[petsc-users] Error with SuperLU_DIST (mkl related?)
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Sun Jan 1 06:45:52 CST 2017
ok, using petsc-3.7.4 but with SuperLU_DIST 5.1.3
(--download-superlu_dist-commit=v5.1.3) fixed the issue!
Thanks to both of you and happy new year! :)
Eric
Le 2016-12-31 à 11:51, Matthew Knepley a écrit :
> On Sat, Dec 31, 2016 at 9:53 AM, Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>     Hi,
>     I am just starting to debug a bug encountered with and only with
>     SuperLU_Dist combined with MKL on a 2 processes validation test.
>     (the same test works fine with MUMPS on 2 processes).
>     I just noticed that the SuperLU_Dist version installed by PETSc
>     configure script is 5.1.0 and the latest SuperLU_DIST is 5.1.3.
>     Before going further, I just want to ask:
>     Is there any specific reason to stick to 5.1.0?
> Can you debug in 'master' which does have 5.1.3, including an
> important bug fix?
>    Matt
>     Here is some more information:
>     On process 2 I have this printed in stdout:
>     Intel MKL ERROR: Parameter 6 was incorrect on entry to DTRSM .
>     and in stderr:
>     Test.ProblemeEFGen.opt: malloc.c:2369: sysmalloc: Assertion
>     `(old_top == (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2]))
>     - __builtin_offsetof (struct malloc_chunk, fd)))) && old_size ==
>     0) || ((unsigned long) (old_size) >= (unsigned
>     long)((((__builtin_offsetof (struct malloc_chunk,
>     fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2
>     *(sizeof(size_t))) - 1))) && ((old_top)->size & 0x1) && ((unsigned
>     long) old_end & pagemask) == 0)' failed.
>     [saruman:15771] *** Process received signal ***
>     This is the 7th call to KSPSolve in the same execution. Here is
>     the last KSPView:
>     KSP Object:(o_slin) 2 MPI processes
>       type: preonly
>       maximum iterations=10000, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>       left preconditioning
>       using NONE norm type for convergence test
>     PC Object:(o_slin) 2 MPI processes
>       type: lu
>         LU: out-of-place factorization
>         tolerance for zero pivot 2.22045e-14
>         matrix ordering: natural
>         factor fill ratio given 0., needed 0.
>           Factored matrix follows:
>             Mat Object:         2 MPI processes
>               type: mpiaij
>               rows=382, cols=382
>               package used to perform factorization: superlu_dist
>               total: nonzeros=0, allocated nonzeros=0
>               total number of mallocs used during MatSetValues calls =0
>                 SuperLU_DIST run parameters:
>                   Process grid nprow 2 x npcol 1
>                   Equilibrate matrix TRUE
>                   Matrix input mode 1
>                   Replace tiny pivots FALSE
>                   Use iterative refinement FALSE
>                   Processors in row 2 col partition 1
>                   Row permutation LargeDiag
>                   Column permutation METIS_AT_PLUS_A
>                   Parallel symbolic factorization FALSE
>                   Repeated factorization SamePattern
>       linear system matrix = precond matrix:
>       Mat Object:  (o_slin)   2 MPI processes
>         type: mpiaij
>         rows=382, cols=382
>         total: nonzeros=4458, allocated nonzeros=4458
>           using I-node (on process 0) routines: found 109 nodes, limit
>     used is 5
>     I know this information is not enough to help debug, but I would
>     like to know if PETSc guys will upgrade to 5.1.3 before trying to
>     debug anything.
>     Thanks,
>     Eric
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170101/31f1b5a7/attachment.html>
