[petsc-users] Fieldsplit with sub pc MUMPS in parallel
Karin&NiKo niko.karin at gmail.com
Thu Jan 5 10:36:04 CST 2017
Dave,
Indeed the residual histories differ. Concerning the IS's, I have checked
them on small cases, so that I am quite sure they are OK.
What could I do with PETSc to evaluate the ill-conditioning of the system
or of the sub-systems?
Thanks again for your help,
Nicolas
2017-01-05 15:46 GMT+01:00 Barry Smith <bsmith at mcs.anl.gov>:
> > On Jan 5, 2017, at 5:58 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> > Do you now see identical residual histories for a job using 1 rank and 4
> ranks?
>    Please send the residual histories with the extra options, I'm curious
> too, because a Krylov method should not be needed in the inner solve, I
> just asked for it so we can see what the residuals look like.
>    Barry
> > If not, I am inclined to believe that the IS's you are defining for the
> splits in the parallel case are incorrect. The operator created to
> approximate the Schur complement with selfp should not depend on  the
> number of ranks.
> > Or possibly your problem is horribly I'll-conditioned. If it is, then
> this could result in slightly different residual histories when using
> different numbers of ranks - even if the operators are in fact identical
> > Thanks,
> >   Dave
> > On Thu, 5 Jan 2017 at 12:14, Karin&NiKo <niko.karin at gmail.com> wrote:
> > Dear Barry, dear Dave,
> > THANK YOU!
> > You two pointed out the right problem.By using the options you provided
> (-fieldsplit_0_ksp_type gmres -fieldsplit_0_ksp_pc_side right
> -fieldsplit_1_ksp_type gmres -fieldsplit_1_ksp_pc_side right), the solver
> converges in 3 iterations whatever the size of the communicator.
> > All the trick is in the precise resolution of the Schur complement, by
> using a Krylov method (and not only preonly) *and* applying the
> preconditioner on the right (so evaluating the convergence on the
> unpreconditioned residual).
> > @Barry : the difference you see on the nonzero allocations for the
> different runs is just an artefact : when using more than one proc, we
> slighly over-estimate the number of non-zero terms. If I run the same
> problem with the -info option, I get extra information :
> > [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 110 X 110; storage space: 0
> unneeded,5048 used
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 271 X 271; storage space: 4249
> unneeded,26167 used
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 307 X 307; storage space: 7988
> unneeded,31093 used
> > [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 110 X 244; storage space: 0
> unneeded,6194 used
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 271 X 233; storage space: 823
> unneeded,9975 used
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 307 X 197; storage space: 823
> unneeded,8263 used
> > And 5048+26167+31093+6194+9975+8263=86740 which is the number of
> exactly estimated nonzero terms for 1 proc.
> > Thank you again!
> > Best regards,
> > Nicolas
> > 2017-01-05 1:36 GMT+01:00 Barry Smith <bsmith at mcs.anl.gov>:
> >    There is something wrong with your set up.
> > 1 process
> >            total: nonzeros=140616, allocated nonzeros=140616
> >           total: nonzeros=68940, allocated nonzeros=68940
> >                 total: nonzeros=3584, allocated nonzeros=3584
> >                 total: nonzeros=1000, allocated nonzeros=1000
> >                 total: nonzeros=8400, allocated nonzeros=8400
> > 2 processes
> >                 total: nonzeros=146498, allocated nonzeros=146498
> >           total: nonzeros=73470, allocated nonzeros=73470
> >                 total: nonzeros=3038, allocated nonzeros=3038
> >                 total: nonzeros=1110, allocated nonzeros=1110
> >                 total: nonzeros=6080, allocated nonzeros=6080
> >           total: nonzeros=2846, allocated nonzeros=2846
> >     total: nonzeros=86740, allocated nonzeros=94187
> >   It looks like you are setting up the problem differently in parallel
> and seq. If it is suppose to be an identical problem then the number
> nonzeros should be the same in at least the first two matrices.
> > > On Jan 4, 2017, at 3:39 PM, Karin&NiKo <niko.karin at gmail.com> wrote:
> > > Dear Petsc team,
> > > I am (still) trying to solve Biot's poroelasticity problem :
> > >  <image.png>
> > > I am using a mixed P2-P1 finite element discretization. The matrix of
> the discretized system in binary format is attached to this email.
> > > I am using the fieldsplit framework to solve the linear system. Since
> I am facing some troubles, I have decided to go back to simple things. Here
> are the options I am using :
> > > -ksp_rtol 1.0e-5
> > > -ksp_type fgmres
> > > -pc_type fieldsplit
> > > -pc_fieldsplit_schur_factorization_type full
> > > -pc_fieldsplit_type schur
> > > -pc_fieldsplit_schur_precondition selfp
> > > -fieldsplit_0_pc_type lu
> > > -fieldsplit_0_pc_factor_mat_solver_package mumps
> > > -fieldsplit_0_ksp_type preonly
> > > -fieldsplit_0_ksp_converged_reason
> > > -fieldsplit_1_pc_type lu
> > > -fieldsplit_1_pc_factor_mat_solver_package mumps
> > > -fieldsplit_1_ksp_type preonly
> > > -fieldsplit_1_ksp_converged_reason
> > > On a single proc, everything runs fine : the solver converges in 3
> iterations, according to the theory (see Run-1-proc.txt [contains
> -log_view]).
> > > On 2 procs, the solver converges in 28 iterations (see Run-2-proc.txt).
> > > On 3 procs, the solver converges in 91 iterations (see Run-3-proc.txt).
> > > I do not understand this behavior : since MUMPS is a parallel direct
> solver, shouldn't the solver converge in max 3 iterations whatever the
> number of procs?
> > > Thanks for your precious help,
> > > Nicolas
> > > <Run-1-proc.txt><Run-2-proc.txt><Run-3-proc.txt><1_Warning.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170105/ff8c549e/attachment-0001.html>
  0 KSP unpreconditioned resid norm 2.375592557658e+10 true resid norm 2.375592557658e+10 ||r(i)||/||b|| 1.000000000000e+00
    Residual norms for fieldsplit_1_ solve.
    0 KSP Residual norm 0.000000000000e+00
  Linear fieldsplit_1_ solve converged due to CONVERGED_ATOL iterations 0
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 1.000000000000e+00
    1 KSP Residual norm 4.313410630558e-15
  1 KSP unpreconditioned resid norm 6.190344827565e+04 true resid norm 6.190344827565e+04 ||r(i)||/||b|| 2.605810835536e-06
    0 KSP Residual norm 4.407021980813e+05
    1 KSP Residual norm 1.553056052550e-09
    1 KSP Residual norm 1.810321861046e-01
    0 KSP Residual norm 4.443756559170e+05
    1 KSP Residual norm 6.852859005090e-10
    2 KSP Residual norm 4.110160641015e-02
    0 KSP Residual norm 3.459077029344e+05
    1 KSP Residual norm 3.391519472149e-10
    3 KSP Residual norm 9.399363055282e-03
    0 KSP Residual norm 4.045754196688e+05
    1 KSP Residual norm 4.488756555375e-10
    4 KSP Residual norm 1.571092856159e-03
    0 KSP Residual norm 3.162336928973e+05
    1 KSP Residual norm 2.684362494425e-10
    5 KSP Residual norm 1.963417150656e-04
    0 KSP Residual norm 3.145763546913e+05
    1 KSP Residual norm 1.680082274413e-10
    6 KSP Residual norm 2.086077021964e-05
    0 KSP Residual norm 2.507749963975e+05
    1 KSP Residual norm 1.773409123937e-10
    7 KSP Residual norm 2.638900162683e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
    0 KSP Residual norm 2.087534725346e+05
    1 KSP Residual norm 8.396841831477e-10
  2 KSP unpreconditioned resid norm 1.633570314420e-01 true resid norm 1.633570534028e-01 ||r(i)||/||b|| 6.876476055467e-12
KSP Object: 1 MPI processes
  type: fgmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=1000, initial guess is zero
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization UPPER
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: fgmres
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: nd
          factor fill ratio given 0., needed 0.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=624, cols=624
                package used to perform factorization: mumps
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   0
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):                         1
                    ICNTL(13) (efficiency control):                         0
                    ICNTL(14) (percentage of estimated workspace increase): 20
                    ICNTL(18) (input mat struct):                           0
                    ICNTL(19) (Shur complement info):                       0
                    ICNTL(20) (rhs sparse pattern):                         0
                    ICNTL(21) (solution struct):                            0
                    ICNTL(22) (in-core/out-of-core facility):               0
                    ICNTL(23) (max size of memory can be allocated locally):0
                    ICNTL(24) (detection of null pivot rows):               0
                    ICNTL(25) (computation of a null space basis):          0
                    ICNTL(26) (Schur options for rhs or solution):          0
                    ICNTL(27) (experimental parameter):                     -32
                    ICNTL(28) (use parallel or sequential ordering):        1
                    ICNTL(29) (parallel ordering):                          0
                    ICNTL(30) (user-specified set of entries in inv(A)):    0
                    ICNTL(31) (factors is discarded in the solve phase):    0
                    ICNTL(33) (compute determinant):                        0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absolute pivoting threshold):      0.
                    CNTL(4) (value of static pivoting):         -1.
                    CNTL(5) (fixation for null pivots):         0.
                    RINFO(1) (local estimated flops for the elimination after analysis):
                      [0] 1.99982e+07
                    RINFO(2) (local estimated flops for the assembly after factorization):
                      [0]  153549.
                    RINFO(3) (local estimated flops for the elimination after factorization):
                      [0]  1.99982e+07
                    INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                    [0] 3
                    INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                      [0] 3
                    INFO(23) (num of pivots eliminated on this processor after factorization):
                      [0] 624
                    RINFOG(1) (global estimated flops for the elimination after analysis): 1.99982e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 153549.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 1.99982e+07
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 140616
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 4995
                    INFOG(5) (estimated maximum front size in the complete tree): 252
                    INFOG(6) (number of nodes in the complete tree): 23
                    INFOG(7) (ordering option effectively use after analysis): 2
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 140616
                    INFOG(10) (total integer space store the matrix factors after factorization): 4995
                    INFOG(11) (order of largest frontal matrix after factorization): 252
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 3
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 3
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 3
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 3
                    INFOG(20) (estimated number of entries in the factors): 140616
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 3
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 3
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 140616
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 2, 2
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): 7
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         1 MPI processes
          type: seqaij
          rows=624, cols=624
            using I-node routines: found 208 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: lu
          matrix ordering: nd
                type: seqaij
                rows=64, cols=64
                      [0] 123808.
                      [0]  1024.
                      [0]  123808.
                    [0] 1
                      [0] 1
                      [0] 64
                    RINFOG(1) (global estimated flops for the elimination after analysis): 123808.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1024.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 123808.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3584
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 222
                    INFOG(5) (estimated maximum front size in the complete tree): 48
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3584
                    INFOG(10) (total integer space store the matrix factors after factorization): 222
                    INFOG(11) (order of largest frontal matrix after factorization): 48
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 1
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 1
                    INFOG(20) (estimated number of entries in the factors): 3584
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 1
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3584
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          type: schurcomplement
          rows=64, cols=64
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
                rows=64, cols=64
                  not using I-node routines
            A10
                type: seqaij
                rows=64, cols=624
            KSP of A00
                type: fgmres
                type: lu
                  matrix ordering: nd
                        type: seqaij
                        rows=624, cols=624
                              [0] 1.99982e+07
                              [0]  153549.
