[petsc-users] Multigrid coarse grid solver
Garth N. Wells gnw20 at cam.ac.uk
Wed Apr 26 17:25:42 CDT 2017
I'm a bit confused by the selection of the coarse grid solver for
multigrid. For the demo ksp/ex56, if I do:
    mpirun -np 1 ./ex56 -ne 16 -ksp_view -pc_type gamg
-mg_coarse_ksp_type preonly -mg_coarse_pc_type lu
I see
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 1 MPI processes
      type: preonly
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      left preconditioning
      using NONE norm type for convergence test
    PC Object: (mg_coarse_) 1 MPI processes
      type: lu
        out-of-place factorization
        tolerance for zero pivot 2.22045e-14
        matrix ordering: nd
        factor fill ratio given 5., needed 1.
          Factored matrix follows:
            Mat Object: 1 MPI processes
              type: seqaij
              rows=6, cols=6, bs=6
              package used to perform factorization: petsc
              total: nonzeros=36, allocated nonzeros=36
              total number of mallocs used during MatSetValues calls =0
                using I-node routines: found 2 nodes, limit used is 5
      linear system matrix = precond matrix:
        type: seqaij
which is what I expect. Increasing from 1 to 2 processes:
    mpirun -np 2 ./ex56 -ne 16 -ksp_view -pc_type gamg
I see
    KSP Object: (mg_coarse_) 2 MPI processes
      type: preonly
    PC Object: (mg_coarse_) 2 MPI processes
      type: lu
        matrix ordering: natural
        factor fill ratio given 0., needed 0.
            Mat Object: 2 MPI processes
              type: superlu_dist
              rows=6, cols=6
              package used to perform factorization: superlu_dist
              total: nonzeros=0, allocated nonzeros=0
                SuperLU_DIST run parameters:
                  Process grid nprow 2 x npcol 1
                  Equilibrate matrix TRUE
                  Matrix input mode 1
                  Replace tiny pivots FALSE
                  Use iterative refinement FALSE
                  Processors in row 2 col partition 1
                  Row permutation LargeDiag
                  Column permutation METIS_AT_PLUS_A
                  Parallel symbolic factorization FALSE
                  Repeated factorization SamePattern
        type: mpiaij
          using I-node (on process 0) routines: found 2 nodes, limit used is 5
Note that the coarse grid is now using superlu_dist. Is the coarse
grid being solved in parallel?
Garth
