[petsc-users] Fieldsplit with sub pc MUMPS in parallel
Karin&NiKo niko.karin at gmail.com
Thu Jan 5 05:11:04 CST 2017
Dear Barry, dear Dave,
THANK YOU!
You two pointed out the right problem.By using the options you provided
(-fieldsplit_0_ksp_type gmres -fieldsplit_0_ksp_pc_side right
-fieldsplit_1_ksp_type gmres -fieldsplit_1_ksp_pc_side right), the solver
converges in 3 iterations whatever the size of the communicator.
All the trick is in the precise resolution of the Schur complement, by
using a Krylov method (and not only preonly) *and* applying the
preconditioner on the right (so evaluating the convergence on the
unpreconditioned residual).
@Barry : the difference you see on the nonzero allocations for the
different runs is just an artefact : when using more than one proc, we
slighly over-estimate the number of non-zero terms. If I run the same
problem with the -info option, I get extra information :
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 110 X 110; storage space: 0
unneeded,5048 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 271 X 271; storage space: 4249
unneeded,26167 used
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 307 X 307; storage space: 7988
unneeded,31093 used
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 110 X 244; storage space: 0
unneeded,6194 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 271 X 233; storage space: 823
unneeded,9975 used
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 307 X 197; storage space: 823
unneeded,8263 used
And 5048+26167+31093+6194+9975+8263=86740 which is the number of exactly
estimated nonzero terms for 1 proc.
Thank you again!
Best regards,
Nicolas
2017-01-05 1:36 GMT+01:00 Barry Smith <bsmith at mcs.anl.gov>:
>    There is something wrong with your set up.
> 1 process
>            total: nonzeros=140616, allocated nonzeros=140616
>           total: nonzeros=68940, allocated nonzeros=68940
>                 total: nonzeros=3584, allocated nonzeros=3584
>                 total: nonzeros=1000, allocated nonzeros=1000
>                 total: nonzeros=8400, allocated nonzeros=8400
> 2 processes
>                 total: nonzeros=146498, allocated nonzeros=146498
>           total: nonzeros=73470, allocated nonzeros=73470
>                 total: nonzeros=3038, allocated nonzeros=3038
>                 total: nonzeros=1110, allocated nonzeros=1110
>                 total: nonzeros=6080, allocated nonzeros=6080
>           total: nonzeros=2846, allocated nonzeros=2846
>     total: nonzeros=86740, allocated nonzeros=94187
>   It looks like you are setting up the problem differently in parallel and
> seq. If it is suppose to be an identical problem then the number nonzeros
> should be the same in at least the first two matrices.
> > On Jan 4, 2017, at 3:39 PM, Karin&NiKo <niko.karin at gmail.com> wrote:
> > Dear Petsc team,
> > I am (still) trying to solve Biot's poroelasticity problem :
> >  <image.png>
> > I am using a mixed P2-P1 finite element discretization. The matrix of
> the discretized system in binary format is attached to this email.
> > I am using the fieldsplit framework to solve the linear system. Since I
> am facing some troubles, I have decided to go back to simple things. Here
> are the options I am using :
> > -ksp_rtol 1.0e-5
> > -ksp_type fgmres
> > -pc_type fieldsplit
> > -pc_fieldsplit_schur_factorization_type full
> > -pc_fieldsplit_type schur
> > -pc_fieldsplit_schur_precondition selfp
> > -fieldsplit_0_pc_type lu
> > -fieldsplit_0_pc_factor_mat_solver_package mumps
> > -fieldsplit_0_ksp_type preonly
> > -fieldsplit_0_ksp_converged_reason
> > -fieldsplit_1_pc_type lu
> > -fieldsplit_1_pc_factor_mat_solver_package mumps
> > -fieldsplit_1_ksp_type preonly
> > -fieldsplit_1_ksp_converged_reason
> > On a single proc, everything runs fine : the solver converges in 3
> iterations, according to the theory (see Run-1-proc.txt [contains
> -log_view]).
> > On 2 procs, the solver converges in 28 iterations (see Run-2-proc.txt).
> > On 3 procs, the solver converges in 91 iterations (see Run-3-proc.txt).
> > I do not understand this behavior : since MUMPS is a parallel direct
> solver, shouldn't the solver converge in max 3 iterations whatever the
> number of procs?
> > Thanks for your precious help,
> > Nicolas
> > <Run-1-proc.txt><Run-2-proc.txt><Run-3-proc.txt><1_Warning.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170105/eb5ba915/attachment.html>