                              [0]  1.99982e+07
                            [0] 3
                              [0] 3
                              [0] 624
                  type: seqaij
                  rows=624, cols=624
            A01
                type: seqaij
                rows=624, cols=64
          type: seqaij
          rows=64, cols=64
          total: nonzeros=2744, allocated nonzeros=2744
            using I-node routines: found 28 nodes, limit used is 5
    type: seqaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=86740
    0 KSP Residual norm 5.937865172382e-02
    0 KSP Residual norm 4.234217463695e+01
    1 KSP Residual norm 3.118700901238e-14
    1 KSP Residual norm 5.933157534122e-02
    0 KSP Residual norm 1.551000577788e+02
    1 KSP Residual norm 1.093099680676e-13
    2 KSP Residual norm 4.547416945551e-02
    0 KSP Residual norm 1.737103989449e+01
    1 KSP Residual norm 1.028451435945e-14
    3 KSP Residual norm 4.536313349461e-02
    0 KSP Residual norm 2.076405285175e+01
    1 KSP Residual norm 1.273088385228e-14
    4 KSP Residual norm 4.508959132560e-02
    0 KSP Residual norm 2.776609322045e+01
    1 KSP Residual norm 1.223256724488e-14
    5 KSP Residual norm 4.326575141601e-02
    0 KSP Residual norm 3.629553485051e+01
    1 KSP Residual norm 2.354296902115e-14
    6 KSP Residual norm 3.936112364961e-02
    0 KSP Residual norm 1.975372549146e+01
    1 KSP Residual norm 1.108812883295e-14
    7 KSP Residual norm 2.851493746707e-02
    0 KSP Residual norm 2.189629983813e+01
    1 KSP Residual norm 1.321171004401e-14
    8 KSP Residual norm 2.641045917065e-02
    0 KSP Residual norm 5.000370968172e+01
    1 KSP Residual norm 3.111931447011e-14
    9 KSP Residual norm 2.589794225526e-02
    0 KSP Residual norm 3.582922395480e+01
    1 KSP Residual norm 2.124772509356e-14
   10 KSP Residual norm 1.702204742288e-02
    0 KSP Residual norm 1.033329772194e+01
    1 KSP Residual norm 5.205672206586e-15
   11 KSP Residual norm 1.697748745328e-02
    0 KSP Residual norm 3.058818490130e+01
    1 KSP Residual norm 1.676089941959e-14
   12 KSP Residual norm 1.474477289739e-02
    0 KSP Residual norm 1.512605566330e+01
    1 KSP Residual norm 1.101013330523e-14
   13 KSP Residual norm 7.993867975878e-03
    0 KSP Residual norm 3.908076291684e+01
    1 KSP Residual norm 2.142452615562e-14
   14 KSP Residual norm 6.629219736366e-03
    0 KSP Residual norm 1.192268282659e+01
    1 KSP Residual norm 9.502213484402e-15
   15 KSP Residual norm 6.052348486548e-03
    0 KSP Residual norm 5.453321213362e+01
    1 KSP Residual norm 3.272046064366e-14
   16 KSP Residual norm 4.020336463565e-03
    0 KSP Residual norm 9.784852832330e+00
    1 KSP Residual norm 4.860790727577e-15
   17 KSP Residual norm 2.549661912882e-03
    0 KSP Residual norm 1.032060539012e+01
    1 KSP Residual norm 5.409446981951e-15
   18 KSP Residual norm 2.545838697911e-03
    0 KSP Residual norm 3.615049979264e+01
    1 KSP Residual norm 1.933081342600e-14
   19 KSP Residual norm 1.887748224202e-03
    0 KSP Residual norm 7.863199580723e+00
    1 KSP Residual norm 4.154361434029e-15
   20 KSP Residual norm 7.717282078825e-04
    0 KSP Residual norm 4.443583386855e+01
    1 KSP Residual norm 2.580291980533e-14
   21 KSP Residual norm 2.423723070704e-04
    0 KSP Residual norm 1.942812936843e+01
    1 KSP Residual norm 1.166564006857e-14
   22 KSP Residual norm 6.757780242449e-05
    0 KSP Residual norm 1.466822334895e+01
    1 KSP Residual norm 8.386112126578e-15
   23 KSP Residual norm 2.265569464460e-05
    0 KSP Residual norm 1.961396757334e+01
    1 KSP Residual norm 1.495066107508e-14
   24 KSP Residual norm 5.899547964062e-06
    0 KSP Residual norm 1.160271694698e+01
    1 KSP Residual norm 7.056918950209e-15
   25 KSP Residual norm 1.575417880059e-06
    0 KSP Residual norm 2.455608530437e+01
    1 KSP Residual norm 1.644989124097e-14
   26 KSP Residual norm 4.026925350528e-07
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 26
    0 KSP Residual norm 9.386097125234e-01
    1 KSP Residual norm 1.605159181466e-15
  1 KSP unpreconditioned resid norm 4.441623086433e+09 true resid norm 4.441623086433e+09 ||r(i)||/||b|| 1.869690605030e-01
    0 KSP Residual norm 9.995733040893e-01
    0 KSP Residual norm 2.454918438859e+01
    1 KSP Residual norm 1.223419335125e-14
    1 KSP Residual norm 9.944523252125e-01
    0 KSP Residual norm 1.583995535156e+02
    1 KSP Residual norm 8.825640694457e-14
    2 KSP Residual norm 8.949281315445e-01
    0 KSP Residual norm 3.226784992842e+01
    1 KSP Residual norm 2.614144737961e-14
    3 KSP Residual norm 8.933447355096e-01
    0 KSP Residual norm 2.396572368493e+01
    1 KSP Residual norm 1.229693916841e-14
    4 KSP Residual norm 8.214589151615e-01
    0 KSP Residual norm 2.235328400341e+01
    1 KSP Residual norm 1.043544686072e-14
    5 KSP Residual norm 5.263010202342e-01
    0 KSP Residual norm 2.734218208288e+01
    1 KSP Residual norm 1.882179620447e-14
    6 KSP Residual norm 4.783501706809e-01
    0 KSP Residual norm 1.797826701278e+01
    1 KSP Residual norm 8.815613165812e-15
    7 KSP Residual norm 4.766735056010e-01
    0 KSP Residual norm 1.378301418359e+01
    1 KSP Residual norm 7.112099880638e-15
    8 KSP Residual norm 3.972131687194e-01
    0 KSP Residual norm 8.309752053339e+00
    1 KSP Residual norm 4.727621077237e-15
    9 KSP Residual norm 3.792263297146e-01
    0 KSP Residual norm 4.566574961568e+00
    1 KSP Residual norm 2.476526063026e-15
   10 KSP Residual norm 3.408233654575e-01
    0 KSP Residual norm 1.954137437840e+01
    1 KSP Residual norm 9.786196116090e-15
   11 KSP Residual norm 2.642739341639e-01
    0 KSP Residual norm 5.235692697522e+01
    1 KSP Residual norm 2.984886822060e-14
   12 KSP Residual norm 2.575125899492e-01
    0 KSP Residual norm 3.132368047040e+01
    1 KSP Residual norm 1.722885597134e-14
   13 KSP Residual norm 1.403660227010e-01
    0 KSP Residual norm 6.714687023560e+01
    1 KSP Residual norm 3.125740341553e-14
   14 KSP Residual norm 7.177870026278e-02
    0 KSP Residual norm 3.261683387580e+00
    1 KSP Residual norm 1.978759574236e-15
   15 KSP Residual norm 5.005112707018e-02
    0 KSP Residual norm 5.419699934297e+01
    1 KSP Residual norm 3.831022881510e-14
   16 KSP Residual norm 4.942664995089e-02
    0 KSP Residual norm 1.048711823470e+01
    1 KSP Residual norm 6.225736356283e-15
   17 KSP Residual norm 2.551613762746e-02
    0 KSP Residual norm 1.269449392975e+01
    1 KSP Residual norm 6.869644736488e-15
   18 KSP Residual norm 1.175268249018e-02
    0 KSP Residual norm 2.634428310012e+01
    1 KSP Residual norm 1.159312925122e-14
   19 KSP Residual norm 9.914714704583e-03
    0 KSP Residual norm 2.295339266370e+01
    1 KSP Residual norm 1.443683776456e-14
   20 KSP Residual norm 9.398895997393e-03
    0 KSP Residual norm 4.839116504759e+01
    1 KSP Residual norm 2.898144099453e-14
   21 KSP Residual norm 4.572179069537e-03
    0 KSP Residual norm 1.460918536613e+01
    1 KSP Residual norm 8.358504740258e-15
   22 KSP Residual norm 1.720926954498e-03
    0 KSP Residual norm 9.505332571786e+00
    1 KSP Residual norm 5.136221996807e-15
   23 KSP Residual norm 5.546608543469e-04
    0 KSP Residual norm 9.855169634997e+00
    1 KSP Residual norm 6.085063593122e-15
   24 KSP Residual norm 1.225330068103e-04
    0 KSP Residual norm 4.658392935709e+01
    1 KSP Residual norm 2.921900986545e-14
   25 KSP Residual norm 3.155201041607e-05
    0 KSP Residual norm 2.059617562808e+01
    1 KSP Residual norm 9.566032504495e-15
   26 KSP Residual norm 1.035291641520e-05
    0 KSP Residual norm 1.916173965386e+01
    1 KSP Residual norm 1.270318519153e-14
   27 KSP Residual norm 3.422078169478e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 27
    0 KSP Residual norm 3.452631488055e+00
    1 KSP Residual norm 3.295757024840e-15
  2 KSP unpreconditioned resid norm 1.553990983947e+04 true resid norm 1.553990984101e+04 ||r(i)||/||b|| 6.541487845177e-07
KSP Object: 2 MPI processes
  type: fgmres
PC Object: 2 MPI processes
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       2 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_0_)       2 MPI processes
        type: lu
          matrix ordering: natural
              Mat Object:               2 MPI processes
                type: mpiaij
                rows=624, cols=624
                    ICNTL(18) (input mat struct):                           3
                    ICNTL(21) (solution struct):                            1
                      [0] 1.51255e+07
                      [1] 6.89106e+06
                      [0]  87833.
                      [1]  72313.
                      [0]  1.51255e+07
                      [1]  6.89106e+06
                    [0] 8
                    [1] 8
                      [0] 8
                      [1] 8
                      [0] 413
                      [1] 211
                    RINFOG(1) (global estimated flops for the elimination after analysis): 2.20165e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 160146.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 2.20165e+07
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 146498
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 5065
                    INFOG(5) (estimated maximum front size in the complete tree): 263
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 146498
                    INFOG(10) (total integer space store the matrix factors after factorization): 5065
                    INFOG(11) (order of largest frontal matrix after factorization): 263
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 8
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 16
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 8
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 16
                    INFOG(20) (estimated number of entries in the factors): 146498
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 8
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 15
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 146498
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 2, 3
        Mat Object:        (fieldsplit_0_)         2 MPI processes
          type: mpiaij
          rows=624, cols=624
            using I-node (on process 0) routines: found 112 nodes, limit used is 5
      KSP Object:      (fieldsplit_1_)       2 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_1_)       2 MPI processes
        type: lu
                type: mpiaij
                rows=64, cols=64
                      [0] 71763.
                      [1] 15274.
                      [0]  1205.
                      [1]  256.
                      [0]  71763.
                      [1]  15274.
                    [0] 1
                    [1] 1
                      [0] 1
                      [1] 1
                      [0] 52
                      [1] 12
                    RINFOG(1) (global estimated flops for the elimination after analysis): 87037.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1461.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 87037.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3038
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 318
                    INFOG(5) (estimated maximum front size in the complete tree): 45
                    INFOG(6) (number of nodes in the complete tree): 4
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3038
                    INFOG(10) (total integer space store the matrix factors after factorization): 318
                    INFOG(11) (order of largest frontal matrix after factorization): 45
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 2
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 2
                    INFOG(20) (estimated number of entries in the factors): 3038
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 2
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3038
        Mat Object:        (fieldsplit_1_)         2 MPI processes
          rows=64, cols=64
            A11
                type: mpiaij
                rows=64, cols=64
                  not using I-node (on process 0) routines
            A10
                type: mpiaij
                rows=64, cols=624
            KSP of A00
                type: fgmres
                type: lu
                        type: mpiaij
                        rows=624, cols=624
                              [0] 1.51255e+07
                              [1] 6.89106e+06
                              [0]  87833.
                              [1]  72313.
                              [0]  1.51255e+07
                              [1]  6.89106e+06
                            [0] 8
                            [1] 8
                              [0] 8
                              [1] 8
                              [0] 413
                              [1] 211
                  type: mpiaij
                  rows=624, cols=624
            A01
                type: mpiaij
                rows=624, cols=64
                  using I-node (on process 0) routines: found 111 nodes, limit used is 5
          type: mpiaij
          rows=64, cols=64
            using I-node (on process 0) routines: found 37 nodes, limit used is 5
    type: mpiaij
    rows=688, cols=688
      using I-node (on process 0) routines: found 117 nodes, limit used is 5
    0 KSP Residual norm 2.647227604295e-01
    0 KSP Residual norm 2.563845763796e+01
    1 KSP Residual norm 1.590629734547e-14
