[petsc-users] Best way to scatter a Seq vector ?
Manuel Valera mvalera at mail.sdsu.edu
Thu Jan 5 18:21:39 CST 2017
Hello Devs is me again,
I'm trying to distribute a vector to all called processes, the vector would
be originally in root as a sequential vector and i would like to scatter
it, what would the best call to do this ?
I already know how to gather a distributed vector to root with
VecScatterCreateToZero, this would be the inverse operation, i'm currently
trying with VecScatterCreate() and as of now im doing the following:
if(rank==0)then
     call VecCreate(PETSC_COMM_SELF,bp0,ierr); CHKERRQ(ierr) !if i use
WORLD
                                                             !freezes in
SetSizes
     call VecSetSizes(bp0,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
     call VecSetType(bp0,VECSEQ,ierr)
     call VecSetFromOptions(bp0,ierr); CHKERRQ(ierr)
     call VecSetValues(bp0,nbdp,ind,Rhs,INSERT_VALUES,ierr)
     !call VecSet(bp0,5.0D0,ierr); CHKERRQ(ierr)
     call VecView(bp0,PETSC_VIEWER_STDOUT_WORLD,ierr)
     call VecAssemblyBegin(bp0,ierr) ; call VecAssemblyEnd(bp0,ierr) !rhs
     do i=0,nbdp-1,1
        ind(i+1) = i
     enddo
     call
ISCreateGeneral(PETSC_COMM_SELF,nbdp,ind,PETSC_COPY_VALUES,locis,ierr)
    !call VecScatterCreate(bp0,PETSC_NULL_OBJECT,bp2,is,ctr,ierr) !if i use
SELF
        !freezes
here.
     call VecScatterCreate(bp0,locis,bp2,PETSC_NULL_OBJECT,ctr,ierr)
endif
bp2 being the receptor MPI vector to scatter to
But it freezes in VecScatterCreate when trying to use more than one
processor, what would be a better approach ?
Thanks once again,
Manuel
On Wed, Jan 4, 2017 at 3:30 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Thanks i had no idea how to debug and read those logs, that solved this
> issue at least (i was sending a message from root to everyone else, but
> trying to catch from everyone else including root)
> Until next time, many thanks,
> Manuel
> On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>> wrote:
>>> I did a PetscBarrier just before calling the vicariate routine and im
>>> pretty sure im calling it from every processor, code looks like this:
>> From the gdb trace.
>>   Proc 0: Is in some MPI routine you call yourself, line 113
>>   Proc 1: Is in VecCreate(), line 130
>> You need to fix your communication code.
>>    Matt
>>> call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>>> print*,'entering POInit from',rank
>>> !call exit()
>>> call PetscObjsInit()
>>> And output gives:
>>>  entering POInit from           0
>>>  entering POInit from           1
>>>  entering POInit from           2
>>>  entering POInit from           3
>>> Still hangs in the same way,
>>> Thanks,
>>> Manuel
>>> On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>>> Thanks for the answers !
>>>> heres the screenshot of what i got from bt in gdb (great hint in how to
>>>> debug in petsc, didn't know that)
>>>> I don't really know what to look at here,
>>>> Thanks,
>>>> Manuel
>>>> On Wed, Jan 4, 2017 at 2:39 PM, Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> Are you certain ALL ranks in PETSC_COMM_WORLD call these function(s).
>>>>> These functions cannot be inside if statements like
>>>>> if (rank == 0){
>>>>>   VecCreateMPI(...)
>>>>> On Wed, 4 Jan 2017 at 23:34, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>> wrote:
>>>>>> Thanks Dave for the quick answer, appreciate it,
>>>>>> I just tried that and it didn't make a difference, any other
>>>>>> suggestions ?
>>>>>> Thanks,
>>>>>> Manuel
>>>>>> On Wed, Jan 4, 2017 at 2:29 PM, Dave May <dave.mayhem23 at gmail.com>
>>>>>> wrote:
>>>>>> You need to swap the order of your function calls.
>>>>>> Call VecSetSizes() before VecSetType()
>>>>>> Thanks,
>>>>>>   Dave
>>>>>> On Wed, 4 Jan 2017 at 23:21, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>> wrote:
>>>>>> Hello all, happy new year,
>>>>>> I'm working on parallelizing my code, it worked and provided some
>>>>>> results when i just called more than one processor, but created artifacts
>>>>>> because i didn't need one image of the whole program in each processor,
>>>>>> conflicting with each other.
>>>>>> Since the pressure solver is the main part i need in parallel im
>>>>>> chosing mpi to run everything in root processor until its time to solve for
>>>>>> pressure, at this point im trying to create a distributed vector using
>>>>>> either
>>>>>>      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,nbdp,xp,ierr)
>>>>>> or
>>>>>>      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>>>      call VecSetType(xp,VECMPI,ierr)
>>>>>>      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>>>>> In both cases program hangs at this point, something it never
>>>>>> happened on the naive way i described before. I've made sure the global
>>>>>> size, nbdp, is the same in every processor. What can be wrong?
>>>>>> Thanks for your kind help,
>>>>>> Manuel.
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170105/60993fdc/attachment-0001.html>
