[petsc-users] explanations on DM_BOUNDARY_PERIODIC
neok m4700 neok.m4700 at gmail.com
Thu Apr 27 03:46:59 CDT 2017
I am trying to change my problem to using periodic boundary conditions.
However, when I use DMDASetUniformCoordinates on the DA, the spacing
changes.
This is due to an additional point e.g. in dm/impls/da/gr1.c
else if (dim == 2) {
    if (bx == DM_BOUNDARY_PERIODIC) hx = (xmax-xmin)/(M);
    else hx = (xmax-xmin)/(M-1);
    if (by == DM_BOUNDARY_PERIODIC) hy = (ymax-ymin)/(N);
    else hy = (ymax-ymin)/(N-1);
I don't understand the logic here, since xmin an xmax refer to the physical
domain, how does changing to a periodic BC change the discretization ?
Could someone clarify or point to a reference ?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170427/ed53d149/attachment.html>