    1 KSP Residual norm 2.605565139600e-01
    0 KSP Residual norm 1.909035314623e+02
    1 KSP Residual norm 2.267826634834e-13
    2 KSP Residual norm 2.250585637608e-01
    0 KSP Residual norm 6.330887927554e+01
    1 KSP Residual norm 6.513658585363e-14
    3 KSP Residual norm 2.208000740627e-01
    0 KSP Residual norm 5.561164381969e+01
    1 KSP Residual norm 3.969087970696e-14
    4 KSP Residual norm 1.869828337939e-01
    0 KSP Residual norm 1.153388606860e+01
    1 KSP Residual norm 5.713318140590e-15
    5 KSP Residual norm 1.794036720446e-01
    0 KSP Residual norm 5.781962412388e+00
    1 KSP Residual norm 3.300831086316e-15
    6 KSP Residual norm 1.561653176489e-01
    0 KSP Residual norm 4.495691274322e+01
    1 KSP Residual norm 2.376574086230e-14
    7 KSP Residual norm 1.560891088246e-01
    0 KSP Residual norm 6.979404438790e+01
    1 KSP Residual norm 4.591614152870e-14
    8 KSP Residual norm 1.395166058530e-01
    0 KSP Residual norm 6.619352784224e+01
    1 KSP Residual norm 3.919850310257e-14
    9 KSP Residual norm 1.220617129680e-01
    0 KSP Residual norm 5.928236375030e+01
    1 KSP Residual norm 4.743493991329e-14
   10 KSP Residual norm 1.218069676114e-01
    0 KSP Residual norm 4.028882510371e+01
    1 KSP Residual norm 2.263693695029e-14
   11 KSP Residual norm 1.050411964537e-01
    0 KSP Residual norm 8.854058069775e+01
    1 KSP Residual norm 5.292366071944e-14
   12 KSP Residual norm 9.809355206907e-02
    0 KSP Residual norm 7.639593572920e+01
    1 KSP Residual norm 4.085666194460e-14
   13 KSP Residual norm 9.365799197733e-02
    0 KSP Residual norm 3.203422670496e+01
    1 KSP Residual norm 2.135526921770e-14
   14 KSP Residual norm 8.796649024171e-02
    0 KSP Residual norm 9.851329263544e+00
    1 KSP Residual norm 6.772567754349e-15
   15 KSP Residual norm 6.733987269492e-02
    0 KSP Residual norm 1.766565466183e+01
    1 KSP Residual norm 1.075817081759e-14
   16 KSP Residual norm 5.509826260896e-02
    0 KSP Residual norm 4.983496450668e+01
    1 KSP Residual norm 2.820060590514e-14
   17 KSP Residual norm 3.150107095478e-02
    0 KSP Residual norm 1.081910220332e+01
    1 KSP Residual norm 6.000725096350e-15
   18 KSP Residual norm 3.129419737054e-02
    0 KSP Residual norm 2.808540096114e+01
    1 KSP Residual norm 1.456892648344e-14
   19 KSP Residual norm 2.649702912434e-02
    0 KSP Residual norm 3.203107785732e+01
    1 KSP Residual norm 1.755306403735e-14
   20 KSP Residual norm 2.648345476991e-02
    0 KSP Residual norm 5.091952142201e+01
    1 KSP Residual norm 3.516517521666e-14
   21 KSP Residual norm 1.901524967217e-02
    0 KSP Residual norm 1.143854860841e+02
    1 KSP Residual norm 7.556936156281e-14
   22 KSP Residual norm 1.411221461199e-02
    0 KSP Residual norm 2.494808712357e+01
    1 KSP Residual norm 1.581447993093e-14
   23 KSP Residual norm 1.354650215503e-02
    0 KSP Residual norm 2.175022762008e+01
    1 KSP Residual norm 1.253216489904e-14
   24 KSP Residual norm 9.897514103297e-03
    0 KSP Residual norm 7.286752538664e+00
    1 KSP Residual norm 3.983901036990e-15
   25 KSP Residual norm 7.594972887124e-03
    0 KSP Residual norm 9.865959125903e+01
    1 KSP Residual norm 5.854515898291e-14
   26 KSP Residual norm 6.357010324881e-03
    0 KSP Residual norm 6.153248929079e+01
    1 KSP Residual norm 4.342917924936e-14
   27 KSP Residual norm 3.837249141333e-03
    0 KSP Residual norm 2.028466059984e+01
    1 KSP Residual norm 1.260250746468e-14
   28 KSP Residual norm 3.825093258049e-03
    0 KSP Residual norm 2.086259623580e+01
    1 KSP Residual norm 1.096933134163e-14
   29 KSP Residual norm 3.200692740417e-03
    0 KSP Residual norm 2.749989619084e+01
    1 KSP Residual norm 1.653818542601e-14
    0 KSP Residual norm 9.212456473468e-01
    1 KSP Residual norm 7.811434870340e-16
   30 KSP Residual norm 2.636282707457e-03
    0 KSP Residual norm 1.401615923172e+01
    1 KSP Residual norm 9.222569222439e-15
   31 KSP Residual norm 2.636039697841e-03
    0 KSP Residual norm 1.844677267452e+02
    1 KSP Residual norm 1.325038325340e-13
   32 KSP Residual norm 2.630597523590e-03
    0 KSP Residual norm 8.630770614906e+01
    1 KSP Residual norm 5.821918623882e-14
   33 KSP Residual norm 2.630412262238e-03
    0 KSP Residual norm 1.087220583599e+01
    1 KSP Residual norm 6.754654176999e-15
   34 KSP Residual norm 2.625793279994e-03
    0 KSP Residual norm 9.906682862299e+00
    1 KSP Residual norm 6.179914130748e-15
   35 KSP Residual norm 2.614954909094e-03
    0 KSP Residual norm 9.991241843863e+01
    1 KSP Residual norm 6.140979627531e-14
   36 KSP Residual norm 2.599866229697e-03
    0 KSP Residual norm 3.219579076718e+01
    1 KSP Residual norm 2.864524563276e-14
   37 KSP Residual norm 2.598183274119e-03
    0 KSP Residual norm 5.159783668981e+01
    1 KSP Residual norm 2.836923165594e-14
   38 KSP Residual norm 2.541308443042e-03
    0 KSP Residual norm 3.893999639592e+01
    1 KSP Residual norm 2.241867414113e-14
   39 KSP Residual norm 2.390909782968e-03
    0 KSP Residual norm 1.737908166385e+01
    1 KSP Residual norm 1.043913942513e-14
   40 KSP Residual norm 2.347462798286e-03
    0 KSP Residual norm 7.727905145982e+00
    1 KSP Residual norm 3.872497638305e-15
   41 KSP Residual norm 2.222999088699e-03
    0 KSP Residual norm 1.174674207663e+02
    1 KSP Residual norm 7.070746301170e-14
   42 KSP Residual norm 2.008122363433e-03
    0 KSP Residual norm 2.544557284475e+01
    1 KSP Residual norm 1.512873082080e-14
   43 KSP Residual norm 2.001840657014e-03
    0 KSP Residual norm 4.532764632359e+01
    1 KSP Residual norm 2.613884490190e-14
   44 KSP Residual norm 1.852152153525e-03
    0 KSP Residual norm 5.899681731882e+01
    1 KSP Residual norm 3.353112192675e-14
   45 KSP Residual norm 1.815248619938e-03
    0 KSP Residual norm 2.420027510756e+01
    1 KSP Residual norm 1.409629405446e-14
   46 KSP Residual norm 1.699026079178e-03
    0 KSP Residual norm 4.566749427758e+00
    1 KSP Residual norm 2.642825459400e-15
   47 KSP Residual norm 1.528463836818e-03
    0 KSP Residual norm 3.519786948736e+01
    1 KSP Residual norm 2.496355267304e-14
   48 KSP Residual norm 1.316483206944e-03
    0 KSP Residual norm 2.407846345747e+01
    1 KSP Residual norm 2.087084676860e-14
   49 KSP Residual norm 1.012947165095e-03
    0 KSP Residual norm 2.134672390740e+01
    1 KSP Residual norm 1.222476443679e-14
   50 KSP Residual norm 9.849964861771e-04
    0 KSP Residual norm 2.453172987213e+01
    1 KSP Residual norm 1.525121906953e-14
   51 KSP Residual norm 8.512189759291e-04
    0 KSP Residual norm 7.976532936626e+01
    1 KSP Residual norm 4.023893121718e-14
   52 KSP Residual norm 8.436370424839e-04
    0 KSP Residual norm 5.382442903744e+01
    1 KSP Residual norm 3.055032223097e-14
   53 KSP Residual norm 6.357908139806e-04
    0 KSP Residual norm 2.858252044144e+01
    1 KSP Residual norm 1.759490679685e-14
   54 KSP Residual norm 4.940876814429e-04
    0 KSP Residual norm 5.071590224960e+00
    1 KSP Residual norm 2.511589599165e-15
   55 KSP Residual norm 4.875725277714e-04
    0 KSP Residual norm 4.307035788258e+01
    1 KSP Residual norm 2.735393934819e-14
   56 KSP Residual norm 2.070493208681e-04
    0 KSP Residual norm 6.301273218135e+01
    1 KSP Residual norm 5.447468527974e-14
   57 KSP Residual norm 1.729830089614e-04
    0 KSP Residual norm 1.659065943991e+01
    1 KSP Residual norm 9.308110561435e-15
   58 KSP Residual norm 1.429022167527e-04
    0 KSP Residual norm 8.099205223016e+01
    1 KSP Residual norm 5.453570992272e-14
   59 KSP Residual norm 8.072422593685e-05
    0 KSP Residual norm 1.600325142041e+01
    1 KSP Residual norm 8.834547680334e-15
    0 KSP Residual norm 9.191268161987e-01
    1 KSP Residual norm 5.992259523703e-16
   60 KSP Residual norm 6.262411345439e-05
    0 KSP Residual norm 7.080986200168e+00
    1 KSP Residual norm 4.002334951234e-15
   61 KSP Residual norm 6.254142996255e-05
    0 KSP Residual norm 1.417623919935e+02
    1 KSP Residual norm 1.024406175755e-13
   62 KSP Residual norm 6.243167082803e-05
    0 KSP Residual norm 1.386503977267e+02
    1 KSP Residual norm 7.439418887555e-14
   63 KSP Residual norm 6.153278086760e-05
    0 KSP Residual norm 1.778224278172e+01
    1 KSP Residual norm 8.314681512243e-15
   64 KSP Residual norm 6.085814154261e-05
    0 KSP Residual norm 7.515169701694e+01
    1 KSP Residual norm 4.550637381414e-14
   65 KSP Residual norm 5.749081462333e-05
    0 KSP Residual norm 7.184301048304e+01
    1 KSP Residual norm 3.917546833977e-14
   66 KSP Residual norm 5.715814756364e-05
    0 KSP Residual norm 3.189810131099e+01
    1 KSP Residual norm 2.060235636196e-14
   67 KSP Residual norm 5.285103554622e-05
    0 KSP Residual norm 7.770245081696e+00
    1 KSP Residual norm 4.935171402031e-15
   68 KSP Residual norm 4.439814025855e-05
    0 KSP Residual norm 7.829018666461e+01
    1 KSP Residual norm 5.272724492711e-14
   69 KSP Residual norm 4.430835969157e-05
    0 KSP Residual norm 4.378293107947e+01
    1 KSP Residual norm 2.969215266404e-14
   70 KSP Residual norm 3.533204784519e-05
    0 KSP Residual norm 6.390952576475e+01
    1 KSP Residual norm 3.453873499577e-14
   71 KSP Residual norm 3.531906628482e-05
    0 KSP Residual norm 5.728597955221e+01
    1 KSP Residual norm 3.956727722166e-14
   72 KSP Residual norm 2.169987908929e-05
    0 KSP Residual norm 1.594899641221e+01
    1 KSP Residual norm 1.030594558616e-14
   73 KSP Residual norm 2.037731575928e-05
    0 KSP Residual norm 5.293092803067e+01
    1 KSP Residual norm 3.495063112140e-14
   74 KSP Residual norm 1.693927376521e-05
    0 KSP Residual norm 5.570958507353e+01
    1 KSP Residual norm 3.768974204549e-14
   75 KSP Residual norm 1.656092094331e-05
    0 KSP Residual norm 7.612816495733e+00
    1 KSP Residual norm 3.455660567119e-15
   76 KSP Residual norm 1.324603506478e-05
    0 KSP Residual norm 6.342722299112e+01
    1 KSP Residual norm 3.543613274327e-14
   77 KSP Residual norm 1.112116907646e-05
    0 KSP Residual norm 8.558637380532e+00
    1 KSP Residual norm 4.765708951924e-15
   78 KSP Residual norm 9.792527426920e-06
    0 KSP Residual norm 5.586790586197e+01
    1 KSP Residual norm 3.393127203229e-14
   79 KSP Residual norm 8.999446867141e-06
    0 KSP Residual norm 6.392452152663e+01
    1 KSP Residual norm 4.783813012661e-14
   80 KSP Residual norm 8.839832531248e-06
    0 KSP Residual norm 1.045145816041e+01
    1 KSP Residual norm 6.153936531165e-15
   81 KSP Residual norm 7.647795119149e-06
    0 KSP Residual norm 4.959135996874e+00
    1 KSP Residual norm 2.275593074487e-15
   82 KSP Residual norm 7.593975663833e-06
    0 KSP Residual norm 1.850292431359e+01
    1 KSP Residual norm 1.184622563874e-14
   83 KSP Residual norm 4.394648633950e-06
    0 KSP Residual norm 1.468590897433e+01
    1 KSP Residual norm 7.458904334684e-15
   84 KSP Residual norm 3.429174284862e-06
    0 KSP Residual norm 7.184953274476e+01
    1 KSP Residual norm 4.288600833302e-14
   85 KSP Residual norm 2.922046005477e-06
    0 KSP Residual norm 5.108136514544e+01
    1 KSP Residual norm 3.561336998791e-14
   86 KSP Residual norm 1.644609515697e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 86
    0 KSP Residual norm 1.071781318954e+00
    1 KSP Residual norm 1.362129448598e-15
  1 KSP unpreconditioned resid norm 6.572198917831e+09 true resid norm 6.572198917831e+09 ||r(i)||/||b|| 2.766551400679e-01
    0 KSP Residual norm 9.848380124959e-01
    0 KSP Residual norm 5.501420186583e+01
    1 KSP Residual norm 3.596072484238e-14
    1 KSP Residual norm 9.664519068852e-01
    0 KSP Residual norm 1.884754111473e+02
    1 KSP Residual norm 1.094865748271e-13
    2 KSP Residual norm 9.151140887760e-01
    0 KSP Residual norm 5.498192495160e+01
    1 KSP Residual norm 2.800616143568e-14
    3 KSP Residual norm 8.929766395420e-01
    0 KSP Residual norm 5.902323826652e+01
    1 KSP Residual norm 2.975726631139e-14
    4 KSP Residual norm 8.549376988986e-01
    0 KSP Residual norm 5.782359119738e+01
    1 KSP Residual norm 3.635309889749e-14
    5 KSP Residual norm 8.352879905370e-01
    0 KSP Residual norm 5.127106609342e+01
    1 KSP Residual norm 3.574010985759e-14
    6 KSP Residual norm 6.987129723317e-01
    0 KSP Residual norm 4.322880140073e+01
    1 KSP Residual norm 2.896415963782e-14
    7 KSP Residual norm 6.678448419857e-01
    0 KSP Residual norm 1.493509795762e+01
    1 KSP Residual norm 8.217241409848e-15
    8 KSP Residual norm 5.359170547747e-01
    0 KSP Residual norm 2.346360940645e+01
    1 KSP Residual norm 1.347793520261e-14
    9 KSP Residual norm 5.314808437591e-01
    0 KSP Residual norm 2.969064647594e+01
    1 KSP Residual norm 2.032159273570e-14
   10 KSP Residual norm 5.076434654384e-01
    0 KSP Residual norm 1.222260891370e+02
    1 KSP Residual norm 6.987067519281e-14
   11 KSP Residual norm 4.408500752515e-01
    0 KSP Residual norm 6.916464818129e+01
    1 KSP Residual norm 4.025208433555e-14
   12 KSP Residual norm 3.837143107187e-01
    0 KSP Residual norm 2.081812445989e+01
    1 KSP Residual norm 1.251769212430e-14
   13 KSP Residual norm 3.662775827315e-01
    0 KSP Residual norm 8.731979415993e+01
    1 KSP Residual norm 5.172532783199e-14
   14 KSP Residual norm 3.067481960889e-01
    0 KSP Residual norm 7.865367130438e+01
    1 KSP Residual norm 5.368393423596e-14
   15 KSP Residual norm 2.735961518468e-01
    0 KSP Residual norm 4.013285313161e+01
    1 KSP Residual norm 2.725238238414e-14
   16 KSP Residual norm 2.165247750228e-01
