[petsc-users] getting the near nullspace from PCSetCoordinates
Jed Brown jed at jedbrown.org
Mon Jan 2 17:23:48 CST 2017
Mark Adams <mfadams at lbl.gov> writes:
> On Mon, Jan 2, 2017 at 11:47 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Jeremy Theler <jeremy at seamplex.com> writes:
>> > Hi all
>> > I want to check that the near nullspace I provide to GAMG gives "almost
>> > null vectors" when multiplying each vector in the near nullspace against
>> > the matrix problem.
>> > This way I can check that the unknown ordering I am using is consistent,
>> > for example using by MatNullSpaceCreateRigidBody() or by computing the
>> > nullspace by myself.
>> Please use that and MatSetNearNullSpace().  It composes properly and you
>> can check everything.
>> PCSetCoordinates() happens to do double-duty for aggregation-based
>> methods, but outside of semi-geometric methods, it is just ugly code
>> duplication and makes assumptions that may be inappropriate (like
>> elasticity with an interpolatory basis).
> Yes, PCSetCoordinates is an old interface that is essentially deprecated.
> Maybe we should officially deprecated this.
I think we should officially deprecate it, but perhaps make something
more general available as a Mat function (since some algorithms may use
coordinates directly).  (Needing to dig up a PC to provide problem (as
opposed to configuration) information is bad style.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170102/e70a2e68/attachment.pgp>
