[petsc-users] Best way to scatter a Seq vector ?
Manuel Valera mvalera at mail.sdsu.edu
Fri Jan 6 15:29:01 CST 2017
Thanks Dave,
I think is interesting it never gave an error on this, after adding the
vecassembly calls it still shows the same behavior, without complaining, i
did:
if(rankl==0)then
     call VecSetValues(bp0,nbdp,ind,Rhs,INSERT_VALUES,ierr)
     call VecAssemblyBegin(bp0,ierr) ; call VecAssemblyEnd(bp0,ierr);
     CHKERRQ(ierr)
     call VecView(bp0,PETSC_VIEWER_STDOUT_WORLD,ierr)
     CHKERRQ(ierr)
     call VecScatterBegin(ctr,bp0,bp2,INSERT_VALUES,SCATTER_REVERSE,ierr)
     call VecScatterEnd(ctr,bp0,bp2,INSERT_VALUES,SCATTER_REVERSE,ierr)
     print*,"done! "
     CHKERRQ(ierr)
endif
       CHKERRQ(ierr)
Thanks.
On Fri, Jan 6, 2017 at 12:44 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 6 January 2017 at 20:24, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
>> Great help Barry, i totally had overlooked that option (it is explicit in
>> the vecscatterbegin call help page but not in vecscattercreatetozero, as i
>> read later)
>> So i used that and it works partially, it scatters te values assigned in
>> root but not the rest, if i call vecscatterbegin from outside root it
>> hangs, the code currently look as this:
>>   call VecScatterCreateToZero(bp2,ctr,bp0,ierr); CHKERRQ(ierr)
>>   call PetscObjectSetName(bp0, 'bp0:',ierr)
>> if(rankl==0)then
> You need to call
>   VecAssemblyBegin(bp0);
>   VecAssemblyEnd(bp0);
> after your last call to VecSetValues() before you can do any operations
> with bp0.
> With your current code, the call to VecView should produce an error if you
> used the error checking macro CHKERRQ(ierr) (as should VecScatter{Begin,End}
> Thanks,
>   Dave
>>      print*,"done! "
>>      CHKERRQ(ierr)
>> endif
>>    ! call VecScatterBegin(ctr,bp0,bp2,INSERT_VALUES,SCATTER_REVERSE,ierr)
>>    !  call VecScatterEnd(ctr,bp0,bp2,INSERT_VALUES,SCATTER_REVERSE,ierr)
>>   call VecView(bp2,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>   call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>>   call exit()
>> And the output is: (with bp the right answer)
>> Vec Object:bp: 2 MPI processes
>>   type: mpi
>> Process [0]
>> 1.
>> 2.
>> Process [1]
>> 4.
>> 3.
>> Vec Object:bp2: 2 MPI processes  *(before scatter)*
>>   type: mpi
>> Process [0]
>> 0.
>> 0.
>> Process [1]
>> 0.
>> 0.
>> Vec Object:bp0: 1 MPI processes
>>   type: seq
>> 1.
>> 2.
>> 4.
>> 3.
>>  done!
>> Vec Object:bp2: 2 MPI processes  *(after scatter)*
>>   type: mpi
>> Process [0]
>> 1.
>> 2.
>> *Process [1]*
>> *0.*
>> *0.*
>> Thanks inmensely for your help,
>> Manuel
>> On Thu, Jan 5, 2017 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > On Jan 5, 2017, at 6:21 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > Hello Devs is me again,
>>> > I'm trying to distribute a vector to all called processes, the vector
>>> would be originally in root as a sequential vector and i would like to
>>> scatter it, what would the best call to do this ?
>>> > I already know how to gather a distributed vector to root with
>>> VecScatterCreateToZero, this would be the inverse operation,
>>>    Use the same VecScatter object but with SCATTER_REVERSE, not you need
>>> to reverse the two vector arguments as well.