    0 KSP Residual norm 8.786197137801e+00
    1 KSP Residual norm 5.554414761541e-15
   17 KSP Residual norm 1.331008305488e-01
    0 KSP Residual norm 1.280743891939e+01
    1 KSP Residual norm 6.465753713550e-15
   18 KSP Residual norm 1.330540406549e-01
    0 KSP Residual norm 2.764463340215e+01
    1 KSP Residual norm 1.515891339632e-14
   19 KSP Residual norm 9.944993879790e-02
    0 KSP Residual norm 5.023175409073e+01
    1 KSP Residual norm 2.996757017926e-14
   20 KSP Residual norm 9.923808900026e-02
    0 KSP Residual norm 4.544689121560e+00
    1 KSP Residual norm 2.668373629069e-15
   21 KSP Residual norm 6.439740657262e-02
    0 KSP Residual norm 6.750179877441e+01
    1 KSP Residual norm 4.499589395881e-14
   22 KSP Residual norm 5.161995067260e-02
    0 KSP Residual norm 6.646724380082e+00
    1 KSP Residual norm 3.381391291577e-15
   23 KSP Residual norm 5.120003030315e-02
    0 KSP Residual norm 1.153610821276e+01
    1 KSP Residual norm 6.242742332199e-15
   24 KSP Residual norm 4.301852875762e-02
    0 KSP Residual norm 3.015534865920e+01
    1 KSP Residual norm 1.704075348318e-14
   25 KSP Residual norm 3.123500223251e-02
    0 KSP Residual norm 5.166606416724e+01
    1 KSP Residual norm 3.660192724908e-14
   26 KSP Residual norm 3.085043028547e-02
    0 KSP Residual norm 1.000380616221e+01
    1 KSP Residual norm 7.356450370532e-15
   27 KSP Residual norm 1.992660303657e-02
    0 KSP Residual norm 6.996383239267e+00
    1 KSP Residual norm 4.226945372101e-15
   28 KSP Residual norm 1.967028510457e-02
    0 KSP Residual norm 8.152191223945e+01
    1 KSP Residual norm 5.548580748043e-14
   29 KSP Residual norm 1.436872937611e-02
    0 KSP Residual norm 1.081565543262e+01
    1 KSP Residual norm 5.855985392948e-15
    0 KSP Residual norm 4.231450038089e+00
    1 KSP Residual norm 3.927959157970e-15
   30 KSP Residual norm 1.135047212506e-02
    0 KSP Residual norm 1.003951319371e+01
    1 KSP Residual norm 6.548703411090e-15
   31 KSP Residual norm 1.134768565553e-02
    0 KSP Residual norm 2.047999325283e+02
    1 KSP Residual norm 1.233946936211e-13
   32 KSP Residual norm 1.131345996525e-02
    0 KSP Residual norm 9.445728355176e+00
    1 KSP Residual norm 6.068465020255e-15
   33 KSP Residual norm 1.129815169680e-02
    0 KSP Residual norm 1.572595663348e+01
    1 KSP Residual norm 7.704099295392e-15
   34 KSP Residual norm 1.129416642425e-02
    0 KSP Residual norm 6.411160109435e+01
    1 KSP Residual norm 3.868040705854e-14
   35 KSP Residual norm 1.114403858382e-02
    0 KSP Residual norm 2.925908488458e+01
    1 KSP Residual norm 1.725333952254e-14
   36 KSP Residual norm 1.109684952237e-02
    0 KSP Residual norm 4.094752481871e+01
    1 KSP Residual norm 2.548496980880e-14
   37 KSP Residual norm 1.039962803868e-02
    0 KSP Residual norm 4.677928660892e+01
    1 KSP Residual norm 2.575035605781e-14
   38 KSP Residual norm 9.607317624260e-03
    0 KSP Residual norm 3.396143505284e+01
    1 KSP Residual norm 2.306756663535e-14
   39 KSP Residual norm 9.455091778539e-03
    0 KSP Residual norm 1.132420908643e+01
    1 KSP Residual norm 7.892947404093e-15
   40 KSP Residual norm 8.725129855043e-03
    0 KSP Residual norm 1.027802213355e+02
    1 KSP Residual norm 5.644204417728e-14
   41 KSP Residual norm 8.700872603655e-03
    0 KSP Residual norm 3.092617041672e+01
    1 KSP Residual norm 2.128084237682e-14
   42 KSP Residual norm 8.305367523871e-03
    0 KSP Residual norm 9.896865476397e+01
    1 KSP Residual norm 7.027730871792e-14
   43 KSP Residual norm 8.017116947073e-03
    0 KSP Residual norm 2.489635812253e+01
    1 KSP Residual norm 1.488894143307e-14
   44 KSP Residual norm 7.101120826232e-03
    0 KSP Residual norm 5.078927249023e+01
    1 KSP Residual norm 3.393801507715e-14
   45 KSP Residual norm 7.099249405523e-03
    0 KSP Residual norm 7.399091879839e+01
    1 KSP Residual norm 3.970740979389e-14
   46 KSP Residual norm 6.239964305039e-03
    0 KSP Residual norm 1.006107627223e+01
    1 KSP Residual norm 6.275065766989e-15
   47 KSP Residual norm 6.220767037758e-03
    0 KSP Residual norm 2.039510262414e+01
    1 KSP Residual norm 1.226928303532e-14
   48 KSP Residual norm 4.582507692912e-03
    0 KSP Residual norm 3.479122642260e+01
    1 KSP Residual norm 1.980214432629e-14
   49 KSP Residual norm 3.950466021185e-03
    0 KSP Residual norm 3.949023209700e+01
    1 KSP Residual norm 2.830451594639e-14
   50 KSP Residual norm 3.156823554111e-03
    0 KSP Residual norm 1.397673792480e+01
    1 KSP Residual norm 8.333365174822e-15
   51 KSP Residual norm 3.074542857812e-03
    0 KSP Residual norm 6.745938868708e+00
    1 KSP Residual norm 5.757620759309e-15
   52 KSP Residual norm 2.436229423268e-03
    0 KSP Residual norm 1.138575813336e+01
    1 KSP Residual norm 7.419021580885e-15
   53 KSP Residual norm 1.991468511931e-03
    0 KSP Residual norm 2.222970375394e+01
    1 KSP Residual norm 1.687252149997e-14
   54 KSP Residual norm 1.990980997161e-03
    0 KSP Residual norm 3.541206630034e+01
    1 KSP Residual norm 2.378475012463e-14
   55 KSP Residual norm 1.578606371328e-03
    0 KSP Residual norm 1.852187822467e+01
    1 KSP Residual norm 9.691012609173e-15
   56 KSP Residual norm 9.884828200093e-04
    0 KSP Residual norm 9.295541145164e+00
    1 KSP Residual norm 6.736125221102e-15
   57 KSP Residual norm 9.797809483947e-04
    0 KSP Residual norm 1.214064944530e+01
    1 KSP Residual norm 1.296576938899e-14
   58 KSP Residual norm 5.763774407829e-04
    0 KSP Residual norm 6.921061980045e+01
    1 KSP Residual norm 4.469546477185e-14
   59 KSP Residual norm 3.792297931482e-04
    0 KSP Residual norm 1.191677932851e+02
    1 KSP Residual norm 6.630922675029e-14
    0 KSP Residual norm 4.224933659981e+00
    1 KSP Residual norm 2.497733403124e-15
   60 KSP Residual norm 3.591550716791e-04
    0 KSP Residual norm 1.276388696588e+02
    1 KSP Residual norm 7.469339373319e-14
   61 KSP Residual norm 3.591548935140e-04
    0 KSP Residual norm 1.990598481455e+02
    1 KSP Residual norm 1.408982976160e-13
   62 KSP Residual norm 3.591026732446e-04
    0 KSP Residual norm 7.734860422205e+00
    1 KSP Residual norm 3.533425444020e-15
   63 KSP Residual norm 3.590971023537e-04
    0 KSP Residual norm 1.623760676941e+02
    1 KSP Residual norm 1.015281556116e-13
   64 KSP Residual norm 3.590301520440e-04
    0 KSP Residual norm 1.832622645904e+01
    1 KSP Residual norm 1.089337554485e-14
   65 KSP Residual norm 3.589525226283e-04
    0 KSP Residual norm 5.883806323876e+01
    1 KSP Residual norm 3.544699676840e-14
   66 KSP Residual norm 3.587395507263e-04
    0 KSP Residual norm 6.240277600891e+00
    1 KSP Residual norm 3.504024802977e-15
   67 KSP Residual norm 3.582983449722e-04
    0 KSP Residual norm 6.550629626011e+00
    1 KSP Residual norm 4.267672013506e-15
   68 KSP Residual norm 3.569893638194e-04
    0 KSP Residual norm 2.365836388242e+01
    1 KSP Residual norm 1.364611914826e-14
   69 KSP Residual norm 3.512264058619e-04
    0 KSP Residual norm 3.885570512570e+01
    1 KSP Residual norm 2.231047121564e-14
   70 KSP Residual norm 3.453695781694e-04
    0 KSP Residual norm 1.785672778004e+01
    1 KSP Residual norm 1.128829898101e-14
   71 KSP Residual norm 3.379821113338e-04
    0 KSP Residual norm 1.818703910385e+01
    1 KSP Residual norm 1.835880458824e-14
   72 KSP Residual norm 3.067650549825e-04
    0 KSP Residual norm 2.242867319078e+01
    1 KSP Residual norm 1.247178795371e-14
   73 KSP Residual norm 3.054979710119e-04
    0 KSP Residual norm 2.669198661138e+01
    1 KSP Residual norm 1.492131065423e-14
   74 KSP Residual norm 2.495874003759e-04
    0 KSP Residual norm 5.342726072881e+00
    1 KSP Residual norm 2.902529214942e-15
   75 KSP Residual norm 2.468487101598e-04
    0 KSP Residual norm 2.392521903608e+01
    1 KSP Residual norm 1.829624338486e-14
   76 KSP Residual norm 1.773281505854e-04
    0 KSP Residual norm 2.295158643849e+01
    1 KSP Residual norm 1.466453415456e-14
   77 KSP Residual norm 1.675716371561e-04
    0 KSP Residual norm 4.216446384790e+01
    1 KSP Residual norm 2.670744229188e-14
   78 KSP Residual norm 1.482259877515e-04
    0 KSP Residual norm 5.176388567547e+01
    1 KSP Residual norm 2.807830881429e-14
   79 KSP Residual norm 1.406068628540e-04
    0 KSP Residual norm 1.012892551040e+01
    1 KSP Residual norm 5.243773909284e-15
   80 KSP Residual norm 1.317485789064e-04
    0 KSP Residual norm 1.156869226474e+01
    1 KSP Residual norm 5.924271035097e-15
   81 KSP Residual norm 9.076670979346e-05
    0 KSP Residual norm 8.989122609933e+00
    1 KSP Residual norm 4.258362758318e-15
   82 KSP Residual norm 9.013796592102e-05
    0 KSP Residual norm 4.966024298464e+01
    1 KSP Residual norm 3.163767923803e-14
   83 KSP Residual norm 6.586622357040e-05
    0 KSP Residual norm 5.328318841428e+01
    1 KSP Residual norm 3.339851714016e-14
   84 KSP Residual norm 6.369410061991e-05
    0 KSP Residual norm 8.372703920714e+01
    1 KSP Residual norm 6.057922045754e-14
   85 KSP Residual norm 5.883106495026e-05
    0 KSP Residual norm 6.741350051119e+01
    1 KSP Residual norm 3.900500452206e-14
   86 KSP Residual norm 3.722015215339e-05
    0 KSP Residual norm 4.006569837915e+01
    1 KSP Residual norm 2.735673521250e-14
   87 KSP Residual norm 3.720630015478e-05
    0 KSP Residual norm 2.476618885951e+01
    1 KSP Residual norm 1.239800253805e-14
   88 KSP Residual norm 2.135948372700e-05
    0 KSP Residual norm 9.563406544187e+01
    1 KSP Residual norm 6.048724242367e-14
   89 KSP Residual norm 1.816266768652e-05
    0 KSP Residual norm 5.168707958879e+01
    1 KSP Residual norm 3.407108533174e-14
    0 KSP Residual norm 4.225064282276e+00
    1 KSP Residual norm 2.673605755194e-15
   90 KSP Residual norm 1.683628726867e-05
    0 KSP Residual norm 1.525827966750e+01
    1 KSP Residual norm 9.510793334472e-15
   91 KSP Residual norm 1.682892819348e-05
    0 KSP Residual norm 1.970973967869e+02
    1 KSP Residual norm 1.463095390722e-13
   92 KSP Residual norm 1.670654997355e-05
    0 KSP Residual norm 3.134970417364e+01
    1 KSP Residual norm 2.679864390331e-14
   93 KSP Residual norm 1.669541545510e-05
    0 KSP Residual norm 1.243744933528e+02
    1 KSP Residual norm 6.479760510434e-14
   94 KSP Residual norm 1.649566531828e-05
    0 KSP Residual norm 9.665756152536e+00
    1 KSP Residual norm 4.987873333199e-15
   95 KSP Residual norm 1.620495827749e-05
    0 KSP Residual norm 1.396177358022e+01
    1 KSP Residual norm 7.871763025339e-15
   96 KSP Residual norm 1.613120803508e-05
    0 KSP Residual norm 1.347530393061e+01
    1 KSP Residual norm 8.015122439573e-15
   97 KSP Residual norm 1.597909793013e-05
    0 KSP Residual norm 5.964572995928e+01
    1 KSP Residual norm 3.552937639210e-14
   98 KSP Residual norm 1.484704881709e-05
    0 KSP Residual norm 1.790866234771e+01
    1 KSP Residual norm 1.588503602414e-14
   99 KSP Residual norm 1.394465899749e-05
    0 KSP Residual norm 3.901014898016e+01
    1 KSP Residual norm 2.619826027835e-14
  100 KSP Residual norm 1.351932328200e-05
    0 KSP Residual norm 7.894524695594e+01
    1 KSP Residual norm 4.850263628781e-14
  101 KSP Residual norm 1.333742691380e-05
    0 KSP Residual norm 8.243255058264e+01
    1 KSP Residual norm 4.895629816759e-14
  102 KSP Residual norm 1.282339179797e-05
    0 KSP Residual norm 2.252864548303e+01
    1 KSP Residual norm 1.503522226521e-14
  103 KSP Residual norm 1.094586182913e-05
    0 KSP Residual norm 3.986463828179e+01
    1 KSP Residual norm 3.308055500220e-14
  104 KSP Residual norm 1.073066142185e-05
    0 KSP Residual norm 1.228853623752e+01
    1 KSP Residual norm 7.997676112923e-15
  105 KSP Residual norm 8.901585776449e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 105
    0 KSP Residual norm 4.283996885378e+00
    1 KSP Residual norm 2.816714568450e-15
  2 KSP unpreconditioned resid norm 6.438608672179e+04 true resid norm 6.438608672019e+04 ||r(i)||/||b|| 2.710316906518e-06
    0 KSP Residual norm 9.999555556883e-01
    0 KSP Residual norm 2.353695927814e+01
    1 KSP Residual norm 1.425324244435e-14
    1 KSP Residual norm 9.994399522514e-01
    0 KSP Residual norm 2.030669830370e+02
    1 KSP Residual norm 1.486885510352e-13
    2 KSP Residual norm 9.977259845412e-01
    0 KSP Residual norm 4.941831553295e+01
    1 KSP Residual norm 3.382669055833e-14
    3 KSP Residual norm 9.938173184077e-01
    0 KSP Residual norm 1.636052991315e+01
    1 KSP Residual norm 1.277256301908e-14
    4 KSP Residual norm 9.913501774901e-01
    0 KSP Residual norm 7.189810874463e+00
    1 KSP Residual norm 3.637573622646e-15
    5 KSP Residual norm 9.820091324909e-01
    0 KSP Residual norm 1.236401222670e+02
    1 KSP Residual norm 7.141879012712e-14
    6 KSP Residual norm 9.813808060219e-01
    0 KSP Residual norm 3.031651415085e+01
    1 KSP Residual norm 1.917481970774e-14
    7 KSP Residual norm 9.556999134850e-01
    0 KSP Residual norm 6.494361884956e+01
    1 KSP Residual norm 5.302118065701e-14
    8 KSP Residual norm 9.444932047691e-01
    0 KSP Residual norm 8.970221540505e+00
    1 KSP Residual norm 4.651620610378e-15
    9 KSP Residual norm 8.872073957956e-01
    0 KSP Residual norm 4.616931708860e+01
    1 KSP Residual norm 3.372336498494e-14
   10 KSP Residual norm 8.563719267045e-01
    0 KSP Residual norm 4.906284866371e+01
    1 KSP Residual norm 2.963623266967e-14
   11 KSP Residual norm 7.825206625240e-01
    0 KSP Residual norm 4.251050794709e+01
