[petsc-users] problems after glibc upgrade to 2.17-157
Klaij, Christiaan C.Klaij at marin.nl
Thu Jan 5 02:37:49 CST 2017
Satish, Matt
Our sysadmin tells me Scientific Linux is still busy with the
RedHat 7.3 update, so yes, this is a partial update somewhere
between 7.2 and 7.3...
No luck with the quotes on my system, but the option
--with-shared-libraries=0 does work! make test gives:
Running test examples to verify correct installation
Using PETSC_DIR=/projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/install/petsc-3.7.4 and PETSC_ARCH=
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI processes
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
I've also tested the standalone program of metis, that works too:
$ ./gpmetis
Missing parameters.
   Usage: gpmetis [options] <filename> <nparts>
          use 'gpmetis -help' for a summary of the options.
So problem solved for now, thanks to you and Matt for all your
help! On the long run I will go for Intel-17 on SL7.3.
What worries me though is that a simple update (which happens all
the time according to sysadmin) can have such a dramatic effect.
Thanks again,
Chris
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Comparison-of-uRANS-and-BEMBEM-for-propeller-pressure-pulse-prediction.htm
Sent: Wednesday, January 04, 2017 7:24 PM
To: petsc-users
Cc: Klaij, Christiaan
Subject: Re: [petsc-users] problems after glibc upgrade to 2.17-157
On Wed, 4 Jan 2017, Satish Balay wrote:
> So I guess your best bet is static libraries..
Or upgrade to intel-17 compilers.
Satish
[balay at el7 benchmarks]$ icc --version
icc (ICC) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
[balay at el7 benchmarks]$ icc sizeof.c -lifcore
[balay at el7 benchmarks]$ ldd a.out
        linux-vdso.so.1 =>  (0x00007ffed4b02000)
        libifcore.so.5 => /soft/com/packages/intel/17/u1/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/libifcore.so.5 (0x00007f5a65430000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f5a65124000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f5a64f0e000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f5a64b4c000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f5a64948000)
        libimf.so => /soft/com/packages/intel/17/u1/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/libimf.so (0x00007f5a6445c000)
        libsvml.so => /soft/com/packages/intel/17/u1/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/libsvml.so (0x00007f5a63550000)
        libintlc.so.5 => /soft/com/packages/intel/17/u1/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/libintlc.so.5 (0x00007f5a632e6000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f5a65793000)
[balay at el7 benchmarks]$ ./a.out
long double : 16
double      : 8
int         : 4
char        : 1
short       : 2
long        : 8
long long   : 8
int *       : 8
size_t      : 8
