[petsc-users] TS question 1: how to stop explicit methods	because they do not use SNES(VI)?
    Jed Brown
    jed at jedbrown.org
    Tue Feb 14 22:34:28 CST 2017
"Zhang, Hong" <hongzhang at anl.gov> writes:
> It is a great idea to require IFunction to be M u_t or u_t. This
> allows us to eliminate the weird 'shift' parameter in the current
> interface.
Noooooo!  That would prevent solving problems with moving meshes or with
transient statements written in terms of dependent variables, like
  d rho(pressure, momentum, temperature) / dt = div(momentum)
where (pressure, momentum, temperature) are the independent variables
but we want a statement of conservation.  There are important all-speed
flow formulations that look like this.
> But the LHS function would be as confusing as the old
> IFunction. Apparently it can be moved to the right hand side. So why
> don't we use
> IFunction
> RHS function 1 / RHSJacobian 1
> RHS function 2 / RHSJacobian 2
> ... (and more if needed)
> Also we can add command line options to control which RHS terms should be treated explicitly/implicitly, e.g.,
> IMEX: -ts_implicit rhs1 -ts_explicit rhs2
> fully implicit: -ts_implicit rhs1,rhs2
> explicit: -ts_explicit rhs1,rhs2
If you want multiple RHS, then make TSPushRHSFunction(ts, "fname", ...);
Put these in a linked list, add
  -ts_rhs_implicit foo,bar,qux
Then TSComputeIFunction walks the list and evaluates anything that was
named while TSComputeRHSFunction evaluates everything else.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170214/7d23e222/attachment.pgp>