    1 KSP Residual norm 2.379173497429e-14
   12 KSP Residual norm 6.854953711433e-01
    0 KSP Residual norm 4.558826217382e+01
    1 KSP Residual norm 3.261396764736e-14
   13 KSP Residual norm 6.792461509441e-01
    0 KSP Residual norm 4.448485493426e+01
    1 KSP Residual norm 2.358375810593e-14
   14 KSP Residual norm 6.191910235349e-01
    0 KSP Residual norm 3.017765985325e+01
    1 KSP Residual norm 1.754095465701e-14
   15 KSP Residual norm 6.126017234069e-01
    0 KSP Residual norm 4.480456017437e+01
    1 KSP Residual norm 2.317228816482e-14
   16 KSP Residual norm 5.656042821840e-01
    0 KSP Residual norm 2.947761065377e+01
    1 KSP Residual norm 1.657721549132e-14
   17 KSP Residual norm 4.071896024268e-01
    0 KSP Residual norm 2.673338734909e+01
    1 KSP Residual norm 1.631101737943e-14
   18 KSP Residual norm 3.641868322225e-01
    0 KSP Residual norm 2.137690034956e+01
    1 KSP Residual norm 1.244970852076e-14
   19 KSP Residual norm 3.019702364584e-01
    0 KSP Residual norm 6.896891756059e+00
    1 KSP Residual norm 3.591678005999e-15
   20 KSP Residual norm 2.963918359869e-01
    0 KSP Residual norm 2.991072559271e+01
    1 KSP Residual norm 1.747281332404e-14
   21 KSP Residual norm 2.593248332823e-01
    0 KSP Residual norm 3.804871294187e+01
    1 KSP Residual norm 2.188008718899e-14
   22 KSP Residual norm 2.514762212240e-01
    0 KSP Residual norm 3.447581033715e+01
    1 KSP Residual norm 1.928158785603e-14
   23 KSP Residual norm 1.766544426861e-01
    0 KSP Residual norm 7.377218921922e+00
    1 KSP Residual norm 4.517947563482e-15
   24 KSP Residual norm 9.265750187397e-02
    0 KSP Residual norm 5.930421679920e+01
    1 KSP Residual norm 3.647534113740e-14
   25 KSP Residual norm 9.260357558906e-02
    0 KSP Residual norm 1.129721522446e+02
    1 KSP Residual norm 6.680346215739e-14
   26 KSP Residual norm 5.747265051047e-02
    0 KSP Residual norm 1.697414568570e+01
    1 KSP Residual norm 1.140109257527e-14
   27 KSP Residual norm 4.413037641705e-02
    0 KSP Residual norm 6.927774415668e+01
    1 KSP Residual norm 4.709631511851e-14
   28 KSP Residual norm 3.477454752471e-02
    0 KSP Residual norm 4.622392428862e+01
    1 KSP Residual norm 2.856274514870e-14
   29 KSP Residual norm 2.254554159844e-02
    0 KSP Residual norm 2.277898386018e+01
    1 KSP Residual norm 1.545848031054e-14
    0 KSP Residual norm 1.065063454214e+01
    1 KSP Residual norm 3.967556833620e-15
   30 KSP Residual norm 2.228027017534e-02
    0 KSP Residual norm 6.667854404395e+01
    1 KSP Residual norm 4.832478671300e-14
   31 KSP Residual norm 2.228022072114e-02
    0 KSP Residual norm 1.991903342783e+02
    1 KSP Residual norm 1.447689407360e-13
   32 KSP Residual norm 2.227281490564e-02
    0 KSP Residual norm 6.700425410361e+00
    1 KSP Residual norm 3.641691760878e-15
   33 KSP Residual norm 2.226608947816e-02
    0 KSP Residual norm 1.572786843549e+02
    1 KSP Residual norm 8.905071779068e-14
   34 KSP Residual norm 2.224788802748e-02
    0 KSP Residual norm 2.116499026749e+01
    1 KSP Residual norm 1.253874587368e-14
   35 KSP Residual norm 2.220679064680e-02
    0 KSP Residual norm 6.934806060237e+01
    1 KSP Residual norm 4.437835816224e-14
   36 KSP Residual norm 2.217734379137e-02
    0 KSP Residual norm 2.896827775306e+01
    1 KSP Residual norm 1.616656963850e-14
   37 KSP Residual norm 2.205990647709e-02
    0 KSP Residual norm 1.642803318222e+01
    1 KSP Residual norm 1.126364489217e-14
   38 KSP Residual norm 2.199703593686e-02
    0 KSP Residual norm 3.518398852179e+01
    1 KSP Residual norm 1.985076009075e-14
   39 KSP Residual norm 2.174801670090e-02
    0 KSP Residual norm 1.144612436794e+01
    1 KSP Residual norm 5.756878864730e-15
   40 KSP Residual norm 2.049943689215e-02
    0 KSP Residual norm 5.152420288707e+01
    1 KSP Residual norm 2.737555444587e-14
   41 KSP Residual norm 2.048820624991e-02
    0 KSP Residual norm 1.383345143006e+01
    1 KSP Residual norm 7.633625669085e-15
   42 KSP Residual norm 1.712518826879e-02
    0 KSP Residual norm 4.827096130426e+01
    1 KSP Residual norm 3.165109854183e-14
   43 KSP Residual norm 1.711883670834e-02
    0 KSP Residual norm 6.025927974638e+00
    1 KSP Residual norm 4.148427497577e-15
   44 KSP Residual norm 1.591796646582e-02
    0 KSP Residual norm 2.251158032641e+01
    1 KSP Residual norm 1.507563020703e-14
   45 KSP Residual norm 1.584524964268e-02
    0 KSP Residual norm 5.167365199449e+00
    1 KSP Residual norm 3.379105359765e-15
   46 KSP Residual norm 1.349639659612e-02
    0 KSP Residual norm 1.282989106082e+01
    1 KSP Residual norm 8.258313562387e-15
   47 KSP Residual norm 1.148719261322e-02
    0 KSP Residual norm 1.256049481325e+01
    1 KSP Residual norm 6.281823667347e-15
   48 KSP Residual norm 1.079578319384e-02
    0 KSP Residual norm 5.211907560795e+00
    1 KSP Residual norm 2.180241730309e-15
   49 KSP Residual norm 9.448798431757e-03
    0 KSP Residual norm 2.727093655712e+01
    1 KSP Residual norm 1.738181256754e-14
   50 KSP Residual norm 8.896951676290e-03
    0 KSP Residual norm 5.823125854765e+01
    1 KSP Residual norm 4.118553687570e-14
   51 KSP Residual norm 7.138499399917e-03
    0 KSP Residual norm 7.362221724155e+01
    1 KSP Residual norm 5.667658718302e-14
   52 KSP Residual norm 7.116852115789e-03
    0 KSP Residual norm 8.240034073465e+00
    1 KSP Residual norm 4.334051539140e-15
   53 KSP Residual norm 5.250165507525e-03
    0 KSP Residual norm 3.095522616646e+01
    1 KSP Residual norm 2.000416121332e-14
   54 KSP Residual norm 4.866567651521e-03
    0 KSP Residual norm 1.327228390250e+01
    1 KSP Residual norm 8.161300830659e-15
   55 KSP Residual norm 4.238892476107e-03
    0 KSP Residual norm 5.959064809773e+01
    1 KSP Residual norm 3.482334176604e-14
   56 KSP Residual norm 2.340047951042e-03
    0 KSP Residual norm 1.037456562505e+01
    1 KSP Residual norm 6.418123454948e-15
   57 KSP Residual norm 2.094665497633e-03
    0 KSP Residual norm 7.787274616221e+00
    1 KSP Residual norm 5.081208509626e-15
   58 KSP Residual norm 1.966887867784e-03
    0 KSP Residual norm 2.827046845101e+01
    1 KSP Residual norm 1.842102294859e-14
   59 KSP Residual norm 1.439583590501e-03
    0 KSP Residual norm 4.917573265878e+01
    1 KSP Residual norm 2.859758370055e-14
    0 KSP Residual norm 1.067835000333e+01
    1 KSP Residual norm 6.056107330393e-15
   60 KSP Residual norm 1.437223156204e-03
    0 KSP Residual norm 4.897692055893e+01
    1 KSP Residual norm 3.483917653134e-14
   61 KSP Residual norm 1.437222455874e-03
    0 KSP Residual norm 1.979950295805e+02
    1 KSP Residual norm 9.692799839679e-14
   62 KSP Residual norm 1.436931519419e-03
    0 KSP Residual norm 1.614058435142e+01
    1 KSP Residual norm 1.145346746167e-14
   63 KSP Residual norm 1.434863940755e-03
    0 KSP Residual norm 6.311234616234e+01
    1 KSP Residual norm 4.422867387644e-14
   64 KSP Residual norm 1.430266308873e-03
    0 KSP Residual norm 1.351463785495e+01
    1 KSP Residual norm 6.276636129421e-15
   65 KSP Residual norm 1.422795975788e-03
    0 KSP Residual norm 8.006053249097e+00
    1 KSP Residual norm 5.219585311233e-15
   66 KSP Residual norm 1.407082023168e-03
    0 KSP Residual norm 9.793693610326e+01
    1 KSP Residual norm 5.281120573516e-14
   67 KSP Residual norm 1.361194751432e-03
    0 KSP Residual norm 7.167679381144e+01
    1 KSP Residual norm 4.111699980206e-14
   68 KSP Residual norm 1.360028333969e-03
    0 KSP Residual norm 3.658485636909e+01
    1 KSP Residual norm 2.338053373490e-14
   69 KSP Residual norm 1.215632100869e-03
    0 KSP Residual norm 9.381118803734e+01
    1 KSP Residual norm 5.729584278408e-14
   70 KSP Residual norm 1.019028930687e-03
    0 KSP Residual norm 6.335844295233e+01
    1 KSP Residual norm 3.532211557294e-14
   71 KSP Residual norm 1.012734321370e-03
    0 KSP Residual norm 8.866383120189e+00
    1 KSP Residual norm 4.049252634598e-15
   72 KSP Residual norm 9.136832782632e-04
    0 KSP Residual norm 2.360924223766e+01
    1 KSP Residual norm 1.441464363138e-14
   73 KSP Residual norm 9.016799244251e-04
    0 KSP Residual norm 1.573632152504e+01
    1 KSP Residual norm 1.226453211559e-14
   74 KSP Residual norm 8.504560013469e-04
    0 KSP Residual norm 5.712563939357e+01
    1 KSP Residual norm 3.538436178324e-14
   75 KSP Residual norm 7.967375475347e-04
    0 KSP Residual norm 2.048510524737e+01
    1 KSP Residual norm 1.142629566057e-14
   76 KSP Residual norm 7.725342704854e-04
    0 KSP Residual norm 2.149390243310e+01
    1 KSP Residual norm 1.212168050608e-14
   77 KSP Residual norm 7.055554122603e-04
    0 KSP Residual norm 9.641623529528e+00
    1 KSP Residual norm 6.405001038799e-15
   78 KSP Residual norm 6.888816310925e-04
    0 KSP Residual norm 6.111882289314e+01
    1 KSP Residual norm 3.901566240696e-14
   79 KSP Residual norm 5.170122086622e-04
    0 KSP Residual norm 3.624382670754e+01
    1 KSP Residual norm 1.927716593710e-14
   80 KSP Residual norm 5.107276466327e-04
    0 KSP Residual norm 4.679364083079e+01
    1 KSP Residual norm 3.521489721406e-14
   81 KSP Residual norm 4.963504983781e-04
    0 KSP Residual norm 2.604389593451e+01
    1 KSP Residual norm 1.550584626231e-14
   82 KSP Residual norm 4.582722422975e-04
    0 KSP Residual norm 7.694403508481e+01
    1 KSP Residual norm 4.243077435794e-14
   83 KSP Residual norm 3.925555789380e-04
    0 KSP Residual norm 1.983414687166e+01
    1 KSP Residual norm 1.064235673251e-14
   84 KSP Residual norm 2.632566109675e-04
    0 KSP Residual norm 1.592496351987e+01
    1 KSP Residual norm 9.451475167593e-15
   85 KSP Residual norm 2.538224085246e-04
    0 KSP Residual norm 1.710068599656e+01
    1 KSP Residual norm 1.507898897802e-14
   86 KSP Residual norm 1.285183498353e-04
    0 KSP Residual norm 7.921308519134e+01
    1 KSP Residual norm 4.356902065732e-14
   87 KSP Residual norm 6.937880096307e-05
    0 KSP Residual norm 6.179135051924e+00
    1 KSP Residual norm 3.585592552275e-15
   88 KSP Residual norm 6.629418155872e-05
    0 KSP Residual norm 7.370852429775e+01
    1 KSP Residual norm 3.955664816638e-14
   89 KSP Residual norm 3.348941676231e-05
    0 KSP Residual norm 3.949759959284e+01
    1 KSP Residual norm 2.823056205423e-14
    0 KSP Residual norm 1.068983292438e+01
    1 KSP Residual norm 5.389853126500e-15
   90 KSP Residual norm 2.431893823182e-05
    0 KSP Residual norm 7.757467315144e+01
    1 KSP Residual norm 4.293339736665e-14
   91 KSP Residual norm 2.431886219474e-05
    0 KSP Residual norm 1.983252707264e+02
    1 KSP Residual norm 1.109895694437e-13
   92 KSP Residual norm 2.430167100275e-05
    0 KSP Residual norm 1.220141175816e+01
    1 KSP Residual norm 6.563612565523e-15
   93 KSP Residual norm 2.429335340318e-05
    0 KSP Residual norm 1.309265251769e+02
    1 KSP Residual norm 7.832652821703e-14
   94 KSP Residual norm 2.427295128660e-05
    0 KSP Residual norm 8.561036206769e+00
    1 KSP Residual norm 5.024715359286e-15
   95 KSP Residual norm 2.427098980829e-05
    0 KSP Residual norm 4.707846667047e+01
    1 KSP Residual norm 2.730831747912e-14
   96 KSP Residual norm 2.413024211264e-05
    0 KSP Residual norm 3.306516179208e+01
    1 KSP Residual norm 1.799576974063e-14
   97 KSP Residual norm 2.412365231431e-05
    0 KSP Residual norm 1.672532210296e+01
    1 KSP Residual norm 1.232067118408e-14
   98 KSP Residual norm 2.352567094709e-05
    0 KSP Residual norm 7.544804978896e+00
    1 KSP Residual norm 5.125319316741e-15
   99 KSP Residual norm 2.262041446839e-05
    0 KSP Residual norm 7.349374375944e+01
    1 KSP Residual norm 5.451742904231e-14
  100 KSP Residual norm 2.249193750880e-05
    0 KSP Residual norm 7.630664178839e+01
    1 KSP Residual norm 3.873127160607e-14
  101 KSP Residual norm 2.199665874258e-05
    0 KSP Residual norm 2.250953859631e+01
    1 KSP Residual norm 1.561092635880e-14
  102 KSP Residual norm 2.059948500401e-05
    0 KSP Residual norm 1.099195741992e+01
    1 KSP Residual norm 5.776744864697e-15
  103 KSP Residual norm 1.984149460152e-05
    0 KSP Residual norm 9.112075890965e+00
    1 KSP Residual norm 5.677412765590e-15
  104 KSP Residual norm 1.775525377844e-05
    0 KSP Residual norm 9.729837274371e+00
    1 KSP Residual norm 5.245085374515e-15
  105 KSP Residual norm 1.729062001583e-05
    0 KSP Residual norm 5.876559854574e+00
    1 KSP Residual norm 3.117525493160e-15
  106 KSP Residual norm 1.355670504843e-05
    0 KSP Residual norm 1.536973178874e+01
    1 KSP Residual norm 1.091255670410e-14
  107 KSP Residual norm 1.324837246363e-05
    0 KSP Residual norm 1.834964986671e+01
    1 KSP Residual norm 1.056189704322e-14
  108 KSP Residual norm 9.854785712624e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 108
    0 KSP Residual norm 1.069036799388e+01
    1 KSP Residual norm 7.405094057249e-15
  3 KSP unpreconditioned resid norm 6.325000280140e-01 true resid norm 6.325019129368e-01 ||r(i)||/||b|| 2.662501660471e-11
KSP Object: 3 MPI processes
  type: fgmres
PC Object: 3 MPI processes
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       3 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_0_)       3 MPI processes
        type: lu
              Mat Object:               3 MPI processes
                type: mpiaij
                rows=624, cols=624
                total: nonzeros=148148, allocated nonzeros=148148
                      [0] 4.02519e+06
                      [1] 2.70367e+06
                      [2] 1.62473e+07
                      [0]  55439.
