[petsc-users] Using ViennaCL without recompiling
Fri Apr 28 09:46:49 CDT 2017
On Fri, 28 Apr 2017, Franco Milicchio wrote:
> > Not recompiling your own project is fine. PETSc has an ABI. You just reconfigure/recompile PETSc with
> > ViennaCL support. Then you can use -mat_type viennacl etc.
> Thanks for your answer, Matt, but I expressed myself in an ambiguous way.
> I cannot recompile PETSc, I can do whatever I want with my code.
You can always install PETSc.
If you don't have write permission to the install you are currently
using - you can start with a fresh tarball [of the same version], use
reconfigure*.py from the current install to configure - and install
your own copy [obviously at a different location.
Satish
> Thank you!
> 	Franco
> 	/fm
