[petsc-users] VecSetSizes hangs in MPI
Manuel Valera mvalera at mail.sdsu.edu
Wed Jan 4 16:55:42 CST 2017
Thanks for the answers !
heres the screenshot of what i got from bt in gdb (great hint in how to
debug in petsc, didn't know that)
I don't really know what to look at here,
Manuel
On Wed, Jan 4, 2017 at 2:39 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Are you certain ALL ranks in PETSC_COMM_WORLD call these function(s).
> These functions cannot be inside if statements like
> if (rank == 0){
>   VecCreateMPI(...)
> On Wed, 4 Jan 2017 at 23:34, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
>> Thanks Dave for the quick answer, appreciate it,
>> I just tried that and it didn't make a difference, any other suggestions ?
>> Thanks,
>> Manuel
>> On Wed, Jan 4, 2017 at 2:29 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
>> You need to swap the order of your function calls.
>> Call VecSetSizes() before VecSetType()
>> Thanks,
>>   Dave
>> On Wed, 4 Jan 2017 at 23:21, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
>> Hello all, happy new year,
>> I'm working on parallelizing my code, it worked and provided some results
>> when i just called more than one processor, but created artifacts because i
>> didn't need one image of the whole program in each processor, conflicting
>> with each other.
>> Since the pressure solver is the main part i need in parallel im chosing
>> mpi to run everything in root processor until its time to solve for
>> pressure, at this point im trying to create a distributed vector using
>> either
>>      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,nbdp,xp,ierr)
>> or
>>      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>      call VecSetType(xp,VECMPI,ierr)
>>      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>> In both cases program hangs at this point, something it never happened on
>> the naive way i described before. I've made sure the global size, nbdp, is
>> the same in every processor. What can be wrong?
>> Thanks for your kind help,
>> Manuel.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/01679300/attachment-0001.html>
Name: Screen Shot 2017-01-04 at 2.53.05 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/01679300/attachment-0001.png>