                      [1]  30276.
                      [2]  65773.
                      [0]  4.02519e+06
                      [1]  2.70367e+06
                      [2]  1.62473e+07
                    [0] 9
                    [1] 9
                    [2] 10
                      [0] 9
                      [1] 9
                      [2] 10
                      [0] 278
                      [1] 87
                      [2] 259
                    RINFOG(1) (global estimated flops for the elimination after analysis): 2.29761e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 151488.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 2.29761e+07
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 148148
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 4993
                    INFOG(5) (estimated maximum front size in the complete tree): 286
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 148148
                    INFOG(10) (total integer space store the matrix factors after factorization): 4993
                    INFOG(11) (order of largest frontal matrix after factorization): 286
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 10
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 28
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 10
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 28
                    INFOG(20) (estimated number of entries in the factors): 148148
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 10
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 28
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 148148
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 1, 2
        Mat Object:        (fieldsplit_0_)         3 MPI processes
          type: mpiaij
          rows=624, cols=624
          total: nonzeros=72004, allocated nonzeros=72004
            using I-node (on process 0) routines: found 84 nodes, limit used is 5
      KSP Object:      (fieldsplit_1_)       3 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_1_)       3 MPI processes
        type: lu
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=3736, allocated nonzeros=3736
                      [0] 0.
                      [1] 0.
                      [2] 137244.
                      [0]  0.
                      [1]  0.
                      [2]  1225.
                      [0]  0.
                      [1]  0.
                      [2]  137244.
                    [0] 1
                    [1] 1
                    [2] 1
                      [0] 1
                      [1] 1
                      [2] 1
                      [0] 0
                      [1] 0
                      [2] 64
                    RINFOG(1) (global estimated flops for the elimination after analysis): 137244.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1225.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 137244.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3736
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 228
                    INFOG(5) (estimated maximum front size in the complete tree): 55
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3736
                    INFOG(10) (total integer space store the matrix factors after factorization): 228
                    INFOG(11) (order of largest frontal matrix after factorization): 55
                    INFOG(20) (estimated number of entries in the factors): 3736
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3736
        Mat Object:        (fieldsplit_1_)         3 MPI processes
          rows=64, cols=64
            A11
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=1498, allocated nonzeros=1498
                  using I-node (on process 0) routines: found 49 nodes, limit used is 5
            A10
                type: mpiaij
                rows=64, cols=624
                total: nonzeros=6619, allocated nonzeros=6619
            KSP of A00
                type: fgmres
                  GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
                  GMRES: happy breakdown tolerance 1e-30
                maximum iterations=10000, initial guess is zero
                tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
                right preconditioning
                using UNPRECONDITIONED norm type for convergence test
                type: lu
                  LU: out-of-place factorization
                  tolerance for zero pivot 2.22045e-14
                  factor fill ratio given 0., needed 0.
                    Factored matrix follows:
                        type: mpiaij
                        rows=624, cols=624
                        package used to perform factorization: mumps
                        total number of mallocs used during MatSetValues calls =0
                          MUMPS run parameters:
                            SYM (matrix type):                   0
                            PAR (host participation):            1
                            ICNTL(1) (output for error):         6
                            ICNTL(2) (output of diagnostic msg): 0
                            ICNTL(3) (output for global info):   0
                            ICNTL(4) (level of printing):        0
                            ICNTL(5) (input mat struct):         0
                            ICNTL(6) (matrix prescaling):        7
                            ICNTL(7) (sequentia matrix ordering):7
                            ICNTL(8) (scalling strategy):        77
                            ICNTL(10) (max num of refinements):  0
                            ICNTL(11) (error analysis):          0
                            ICNTL(12) (efficiency control):                         1
                            ICNTL(13) (efficiency control):                         0
                            ICNTL(14) (percentage of estimated workspace increase): 20
                            ICNTL(19) (Shur complement info):                       0
                            ICNTL(20) (rhs sparse pattern):                         0
                            ICNTL(22) (in-core/out-of-core facility):               0
                            ICNTL(23) (max size of memory can be allocated locally):0
                            ICNTL(24) (detection of null pivot rows):               0
                            ICNTL(25) (computation of a null space basis):          0
                            ICNTL(26) (Schur options for rhs or solution):          0
                            ICNTL(27) (experimental parameter):                     -32
                            ICNTL(28) (use parallel or sequential ordering):        1
                            ICNTL(29) (parallel ordering):                          0
                            ICNTL(30) (user-specified set of entries in inv(A)):    0
                            ICNTL(31) (factors is discarded in the solve phase):    0
                            ICNTL(33) (compute determinant):                        0
                            CNTL(1) (relative pivoting threshold):      0.01
                            CNTL(2) (stopping criterion of refinement): 1.49012e-08
                            CNTL(3) (absolute pivoting threshold):      0.
                            CNTL(4) (value of static pivoting):         -1.
                            CNTL(5) (fixation for null pivots):         0.
                            RINFO(1) (local estimated flops for the elimination after analysis):
                              [0] 4.02519e+06
                              [1] 2.70367e+06
                              [2] 1.62473e+07
                            RINFO(2) (local estimated flops for the assembly after factorization):
                              [0]  55439.
                              [1]  30276.
                              [2]  65773.
                            RINFO(3) (local estimated flops for the elimination after factorization):
                              [0]  4.02519e+06
                              [1]  2.70367e+06
                              [2]  1.62473e+07
                            INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                            [0] 9
                            [1] 9
                            [2] 10
                            INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                              [0] 9
                              [1] 9
                              [2] 10
                            INFO(23) (num of pivots eliminated on this processor after factorization):
                              [0] 278
                              [1] 87
                              [2] 259
                            (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
                  type: mpiaij
                  rows=624, cols=624
            A01
                type: mpiaij
                rows=624, cols=64
          type: mpiaij
          rows=64, cols=64
          total: nonzeros=3254, allocated nonzeros=3254
            using I-node (on process 0) routines: found 36 nodes, limit used is 5
    type: mpiaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=100623
      using I-node (on process 0) routines: found 89 nodes, limit used is 5
  0 KSP unpreconditioned resid norm 2.375592557658e+10 true resid norm 2.375592557658e+10 ||r(i)||/||b|| 1.000000000000e+00
    Residual norms for fieldsplit_1_ solve.
    0 KSP Residual norm 2.521869279267e-01
    Residual norms for fieldsplit_0_ solve.
