[petsc-users] problems after glibc upgrade to 2.17-157
Klaij, Christiaan C.Klaij at marin.nl
Wed Jan 4 03:16:18 CST 2017
Well, a bit clearer perhaps. It seems the relevant ERROR is on
line 31039. So I did this case by hand using the compile and link
lines from the log, then run it in gdb:
$ pwd
/tmp/petsc-Q0URwQ/config.setCompilers
$ ls
confdefs.h  conffix.h  conftest  conftest.F  conftest.o
$ gdb
GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-80.el7
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
(gdb) file conftest
Reading symbols from /tmp/petsc-Q0URwQ/config.setCompilers/conftest...done.
(gdb) run
Starting program: /tmp/petsc-Q0URwQ/config.setCompilers/conftest
Program received signal SIGSEGV, Segmentation fault.
0x00002aaaae32f65e in ?? ()
Missing separate debuginfos, use: debuginfo-install glibc-2.17-157.el7.x86_64
(gdb) bt
#0  0x00002aaaae32f65e in ?? ()
#1  0x00002aaaaaab7675 in _dl_relocate_object ()
   from /lib64/ld-linux-x86-64.so.2
#2  0x00002aaaaaaae792 in dl_main () from /lib64/ld-linux-x86-64.so.2
#3  0x00002aaaaaac1e36 in _dl_sysdep_start () from /lib64/ld-linux-x86-64.so.2
#4  0x00002aaaaaaafa31 in _dl_start () from /lib64/ld-linux-x86-64.so.2
#5  0x00002aaaaaaac1e8 in _start () from /lib64/ld-linux-x86-64.so.2
#6  0x0000000000000001 in ?? ()
#7  0x00007fffffffd4e2 in ?? ()
#8  0x0000000000000000 in ?? ()
(gdb)
Does this make any sense to you?
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Software-seminar-in-Shanghai-for-the-first-time-March-28.htm
Sent: Wednesday, January 04, 2017 9:26 AM
To: Matthew Knepley; petsc-users; Satish Balay
Subject: Re: [petsc-users] problems after glibc upgrade to 2.17-157
So I've applied the patch to my current 3.7.4 source, the new
configure.log is attached. It's slightly larger but not much
clearer too me...
Chris
Sent: Tuesday, January 03, 2017 5:00 PM
To: Matthew Knepley
Cc: Klaij, Christiaan; petsc-users at mcs.anl.gov
On Tue, 3 Jan 2017, Matthew Knepley wrote:
> Or get the new tarball when it spins tonight, since Satish has just
> added the fix to maint.
We don't spin 'maint/patch-release' tarballs everynight. Its every 1-3
months - [partly depending upon the number of outstanding patches - or
their severity]
-rw-r--r-- 1 petsc pdetools 23194357 Jan  1 10:41 petsc-3.7.5.tar.gz
-rw-r--r-- 1 petsc pdetools 23189526 Oct  2 22:06 petsc-3.7.4.tar.gz
-rw-r--r-- 1 petsc pdetools 23172670 Jul 24 12:22 petsc-3.7.3.tar.gz
-rw-r--r-- 1 petsc pdetools 23111802 Jun  5  2016 petsc-3.7.2.tar.gz
-rw-r--r-- 1 petsc pdetools 23113397 May 15  2016 petsc-3.7.1.tar.gz
-rw-r--r-- 1 petsc pdetools 22083999 Apr 25  2016 petsc-3.7.0.tar.gz
Satish
