[petsc-users] problems after glibc upgrade to 2.17-157
Fri Jan 6 10:11:37 CST 2017
On Fri, 6 Jan 2017, Klaij, Christiaan wrote:
> Satish,
> Our sysadmin is not keen on downgrading glibc.
sure
> I'll stick with "--with-shared-libraries=0" for now
thats fine.
> and wait for SL7.3 with intel 17.
Well they are not related so if you can - you should upgrade to
intel-17 [irrespective SL7.2 or 7.3]
> Thanks for filing the bugreport at RHEL, very curious to see their response.
There is a response with reference to previous report
https://bugzilla.redhat.com/show_bug.cgi?id=1377895
[with reference to libintlc.so.5 as the cause - its using some wierd/invalid format]
A workarround for existing intel-16 precompiled binaries is mentioned.
LD_PRELOAD=/lib64/libc.so.6:/opt/intel/16.0/compiler/lib/intel64/libintlc.so.5 icc-compiled-binary
This does not help with PETSc build - which uses non-icc binaries
during the build. [they break with this LD_PRELOAD]
If intel-16 is really required - I found that replacing libintlc.so.5
in intel-16 with the one from intel-17 lets me use intel-16 compilers
[for ex: building PETSc]. I haven't tested this extensively to see if
there are any breakages with this approach..
Satish