    0 KSP Residual norm 2.806099413608e+01
    1 KSP Residual norm 1.432171001499e-14
    1 KSP Residual norm 2.445634516606e-01
    0 KSP Residual norm 6.329002388032e+01
    1 KSP Residual norm 3.678452143235e-14
    2 KSP Residual norm 2.399701984035e-01
    0 KSP Residual norm 5.154412453190e+01
    1 KSP Residual norm 2.397884362424e-14
    3 KSP Residual norm 2.213788128356e-01
    0 KSP Residual norm 2.647018644622e+01
    1 KSP Residual norm 1.698023338640e-14
    4 KSP Residual norm 2.213179093002e-01
    0 KSP Residual norm 2.175770266807e+01
    1 KSP Residual norm 1.381365862606e-14
    5 KSP Residual norm 1.504363405295e-01
    0 KSP Residual norm 1.622388030195e+01
    1 KSP Residual norm 9.598596291082e-15
    6 KSP Residual norm 1.491015929887e-01
    0 KSP Residual norm 1.711987132934e+01
    1 KSP Residual norm 9.648436647953e-15
    7 KSP Residual norm 1.203534873699e-01
    0 KSP Residual norm 8.561471454393e+00
    1 KSP Residual norm 6.095012008259e-15
    8 KSP Residual norm 1.129338478244e-01
    0 KSP Residual norm 9.113869007125e+00
    1 KSP Residual norm 5.635175307550e-15
    9 KSP Residual norm 9.412298012302e-02
    0 KSP Residual norm 7.867446395666e+00
    1 KSP Residual norm 5.308787069292e-15
   10 KSP Residual norm 9.076344069699e-02
    0 KSP Residual norm 9.111884792764e+00
    1 KSP Residual norm 4.585644747924e-15
   11 KSP Residual norm 8.864297546579e-02
    0 KSP Residual norm 5.569461905956e+00
    1 KSP Residual norm 2.698380151461e-15
   12 KSP Residual norm 5.115236257501e-02
    0 KSP Residual norm 8.935129989983e+00
    1 KSP Residual norm 4.332144654425e-15
   13 KSP Residual norm 4.481643764200e-02
    0 KSP Residual norm 2.390181565186e+01
    1 KSP Residual norm 1.248562714000e-14
   14 KSP Residual norm 4.241523078453e-02
    0 KSP Residual norm 1.774493089199e+01
    1 KSP Residual norm 8.532117108176e-15
   15 KSP Residual norm 3.417337301035e-02
    0 KSP Residual norm 5.919235593232e+00
    1 KSP Residual norm 3.970215047557e-15
   16 KSP Residual norm 3.108911404130e-02
    0 KSP Residual norm 1.591664532146e+01
    1 KSP Residual norm 9.667065076883e-15
   17 KSP Residual norm 2.277620657164e-02
    0 KSP Residual norm 7.797600047879e+00
    1 KSP Residual norm 5.176679186923e-15
   18 KSP Residual norm 1.639271572922e-02
    0 KSP Residual norm 1.318920068597e+01
    1 KSP Residual norm 6.253170030367e-15
   19 KSP Residual norm 1.619319380401e-02
    0 KSP Residual norm 3.764544707982e+01
    1 KSP Residual norm 2.462908891721e-14
   20 KSP Residual norm 1.472897742746e-02
    0 KSP Residual norm 2.317333100856e+01
    1 KSP Residual norm 1.095637991572e-14
   21 KSP Residual norm 1.454869897024e-02
    0 KSP Residual norm 1.049288666085e+01
    1 KSP Residual norm 5.980964479485e-15
   22 KSP Residual norm 1.268410085656e-02
    0 KSP Residual norm 1.254603107752e+01
    1 KSP Residual norm 7.351481319161e-15
   23 KSP Residual norm 5.537616809231e-03
    0 KSP Residual norm 3.084124465773e+01
    1 KSP Residual norm 2.056359178445e-14
   24 KSP Residual norm 4.035596019528e-03
    0 KSP Residual norm 1.874909563488e+01
    1 KSP Residual norm 1.108739232485e-14
   25 KSP Residual norm 3.734776718350e-03
    0 KSP Residual norm 5.464253943112e+00
    1 KSP Residual norm 2.340278829916e-15
   26 KSP Residual norm 1.908455217505e-03
    0 KSP Residual norm 1.104496809103e+01
    1 KSP Residual norm 6.713282665205e-15
   27 KSP Residual norm 1.301798524704e-03
    0 KSP Residual norm 5.816124801554e+00
    1 KSP Residual norm 4.186724343140e-15
   28 KSP Residual norm 1.300974942151e-03
    0 KSP Residual norm 5.308031782782e+01
    1 KSP Residual norm 3.418754736403e-14
   29 KSP Residual norm 6.699990870445e-04
    0 KSP Residual norm 8.133054255347e+01
    1 KSP Residual norm 4.611113512061e-14
    0 KSP Residual norm 6.649242661504e-01
    1 KSP Residual norm 6.275354901241e-16
   30 KSP Residual norm 2.264634759192e-04
    0 KSP Residual norm 2.259693533077e+01
    1 KSP Residual norm 1.208079839116e-14
   31 KSP Residual norm 2.259029118632e-04
    0 KSP Residual norm 7.355699745753e+01
    1 KSP Residual norm 5.314817710931e-14
   32 KSP Residual norm 2.235265647802e-04
    0 KSP Residual norm 4.279431355060e+01
    1 KSP Residual norm 2.163416708995e-14
   33 KSP Residual norm 2.160330139606e-04
    0 KSP Residual norm 2.976331189059e+01
    1 KSP Residual norm 1.805719527130e-14
   34 KSP Residual norm 2.103972955743e-04
    0 KSP Residual norm 1.916935366136e+01
    1 KSP Residual norm 1.122048193810e-14
   35 KSP Residual norm 2.084486759714e-04
    0 KSP Residual norm 1.813466960479e+01
    1 KSP Residual norm 1.078964070295e-14
   36 KSP Residual norm 1.998184711285e-04
    0 KSP Residual norm 1.238583715918e+01
    1 KSP Residual norm 6.518916445052e-15
   37 KSP Residual norm 1.995442017291e-04
    0 KSP Residual norm 1.106750683761e+01
    1 KSP Residual norm 6.139614465238e-15
   38 KSP Residual norm 1.673417490448e-04
    0 KSP Residual norm 6.801972298915e+00
    1 KSP Residual norm 3.308071991861e-15
   39 KSP Residual norm 1.640347139666e-04
    0 KSP Residual norm 7.886311041541e+00
    1 KSP Residual norm 4.727711665107e-15
   40 KSP Residual norm 1.532482827507e-04
    0 KSP Residual norm 2.357082702798e+01
    1 KSP Residual norm 1.350689741244e-14
   41 KSP Residual norm 1.524699383850e-04
    0 KSP Residual norm 1.334880543637e+01
    1 KSP Residual norm 1.038849189409e-14
   42 KSP Residual norm 1.326740371764e-04
    0 KSP Residual norm 7.613405829492e+00
    1 KSP Residual norm 4.351469045081e-15
   43 KSP Residual norm 9.702146143517e-05
    0 KSP Residual norm 8.344940891608e+00
    1 KSP Residual norm 5.223445727563e-15
   44 KSP Residual norm 9.701957156472e-05
    0 KSP Residual norm 1.500120922077e+01
    1 KSP Residual norm 7.343137005473e-15
   45 KSP Residual norm 8.589372653172e-05
    0 KSP Residual norm 8.438410329744e+00
    1 KSP Residual norm 5.389480482248e-15
   46 KSP Residual norm 8.496029911613e-05
    0 KSP Residual norm 8.253517408867e+00
    1 KSP Residual norm 3.902550193105e-15
   47 KSP Residual norm 7.688125158693e-05
    0 KSP Residual norm 1.402387747121e+01
    1 KSP Residual norm 8.804993340094e-15
   48 KSP Residual norm 7.215610809159e-05
    0 KSP Residual norm 1.210264588773e+01
    1 KSP Residual norm 5.236690525330e-15
   49 KSP Residual norm 5.345162832655e-05
    0 KSP Residual norm 2.987837617226e+01
    1 KSP Residual norm 1.338727965951e-14
   50 KSP Residual norm 3.156343000770e-05
    0 KSP Residual norm 2.540807976137e+01
    1 KSP Residual norm 1.107249944979e-14
   51 KSP Residual norm 3.053522075305e-05
    0 KSP Residual norm 3.830313802276e+01
    1 KSP Residual norm 1.760193567014e-14
   52 KSP Residual norm 1.633994412866e-05
    0 KSP Residual norm 3.265827563112e+01
    1 KSP Residual norm 1.998832119322e-14
   53 KSP Residual norm 7.266025291062e-06
    0 KSP Residual norm 4.848423047101e+01
    1 KSP Residual norm 2.394486478782e-14
   54 KSP Residual norm 4.779862162525e-06
    0 KSP Residual norm 2.873351653264e+01
    1 KSP Residual norm 1.326653645744e-14
   55 KSP Residual norm 4.289115120672e-06
    0 KSP Residual norm 2.147848066320e+01
    1 KSP Residual norm 1.093806167006e-14
   56 KSP Residual norm 2.130089431312e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 56
    0 KSP Residual norm 1.020423824033e+00
    1 KSP Residual norm 1.340495878854e-15
  1 KSP unpreconditioned resid norm 5.518013746793e+09 true resid norm 5.518013746793e+09 ||r(i)||/||b|| 2.322794676640e-01
    0 KSP Residual norm 9.921649121308e-01
    0 KSP Residual norm 8.786684935264e+00
    1 KSP Residual norm 6.300573552342e-15
    1 KSP Residual norm 9.846150887323e-01
    0 KSP Residual norm 1.982900774306e+01
    1 KSP Residual norm 1.175913600201e-14
    2 KSP Residual norm 9.845295387442e-01
    0 KSP Residual norm 1.064326577914e+01
    1 KSP Residual norm 5.258040320685e-15
    3 KSP Residual norm 9.550877928390e-01
    0 KSP Residual norm 8.011781346614e+01
    1 KSP Residual norm 5.091014818918e-14
    4 KSP Residual norm 7.382688784340e-01
    0 KSP Residual norm 2.757292807303e+01
    1 KSP Residual norm 1.734378343854e-14
    5 KSP Residual norm 6.548392876144e-01
    0 KSP Residual norm 2.746825441526e+01
    1 KSP Residual norm 1.502786203235e-14
    6 KSP Residual norm 6.542185211824e-01
    0 KSP Residual norm 1.110142258010e+01
    1 KSP Residual norm 6.500412657488e-15
    7 KSP Residual norm 6.166015616760e-01
    0 KSP Residual norm 1.504330846262e+01
    1 KSP Residual norm 9.150321495498e-15
    8 KSP Residual norm 6.018805768301e-01
    0 KSP Residual norm 1.819469112227e+01
    1 KSP Residual norm 9.917949871378e-15
    9 KSP Residual norm 5.101663323566e-01
    0 KSP Residual norm 5.219244177922e+00
    1 KSP Residual norm 2.566905173517e-15
   10 KSP Residual norm 5.082790563248e-01
    0 KSP Residual norm 6.057731883008e+00
    1 KSP Residual norm 3.788570094014e-15
   11 KSP Residual norm 4.259267623713e-01
    0 KSP Residual norm 3.913073719114e+00
    1 KSP Residual norm 2.648276587257e-15
   12 KSP Residual norm 4.217605191516e-01
    0 KSP Residual norm 1.546853992536e+01
    1 KSP Residual norm 7.586472222653e-15
   13 KSP Residual norm 3.645455167577e-01
    0 KSP Residual norm 2.232787025706e+01
    1 KSP Residual norm 1.332033120817e-14
   14 KSP Residual norm 2.963053714929e-01
    0 KSP Residual norm 1.031462030172e+01
    1 KSP Residual norm 5.064897993862e-15
   15 KSP Residual norm 2.950586509416e-01
    0 KSP Residual norm 1.271490936555e+01
    1 KSP Residual norm 5.959609491498e-15
   16 KSP Residual norm 2.509465967902e-01
    0 KSP Residual norm 8.339336422925e+00
    1 KSP Residual norm 4.611842071541e-15
   17 KSP Residual norm 1.816083599502e-01
    0 KSP Residual norm 1.869180645027e+01
    1 KSP Residual norm 9.516921481679e-15
   18 KSP Residual norm 1.785417729810e-01
    0 KSP Residual norm 7.143628637419e+00
    1 KSP Residual norm 4.117829217383e-15
   19 KSP Residual norm 1.311181348810e-01
    0 KSP Residual norm 5.308755912250e+00
    1 KSP Residual norm 2.973736047510e-15
   20 KSP Residual norm 1.034998543700e-01
    0 KSP Residual norm 1.235426150209e+01
    1 KSP Residual norm 5.546613973367e-15
   21 KSP Residual norm 9.296803910151e-02
    0 KSP Residual norm 2.364943420264e+01
    1 KSP Residual norm 1.442397276091e-14
   22 KSP Residual norm 4.194011567465e-02
    0 KSP Residual norm 3.654021421986e+01
    1 KSP Residual norm 2.187300113984e-14
   23 KSP Residual norm 3.685382820500e-02
    0 KSP Residual norm 4.800600601628e+01
    1 KSP Residual norm 2.969039908430e-14
   24 KSP Residual norm 3.523119764435e-02
    0 KSP Residual norm 2.726790062548e+01
    1 KSP Residual norm 1.323712596846e-14
   25 KSP Residual norm 2.152327979441e-02
    0 KSP Residual norm 1.096196086907e+01
    1 KSP Residual norm 5.359278004446e-15
   26 KSP Residual norm 2.143614849769e-02
    0 KSP Residual norm 3.048874304328e+01
    1 KSP Residual norm 1.334835347090e-14
   27 KSP Residual norm 1.693569452346e-02
    0 KSP Residual norm 1.128480634134e+01
    1 KSP Residual norm 6.649264895961e-15
   28 KSP Residual norm 5.564609247553e-03
    0 KSP Residual norm 6.557918235445e+01
    1 KSP Residual norm 3.227129301566e-14
   29 KSP Residual norm 1.769604988520e-03
    0 KSP Residual norm 2.644329330955e+01
    1 KSP Residual norm 1.369295734449e-14
    0 KSP Residual norm 4.013628445075e+00
    1 KSP Residual norm 2.297023413331e-15
   30 KSP Residual norm 3.780292422787e-04
    0 KSP Residual norm 9.878549878832e+01
    1 KSP Residual norm 5.582808788638e-14
   31 KSP Residual norm 3.779609717168e-04
    0 KSP Residual norm 5.524185725671e+01
    1 KSP Residual norm 2.948925583795e-14
   32 KSP Residual norm 3.761891968007e-04
    0 KSP Residual norm 7.261547123354e+01
    1 KSP Residual norm 4.339446472292e-14
   33 KSP Residual norm 3.453463015746e-04
    0 KSP Residual norm 1.032561955001e+01
    1 KSP Residual norm 5.670375392335e-15
   34 KSP Residual norm 3.323439164298e-04
    0 KSP Residual norm 2.237735451509e+01
    1 KSP Residual norm 1.259118333623e-14
   35 KSP Residual norm 3.312643911003e-04
    0 KSP Residual norm 8.483656967206e+00
    1 KSP Residual norm 4.577586639900e-15
   36 KSP Residual norm 2.933977342983e-04
    0 KSP Residual norm 2.263968932249e+01
    1 KSP Residual norm 1.195090229111e-14
   37 KSP Residual norm 2.927559292018e-04
    0 KSP Residual norm 4.570173088691e+01
    1 KSP Residual norm 2.439856809117e-14
   38 KSP Residual norm 2.766456470778e-04
    0 KSP Residual norm 1.543641058302e+01
    1 KSP Residual norm 9.512540695658e-15
   39 KSP Residual norm 2.722351685899e-04
    0 KSP Residual norm 2.960108743626e+01
    1 KSP Residual norm 1.638507242437e-14
   40 KSP Residual norm 1.966809871057e-04
    0 KSP Residual norm 3.181169858553e+01
    1 KSP Residual norm 1.491899872836e-14
   41 KSP Residual norm 1.960355506999e-04
    0 KSP Residual norm 1.102852988449e+01
    1 KSP Residual norm 6.139303597704e-15
   42 KSP Residual norm 1.579088890931e-04
    0 KSP Residual norm 1.955001444291e+01
    1 KSP Residual norm 1.119075160254e-14
   43 KSP Residual norm 1.498343643989e-04
    0 KSP Residual norm 1.119714756404e+01
    1 KSP Residual norm 5.435830585621e-15
   44 KSP Residual norm 1.177012410410e-04
    0 KSP Residual norm 2.149957637981e+01
    1 KSP Residual norm 1.414378886080e-14
   45 KSP Residual norm 9.618179814688e-05
    0 KSP Residual norm 5.001393397970e+00
    1 KSP Residual norm 2.168754284658e-15
   46 KSP Residual norm 9.617788353595e-05
    0 KSP Residual norm 1.105047015469e+01
    1 KSP Residual norm 6.959946362637e-15
   47 KSP Residual norm 7.273688620090e-05
    0 KSP Residual norm 3.219260106164e+01
    1 KSP Residual norm 1.629207059504e-14
   48 KSP Residual norm 6.571848764176e-05
    0 KSP Residual norm 1.270553344009e+01
    1 KSP Residual norm 5.509909853652e-15
   49 KSP Residual norm 6.452998487040e-05
    0 KSP Residual norm 2.022029856595e+01
    1 KSP Residual norm 1.077753660865e-14
   50 KSP Residual norm 3.951376554426e-05
    0 KSP Residual norm 1.406626662353e+01
    1 KSP Residual norm 7.075535826621e-15
   51 KSP Residual norm 3.938931734863e-05
    0 KSP Residual norm 1.388041353344e+01
    1 KSP Residual norm 7.968359529568e-15
   52 KSP Residual norm 3.038877167921e-05
    0 KSP Residual norm 4.510270920614e+01
    1 KSP Residual norm 3.017984388501e-14
   53 KSP Residual norm 1.730421998562e-05
    0 KSP Residual norm 1.762064545159e+01
    1 KSP Residual norm 8.988961441533e-15
   54 KSP Residual norm 1.009814936425e-05
