (default).
>> > This is a nonhidrostatic pressure solver, it is an elliptic problem so
>> > multigrid is a must,
>> Yes, multigrid should work well.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/a149e329/attachment-0001.html>