>>> > i'm currently trying with VecScatterCreate() and as of now im doing
>>> the following:
>>> > if(rank==0)then
>>> >      call VecCreate(PETSC_COMM_SELF,bp0,ierr); CHKERRQ(ierr) !if i
>>> use WORLD
>>> >                                                              !freezes
>>> in SetSizes
>>> >      call VecSetSizes(bp0,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>> >      call VecSetType(bp0,VECSEQ,ierr)
>>> >      call VecSetFromOptions(bp0,ierr); CHKERRQ(ierr)
>>> >      !call VecSet(bp0,5.0D0,ierr); CHKERRQ(ierr)
>>> !rhs
>>> >      do i=0,nbdp-1,1
>>> >         ind(i+1) = i
>>> >      enddo
>>> >      call ISCreateGeneral(PETSC_COMM_SELF,nbdp,ind,PETSC_COPY_VALUES,l
>>> ocis,ierr)
>>> >     !call VecScatterCreate(bp0,PETSC_NULL_OBJECT,bp2,is,ctr,ierr) !if
>>> i use SELF
>>>  !freezes here.
>>> >      call VecScatterCreate(bp0,locis,bp2,PETSC_NULL_OBJECT,ctr,ierr)
>>> > endif
>>> > bp2 being the receptor MPI vector to scatter to
>>> > But it freezes in VecScatterCreate when trying to use more than one
>>> processor, what would be a better approach ?
>>> > Thanks once again,
>>> > Manuel
>>> > On Wed, Jan 4, 2017 at 3:30 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > Thanks i had no idea how to debug and read those logs, that solved
>>> this issue at least (i was sending a message from root to everyone else,
>>> but trying to catch from everyone else including root)
>>> > Until next time, many thanks,
>>> > Manuel
>>> > On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > I did a PetscBarrier just before calling the vicariate routine and im
>>> pretty sure im calling it from every processor, code looks like this:
>>> > From the gdb trace.
>>> >   Proc 0: Is in some MPI routine you call yourself, line 113
>>> >   Proc 1: Is in VecCreate(), line 130
>>> > You need to fix your communication code.
>>> >    Matt
>>> > print*,'entering POInit from',rank
>>> > !call exit()
>>> > call PetscObjsInit()
>>> > And output gives:
>>> >  entering POInit from           0
>>> >  entering POInit from           1
>>> >  entering POInit from           2
>>> >  entering POInit from           3
>>> > Still hangs in the same way,
>>> > Thanks,
>>> > Manuel
>>> > On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > Thanks for the answers !
>>> > heres the screenshot of what i got from bt in gdb (great hint in how
>>> to debug in petsc, didn't know that)
>>> > I don't really know what to look at here,
>>> > Thanks,
>>> > Manuel
>>> > On Wed, Jan 4, 2017 at 2:39 PM, Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>> > Are you certain ALL ranks in PETSC_COMM_WORLD call these function(s).
>>> These functions cannot be inside if statements like
>>> > if (rank == 0){
>>> >   VecCreateMPI(...)
>>> > On Wed, 4 Jan 2017 at 23:34, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > Thanks Dave for the quick answer, appreciate it,
>>> > I just tried that and it didn't make a difference, any other
>>> suggestions ?
>>> > Thanks,
>>> > Manuel
>>> > On Wed, Jan 4, 2017 at 2:29 PM, Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>> > You need to swap the order of your function calls.
>>> > Call VecSetSizes() before VecSetType()
>>> > Thanks,
>>> >   Dave
>>> > On Wed, 4 Jan 2017 at 23:21, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>> > Hello all, happy new year,
>>> > I'm working on parallelizing my code, it worked and provided some
>>> results when i just called more than one processor, but created artifacts
>>> because i didn't need one image of the whole program in each processor,
>>> conflicting with each other.
>>> > Since the pressure solver is the main part i need in parallel im
>>> chosing mpi to run everything in root processor until its time to solve for
>>> pressure, at this point im trying to create a distributed vector using
>>> either
>>> >      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,nbdp,xp,ierr)
>>> > or
>>> >      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>> >      call VecSetType(xp,VECMPI,ierr)
>>> >      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>> > In both cases program hangs at this point, something it never happened
>>> on the naive way i described before. I've made sure the global size, nbdp,
>>> is the same in every processor. What can be wrong?
>>> > Thanks for your kind help,
>>> > Manuel.
>>> > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170106/1d99018c/attachment-0001.html>