    0 KSP Residual norm 2.504153920060e+01
    1 KSP Residual norm 1.544394188030e-14
   55 KSP Residual norm 9.315642093529e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 55
    0 KSP Residual norm 4.039500133857e+00
    1 KSP Residual norm 1.693585899029e-15
  2 KSP unpreconditioned resid norm 5.468663366545e+04 true resid norm 5.468663366544e+04 ||r(i)||/||b|| 2.302020752218e-06
    0 KSP Residual norm 9.999660137454e-01
    0 KSP Residual norm 1.512966219295e+01
    1 KSP Residual norm 8.466432884640e-15
    1 KSP Residual norm 9.999651564078e-01
    0 KSP Residual norm 2.994288764858e+01
    1 KSP Residual norm 1.711280396368e-14
    2 KSP Residual norm 9.994185927841e-01
    0 KSP Residual norm 5.567501839169e+01
    1 KSP Residual norm 2.327531957351e-14
    3 KSP Residual norm 9.980051058368e-01
    0 KSP Residual norm 6.220771381500e+01
    1 KSP Residual norm 2.851758386798e-14
    4 KSP Residual norm 9.944061357622e-01
    0 KSP Residual norm 1.210667437341e+01
    1 KSP Residual norm 7.918678254417e-15
    5 KSP Residual norm 9.926732118291e-01
    0 KSP Residual norm 1.710051059968e+01
    1 KSP Residual norm 1.031198893709e-14
    6 KSP Residual norm 9.892888332377e-01
    0 KSP Residual norm 1.065143304135e+01
    1 KSP Residual norm 5.120284635222e-15
    7 KSP Residual norm 9.423300046616e-01
    0 KSP Residual norm 7.795802699122e+00
    1 KSP Residual norm 6.049395267594e-15
    8 KSP Residual norm 9.423277208555e-01
    0 KSP Residual norm 1.607454810811e+01
    1 KSP Residual norm 1.136826940611e-14
    9 KSP Residual norm 8.902036915271e-01
    0 KSP Residual norm 1.545261073989e+01
    1 KSP Residual norm 7.685240753800e-15
   10 KSP Residual norm 8.691165837785e-01
    0 KSP Residual norm 1.004819978325e+01
    1 KSP Residual norm 4.836988811849e-15
   11 KSP Residual norm 8.177375284121e-01
    0 KSP Residual norm 1.224742916689e+01
    1 KSP Residual norm 8.017639380786e-15
   12 KSP Residual norm 8.148035496617e-01
    0 KSP Residual norm 5.490916395786e+00
    1 KSP Residual norm 4.218343229663e-15
   13 KSP Residual norm 7.686550907751e-01
    0 KSP Residual norm 1.863707110986e+01
    1 KSP Residual norm 9.836415324799e-15
   14 KSP Residual norm 7.631125961607e-01
    0 KSP Residual norm 6.961151505734e+00
    1 KSP Residual norm 3.983069193141e-15
   15 KSP Residual norm 6.578122073809e-01
    0 KSP Residual norm 1.587829981409e+01
    1 KSP Residual norm 8.048592135319e-15
   16 KSP Residual norm 5.618775907525e-01
    0 KSP Residual norm 1.340318743246e+01
    1 KSP Residual norm 9.056459718356e-15
   17 KSP Residual norm 5.588123879404e-01
    0 KSP Residual norm 3.072081083047e+01
    1 KSP Residual norm 1.644987691963e-14
   18 KSP Residual norm 4.188304169445e-01
    0 KSP Residual norm 2.264335868720e+01
    1 KSP Residual norm 1.220794237774e-14
   19 KSP Residual norm 3.126485943590e-01
    0 KSP Residual norm 1.012967342147e+01
    1 KSP Residual norm 4.654532243035e-15
   20 KSP Residual norm 2.598228967616e-01
    0 KSP Residual norm 4.043843349481e+01
    1 KSP Residual norm 2.116726666204e-14
   21 KSP Residual norm 1.310574819467e-01
    0 KSP Residual norm 4.095731649043e+01
    1 KSP Residual norm 2.113250959118e-14
   22 KSP Residual norm 1.057293976409e-01
    0 KSP Residual norm 2.020225055281e+01
    1 KSP Residual norm 1.369072336849e-14
   23 KSP Residual norm 7.581876193623e-02
    0 KSP Residual norm 1.386480955463e+01
    1 KSP Residual norm 9.593263139405e-15
   24 KSP Residual norm 2.702311026908e-02
    0 KSP Residual norm 7.558249339488e+00
    1 KSP Residual norm 3.738309153297e-15
   25 KSP Residual norm 2.501151584374e-02
    0 KSP Residual norm 4.249618163888e+01
    1 KSP Residual norm 2.606677327976e-14
   26 KSP Residual norm 2.098141467454e-02
    0 KSP Residual norm 4.980653251345e+01
    1 KSP Residual norm 3.085739367977e-14
   27 KSP Residual norm 5.319308686431e-03
    0 KSP Residual norm 7.561559510835e+01
    1 KSP Residual norm 4.682604537783e-14
   28 KSP Residual norm 2.357578266531e-03
    0 KSP Residual norm 7.697543500140e+00
    1 KSP Residual norm 4.705437412484e-15
   29 KSP Residual norm 7.831623172258e-04
    0 KSP Residual norm 1.552171877694e+01
    1 KSP Residual norm 8.274479026171e-15
    0 KSP Residual norm 9.832210783163e+00
    1 KSP Residual norm 5.127892959467e-15
   30 KSP Residual norm 2.224830879397e-04
    0 KSP Residual norm 4.730826658204e+01
    1 KSP Residual norm 2.645799065112e-14
   31 KSP Residual norm 2.222038938192e-04
    0 KSP Residual norm 5.194629282389e+01
    1 KSP Residual norm 2.529145394481e-14
   32 KSP Residual norm 2.172372103427e-04
    0 KSP Residual norm 6.401608062279e+01
    1 KSP Residual norm 3.696831155297e-14
   33 KSP Residual norm 2.086657654397e-04
    0 KSP Residual norm 2.613724980915e+01
    1 KSP Residual norm 1.424783750506e-14
   34 KSP Residual norm 2.078584508122e-04
    0 KSP Residual norm 1.678222730477e+01
    1 KSP Residual norm 9.846634634588e-15
   35 KSP Residual norm 2.026965179502e-04
    0 KSP Residual norm 2.492173520125e+01
    1 KSP Residual norm 1.233283083744e-14
   36 KSP Residual norm 1.968355930907e-04
    0 KSP Residual norm 3.151121176221e+01
    1 KSP Residual norm 1.459698625490e-14
   37 KSP Residual norm 1.963770357554e-04
    0 KSP Residual norm 6.659693841222e+00
    1 KSP Residual norm 2.851591003851e-15
   38 KSP Residual norm 1.743036703175e-04
    0 KSP Residual norm 6.898868752942e+00
    1 KSP Residual norm 3.915083832774e-15
   39 KSP Residual norm 1.594980545053e-04
    0 KSP Residual norm 1.161844406360e+01
    1 KSP Residual norm 7.104272159155e-15
   40 KSP Residual norm 1.563819578420e-04
    0 KSP Residual norm 4.174928568690e+00
    1 KSP Residual norm 2.736188681388e-15
   41 KSP Residual norm 1.436521416665e-04
    0 KSP Residual norm 1.266991290007e+01
    1 KSP Residual norm 7.315039100890e-15
   42 KSP Residual norm 1.003788321403e-04
    0 KSP Residual norm 7.072816720445e+00
    1 KSP Residual norm 3.214074293067e-15
   43 KSP Residual norm 7.735059060567e-05
    0 KSP Residual norm 1.196219446995e+01
    1 KSP Residual norm 6.709790075083e-15
   44 KSP Residual norm 7.106374657769e-05
    0 KSP Residual norm 1.172536791568e+01
    1 KSP Residual norm 6.350834757822e-15
   45 KSP Residual norm 4.533210969996e-05
    0 KSP Residual norm 5.948305762127e+00
    1 KSP Residual norm 3.631931750053e-15
   46 KSP Residual norm 3.855331321954e-05
    0 KSP Residual norm 6.995034077642e+00
    1 KSP Residual norm 3.493881144042e-15
   47 KSP Residual norm 3.380297750312e-05
    0 KSP Residual norm 6.559035831681e+00
    1 KSP Residual norm 3.762657305592e-15
   48 KSP Residual norm 2.758375321853e-05
    0 KSP Residual norm 1.463600681096e+01
    1 KSP Residual norm 9.925614576717e-15
   49 KSP Residual norm 2.713608472722e-05
    0 KSP Residual norm 3.641339591064e+01
    1 KSP Residual norm 2.288329222235e-14
   50 KSP Residual norm 1.644008204304e-05
    0 KSP Residual norm 2.777796092614e+01
    1 KSP Residual norm 1.736200237872e-14
   51 KSP Residual norm 1.601928968478e-05
    0 KSP Residual norm 8.608269728513e+01
    1 KSP Residual norm 4.736176807131e-14
   52 KSP Residual norm 1.435535309320e-05
    0 KSP Residual norm 4.005888854858e+01
    1 KSP Residual norm 2.201592997318e-14
   53 KSP Residual norm 5.863164482628e-06
  Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 53
    0 KSP Residual norm 9.832346329590e+00
    1 KSP Residual norm 4.680739207301e-15
  3 KSP unpreconditioned resid norm 3.034412141321e-01 true resid norm 3.034423463859e-01 ||r(i)||/||b|| 1.277333292730e-11
KSP Object: 4 MPI processes
  type: fgmres
  maximum iterations=1000, initial guess is zero
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
PC Object: 4 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization UPPER
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       4 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_0_)       4 MPI processes
        type: lu
          matrix ordering: natural
              Mat Object:               4 MPI processes
                type: mpiaij
                rows=624, cols=624
                total: nonzeros=134430, allocated nonzeros=134430
                    ICNTL(18) (input mat struct):                           3
                    ICNTL(21) (solution struct):                            1
                      [0] 2.11737e+06
                      [1] 5.16896e+06
                      [2] 8.22021e+06
                      [3] 2.19477e+06
                      [0]  26687.
                      [1]  45712.
                      [2]  81753.
                      [3]  30601.
                      [0]  2.11737e+06
                      [1]  5.16896e+06
                      [2]  8.22021e+06
                      [3]  2.19477e+06
                    [0] 11
                    [1] 12
                    [2] 12
                    [3] 11
                      [0] 11
                      [1] 12
                      [2] 12
                      [3] 11
                      [0] 118
                      [1] 129
                      [2] 303
                      [3] 74
                    RINFOG(1) (global estimated flops for the elimination after analysis): 1.77013e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 184753.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 1.77013e+07
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 134430
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 5517
                    INFOG(5) (estimated maximum front size in the complete tree): 219
                    INFOG(6) (number of nodes in the complete tree): 25
                    INFOG(7) (ordering option effectively use after analysis): 2
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 134430
                    INFOG(10) (total integer space store the matrix factors after factorization): 5517
                    INFOG(11) (order of largest frontal matrix after factorization): 219
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 12
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 46
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 12
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 46
                    INFOG(20) (estimated number of entries in the factors): 134430
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 12
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 45
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 134430
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): 7
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         4 MPI processes
          type: mpiaij
          rows=624, cols=624
          total: nonzeros=71358, allocated nonzeros=71358
            using I-node (on process 0) routines: found 66 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       4 MPI processes
        type: fgmres
      PC Object:      (fieldsplit_1_)       4 MPI processes
        type: lu
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=3450, allocated nonzeros=3450
                      [0] 0.
                      [1] 0.
                      [2] 0.
                      [3] 113595.
                      [0]  0.
                      [1]  0.
                      [2]  0.
                      [3]  784.
                      [0]  0.
                      [1]  0.
                      [2]  0.
                      [3]  113595.
                    [0] 1
                    [1] 1
                    [2] 1
                    [3] 1
                      [0] 1
                      [1] 1
                      [2] 1
                      [3] 1
                      [0] 0
                      [1] 0
                      [2] 0
                      [3] 64
                    RINFOG(1) (global estimated flops for the elimination after analysis): 113595.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 784.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 113595.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3450
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 214
                    INFOG(5) (estimated maximum front size in the complete tree): 47
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3450
                    INFOG(10) (total integer space store the matrix factors after factorization): 214
                    INFOG(11) (order of largest frontal matrix after factorization): 47
                    INFOG(12) (number of off-diagonal pivots): 1
                    INFOG(20) (estimated number of entries in the factors): 3450
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3450
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_1_)         4 MPI processes
          type: schurcomplement
          rows=64, cols=64
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=1550, allocated nonzeros=1550
                  using I-node (on process 0) routines: found 48 nodes, limit used is 5
            A10
                type: mpiaij
                rows=64, cols=624
                total: nonzeros=6916, allocated nonzeros=6916
            KSP of A00
                type: fgmres
                type: lu
                        type: mpiaij
                        rows=624, cols=624
                              [0] 2.11737e+06
                              [1] 5.16896e+06
                              [2] 8.22021e+06
                              [3] 2.19477e+06
                              [0]  26687.
                              [1]  45712.
                              [2]  81753.
                              [3]  30601.
                              [0]  2.11737e+06
                              [1]  5.16896e+06
                              [2]  8.22021e+06
                              [3]  2.19477e+06
                            [0] 11
                            [1] 12
                            [2] 12
                            [3] 11
                              [0] 11
                              [1] 12
                              [2] 12
                              [3] 11
                              [0] 118
                              [1] 129
                              [2] 303
                              [3] 74
                  type: mpiaij
                  rows=624, cols=624
            A01
                type: mpiaij
                rows=624, cols=64
          type: mpiaij
          rows=64, cols=64
          total: nonzeros=3246, allocated nonzeros=3246
            using I-node (on process 0) routines: found 30 nodes, limit used is 5
    type: mpiaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=101416
      using I-node (on process 0) routines: found 72 nodes, limit used is 5
